Visit Derek Woodman MINI
Tags: , ,
Old Jun 6th, 2007, 02:56 PM   #1
Richard Crofts
THE STICK
Richard Crofts's Avatar
Local Time: 11:59 AM
Requirement of sparks on 15% pulley
OK guys
Just wondering how long you could run an S with Milly mani, milly exhaust and alta intake on stock plugs once the pulley is on. Alta 15% pulley is not too big a reduction so what is the real likelyhood of having a problem with sparks getting over hot? Anyone just running thier 15% on the stock sparks?
Also out of interest how many folks run a 15% on a stock belt rather than a reduced belt?
TIA
R
Old Jun 6th, 2007, 03:06 PM   #2 (permalink)
MiniPetrolHead
263bhp / 284.55Nm Torque
MiniPetrolHead's Avatar
Online
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
I dont have a Mini CooperS yet so i cant offer to much advice, but by the mods you have, your Mini will be putting out around 220-230bhp, so i really would change the plugs for some Iridium ones either from Lohen, MiniMania or GTT.
Having the correct plug in any car is vital for reliability, because if something go's wrong with the plugs your engine will be B*g***d!!!
For £30 or so, i really really would recommend you getting some Iridium spark plugs asap!
If you notice, every performance package provided by the tuning companies all include iridium spark plugs for reliability, and smooth engine running and thats even for the Mini One and Cooper!
Alex
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 6th, 2007, 03:42 PM   #3 (permalink)
Richard Crofts
THE STICK
Yeah it seems OK at the moment but just wondered if anyone was leaving there stock in and not had an issue. Will change to colder iridium ones (the irridium doesn't make them colder its that that i'm wondering about as you can get standard heat range iridium ones and they are cheaper than colder ones) at some point but can you leave them in as i don't want to push my luck and then cost loads of cash...i drive pretty fast as well so advice or experiences good and bad?
Old Jun 6th, 2007, 04:03 PM   #4 (permalink)
sef
Affinity to 1320 Autos
sef's Avatar
£62.00 from Lohen
United Kingdom Male View sef's Hyper Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 6th, 2007, 10:34 PM   #5 (permalink)
Ant FR
half that if you just get a set from your local motor factors. there not special to Lohen, NGK or Denso, in fact Denso's are cheapest
Old Jun 6th, 2007, 10:55 PM   #6 (permalink)
Loui
230whp an counting
Loui's Avatar
Or even speak to 1320 there using cheap NGK`s in the s drag car, apparently the same as they use in cossies
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 6th, 2007, 10:56 PM   #7 (permalink)
Loui
230whp an counting
Loui's Avatar
Alex
230bhp you smoking crack????????????????
Old Jun 7th, 2007, 04:59 AM   #8 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Local Time: 06:59 AM
Online
Quote: Originally Posted by Richard Crofts (original)
OK guys
TIA
R
Colder plugs are really not needed for a 15% pulley. I was running stock for a year before I switched to colder ones. I wanted to see what the hype was about and all I have found out so far is that I am out about 30 quid. Not worth it IMHO and my stock plugs looked great when I pulled them.
As for the belt, I run stock size but bought a gator (Goodyear) belt. No need for a reduced belt either.
Global Moderator
Old Jun 7th, 2007, 10:11 AM   #9 (permalink)
Richard Crofts
THE STICK
Well its about 220 Loui you mean old dog you!
The only thing missing is an uprated IC. The bypass mod I have adds a bit to the rest of the setup meaning i achieve around the 220 me thinks. We'll see on the RR....i'm catching up fast loui...Run
Old Jun 7th, 2007, 10:19 AM   #10 (permalink)
Loui
230whp an counting
Loui's Avatar
we`ll see wont we
Old Jun 7th, 2007, 12:10 PM   #11 (permalink)
Richard Crofts
THE STICK
Bring it on big boy!
....Suddenly realises the connotations of that statement and that Loui has a faster car
Old Jun 7th, 2007, 12:14 PM   #12 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Online
Good thing you put that little extra bit in there....
Global Moderator
Old Jun 7th, 2007, 12:55 PM   #13 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Well put it this way. I put a hole through one of my exhaust valves and the only real cause of it for me was incorrect spark plugs.
My car had a Hartge conversion, plus manifold, sports cat, exhaust, a remap and colder plugs. It wasn't until the car went into limp home mode I discovered that at some time the plugs had been changed back to standard.
It was acceptable in the 80's
Old Jun 7th, 2007, 01:04 PM   #14 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Online
It definitely depends on the mods that have been done. You definitely needed the colder plugs but just a 15% pulley doesn't really require it.
Global Moderator
Spare wheel requirement for UK MOT? Mull3t Wheels, Tyres & Brakes 6 May 4th, 2007 04:41 PM
Recharged battery and now get sparks when reconnecting leads! stellablade Maintenance & MINI Care 8 Feb 11th, 2006 10:47 PM
Sparks Plug Wire lemoncoke Engine & Drivetrain Tuning 1 Nov 2nd, 2005 07:10 PM
New Mini Models!!! Sparks... Highly collectable!! MiniCooper Models Collectables & Collectibles 15 Oct 23rd, 2005 09:51 AM
Are these a legal requirement? LANER General Discussion 15 Jul 17th, 2002 10:43 PM
