| mcjibbin Join Date: Mar 2007 Location: stanwood, wa Local Time: 12:55 PM
Offline | Mechanical Oil Pressure Gauge Tap Location I'm sure this has been discussed before, but I couldn't locate the info I was looking for--so I apologize if this is redundant... Q: What is the best location to tap the engine for a mechanical oil pressure gauge tube? I've heard some discussion about a ProMini kit you can buy, but I couldn't locate the kit on their website or in their catalog. How does the kit work--is that the way to go? I read somewhere that it taps into the oil filter housing. It seems that would be a pain when changing the oil. Any feedback from someone running this kit would be awesome. Doesn't the Mini have an OEM oil pressure sender somewhere (for the check engine or oil pressure warning light)? Would it be possible just to purchase a brass tee and tap in to the engine at that location? Any feedback or suggestions would be greatly appreciated. Thanks, Austin |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 08:55 PM
Offline | The oil pressure switch screws into the oil filter housing, you'll see it located to the left off the starter heat shield if you remove the header shield cover, if you're really lucky you can see the green plug if you look beyond the oil filter housing. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| Oil pressure mechanical gauge how to | steebo777 | Engine & Drivetrain Tuning | 0 | Apr 11th, 2005 03:45 PM |
| oil pressure gauge | Cooper S Ire | MINI Cooper S | 2 | Jan 24th, 2005 07:11 PM |
| Oil Pressure Gauge | Amigo | Engine & Drivetrain Tuning | 0 | Jul 16th, 2004 01:52 PM |
| Oil Temp / Pressure Gauge | JCampos | Engine & Drivetrain Tuning | 2 | Jun 2nd, 2004 02:10 AM |
| Boost and oil pressure gauge | BigM | Engine & Drivetrain Tuning | 4 | Oct 25th, 2003 07:01 PM |
