| Tags: exhaust, heat s, mini, sealant, silicone |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 11:57 PM
Offline | Exhaust Tempretures?? Guys Anyone know the sorts of temps the exhaust on an S has to cope with. Want to know wether I can use a silcone sealant on it bu the various ones have diofferent heat ranges...what sort of max temp do I have to ensure the sealant can deal with? Ta Richard |
| 263bhp / 284.55Nm Torque Join Date: Oct 2006 Location: Eastbourne E.Sussex Local Time: 11:57 PM
Offline | On my mates Mini cooperS after a good thrashing the break discs, manifold and cat were glowing orange, it will have to cope with ver high temperatures even with normal driving. Easyest thing to do is get the sealant with the highest temperature rating ![]() Alex |
Offline | So something that can deal with 500 should be alright then I guess. Shes only running around 220 brake and its just to seal the gasket joints and the centre pipe on my milly. Exhaust assembly paste seems to be a load of ***** ![]() |
| | #8 (permalink) |
Offline | Whats suggested as the best way to seal the joints on the milly manifold/exhaust system then...exhaust paste, silcone and a gasket, just a gasket or exhaust paste with a gasket? Thoughts guys as I need to try and do something before sunday if I can manage it. |
| | #9 (permalink) |
Offline | How is the joint at the cat an issue roland as the o2 sensor is upstream by quite a bit. Is it a situation of vacuum sucking bit onto the sensor as gas flow from the engine drops on overrun or something? |
| | #10 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 11:57 PM
Offline | Hi Richard, it may be fine but the second sensor is pretty close to that flange although as you say downstream. The Miltek gaskets are pretty good, see if they will supply you a couple of new ones. Also check both flanges for flatness with a straight edge. As a second choice 'used' Miltek gaskets with a thin smear of exhaust sealant paste on both sides . Best Regards Roland GTT ![]() |
| | #11 (permalink) |
Offline | Top man...hopefully its a short term measure as i fancy a GTT mani and a borla agressive system all brand new soon. My second hand milly might go up for sale as its agressive but I want larey! ![]() |
| Retro fitting JCW exhaust tips to MCS Exhaust | Cooooooperslad | Exterior | 13 | Jul 3rd, 2007 01:33 PM |
| What exhaust is this?! | sprp85 | Engine & Drivetrain Tuning | 7 | May 29th, 2007 08:30 AM |
| JCW GP Exhaust on Mini One(dyno inside without\exhaust) | Innuendo | MINI One | 13 | Feb 25th, 2007 10:15 PM |
| 05 stock MCS exhaust sound vs. JCW exhaust - pops or no?? | MiniMelSF | Engine & Drivetrain Tuning | 7 | Jul 1st, 2005 07:10 AM |
| **UK** Magnaflow Cooper S exhaust swap for other aftermarket s exhaust | B4d4Bing | For Sale | 3 | Apr 11th, 2004 05:51 AM |
