Carccessory.com
Old Mar 24th, 2007, 10:16 PM   #21
uncle albert
uncle albert's Avatar
Local Time: 09:51 PM
Oh crikey, yeah you're power plot wobbles from 4500 onwards! Defo bigger issue than running lean there!
James
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 24th, 2007, 10:18 PM   #22 (permalink)
62Lincoln
Local Time: 04:51 PM
Quote: Originally Posted by 1320autos (original)
Futureal33,
Did they record the afr while dynoing your car?
Did they record the timing or fuel trims while they were dynoing your car?
I agree with this poster, you really need to know this information to make informed decisions. Speak with the mechanic that performed the dyno about what he would charge to add a bung to your exhaust, which would them allow him to get the readings mentioned above. Without them, there's no way to know what to do. As an aside, MINIs typically run very rich, so don't be surprised if you find that your A/F ratio is not leaning out.
Old Mar 25th, 2007, 08:50 AM   #23 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi, to get any meaningful results you need ;-
(1) a wide band system
(2) the sensor screwed in the exhaust using a welded on bung. - GTT decat pipe is very usfeul for this .
(3) Sensor positioned before the cat.
Any less than this and you cant rely on the results at all. To make adjustments /changes without this could be suicidal to your engine. TBH there is more likely a fault . You need to find it and cure it rather than try and change other things ( eg a re-map) to counteract it.
The normal thing to do is take the car back to the tuner (lohen?) who did the work. I'm sure they they will sort it for you.
Best Regards Roland GTT
Old Mar 28th, 2007, 02:30 PM   #24 (permalink)
DiGiTaLBee
Local Time: 11:51 PM
These are my dyno results:
ID:	130695 Click image for larger version
Max power 236.9 Whp at 7400rpm.
The car is a Mini Cooper S F/L with 15% pulley, modified cylinder head with stock valves, 63mm throttle body, Alta CAI, OBX manifold, Scorpion exhaust, GTT intecooler, Schrick camshaft and program from MiniSpeed.UK.
I know I have a problem with my A/F ratio from around 2300-3500rpm and then from 6400rpm and up. I also have a very strange boost reading (black line) that can not figure out.
What do you guys think?
Last edited by MINIAC : Mar 28th, 2007 at 04:40 PM. Reason: Attach oversize images
Greece   Reply With Quote
Rolling Road Ven0m Engine & Drivetrain Tuning 32 Feb 25th, 2008 04:11 PM
Rolling Road Test RESULTS - CAI & Ebay Manifold BigShow Engine & Drivetrain Tuning 20 Aug 22nd, 2007 09:35 AM
My Rolling Road results at 1320Autos Richard22b Engine & Drivetrain Tuning 20 Jul 28th, 2007 12:23 AM
Rolling Road Results FAO; People In the Know! Mat-CooperS Engine & Drivetrain Tuning 14 Apr 26th, 2007 04:52 PM
Rolling Road James Haigh MINI Cooper S 3 Feb 28th, 2003 02:35 AM
