| Tags: opcon |
| MINI2 Master | Opcon Supercharger??? Been speaking with my mates Dad and he has a strange old mini, it really seems to be bits from all over the place, a Hartge head, different pulley, etc anyhow he has been told to try fitting an Opcon Supercharger and you can be looking at nearer 290 Bhp. And on top of that it will only require 20bhp to run it. Now i am a little skeptical. and did search o here but only one post came up from back in 2002. So anyone know what he's been told, Anyone heard similar I can't see that just a different supercharger is onna boost that much, as surely the problem is not boost levels as M45's already push 18PSi ( which is actually high even comapred with turbo cars) but more along the lines of Flow, ie headwork, cams, intake system etc etc. Any ideas |
| | #6 (permalink) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 10:07 PM
Offline | So far the superchargers available are 1 the eaton -roots type -pump 2 the rotrex -centrfugal compressor-(turbo but belt driven) 3 the opcon- mine is ,I believe the only one in the world!! -twin screw compressor 4 the larger eaton m62 is being tried but suffers as does the m45 |
| | #9 (permalink) |
Offline | Hi Roland , The conversion was always with the opcon, I never considered the larger M62 (I think the americans are trying) ,it is by nature (roots) inefficient and simply consumes too much hp . and too many pumping losses,What I am trying to achieve is not so much the bhp gain but monster torque and a torque curve to die for!! -the twin screw does not have an efficiency area or rpm where it works best at like the the rotrex (centrifugal compressor) and matches centrifugal compressors in efficiency terms- clearances are much tighter than the rotors in the eaton and far less losses there too. I expect around 40 degree + drop in temp over the eaton at the same boost and a saving of 20-30 bhp in terms of power to drive it (so that kinda answers bluesox question) an interesting google search is the Hartge H50 (M3) they used an opcon in a one off car and created their fastest ever car!! --"wall of torque" another US company has an opcon on a M3 (e36)as a kit ,makes around 435bhp and the torque curve , well curve is the wrong word -its a flat line Hartge H50 Compressor H50 compressor articleregards Adam |
| | #10 (permalink) |
Offline | A good read -well presented and clears up a few myths about the eaton, anyone considering tuning a cooper s should have a read it explains a bit why the charger does not like being worked too hard ,and why so much heat is generated when trying to do so. also explains "boost pressure" relative to a supercharged engine -its still missunderstood by owners. I am working in conjunction with Dennis P at AJ6 superchargers on my car and the conversion,I have had a delay on getting a quality intake fabricated (Graham at GRS has kindly offered to make one for me) but for the time being I shall go with the rubbish one I have to enable testing and get a proper finished one later ,post testing . I would like to get the car upto Paul at 1320 autos for dyno runs(the MINi world is small isnt it?) and it would give a good comparisson against stock numbers. The UK is trying to keep pace with our US cousins over the water ,and I sure we will keep up! ![]() |
| | #12 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 10:07 PM
Offline | Also known as Mr 6 whose just had his old dragster returned to him last weekend to be restored. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #13 (permalink) |
Offline | Looks like my Mini horsepower record on the dyno isn't going to last long ![]() Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #14 (permalink) |
| The Power Cube | I always understood the S/Charger to be a non-improvement part. It sounds interesting that it may now become viable to replace the S/Charger with a unit that is more efficient and provides a performance increase.... Have not read any articles yet so don't have a techy appreciation, but definately V. interested in the topic if it leads to a modification possibility... Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| | #19 (permalink) |
Offline | You'll be able to buy it as a bolt on from Adam at MiniMania shortly, I know I keep saying it but its very exciting times for horsepower hungry Mini owners, the problem could be is that there is to much choice ![]() Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #20 (permalink) |
Offline | I am doing a kit which is bolt on ,but it does require a bit of mechanical aptitude,also comes with an electric water pump ,and oil lines ,oil adaptor plate,oil cooler,intake ,injectors x2,control unit,vent lines,belt,charger,charger mounts,wiring loom,water pipes,fuel line ,adaptor ,etc -not looking so simple bolt in is it? ![]() The control unit will be preset but adjustable, the car does not require remapping as there are 2 extra injectors that only work when charger is "on boost "controlled by the control unit, it means "off boost "conditions like idle the car runs as standard . the extra fuelling is only added when boost is above the stock levels at any rpm . price is tba and not finalised,but as always powerful cars cost ££££££, in more ways than the just kit price - the standard clutch for example would be struggling to cope ,like wise the engine mounts,and driveshafts -we have uprated versions of all these but they all cost, tyres also will not last long if spirited driving done If MPG is an issue you really dont want this conversion,6 injectors at full chat on full boost will be hardly "green", off/low boost however would be slightly better than stock due less parastic drag from s/c My question is what would owners be prepared to pay for such a conversion? |
| OPCON conversion | MINIMANIAUK | Engine & Drivetrain Tuning | 61 | Mar 3rd, 2008 11:20 PM |
| Supercharger | MiniBimmer | MINI Cooper S | 5 | Oct 13th, 2005 02:55 AM |
| Supercharger | docmagoo2 | Engine & Drivetrain Tuning | 2 | Aug 17th, 2005 10:08 PM |
| MCS Supercharger vs Works Supercharger | LMB | John Cooper Works & GP | 60 | Jul 15th, 2003 08:41 PM |
| Supercharger | Mini S | Engine & Drivetrain Tuning | 5 | Nov 15th, 2002 07:57 AM |
