Tags: , ,
Old Jun 26th, 2007, 10:28 AM   #1
mkone
Local Time: 09:56 PM
BMC CDA Air Filter for Cooper S
Hello,
Just wondering if anyone could offer their help. I've a BMC CDA Air Filter that was fitted to my previous car (VW Polo GTi) I was wondering if it is possible to fit this to my Cooper S?
The model of the kit is as follows:
Code : CDA70-130
D1 (mm)D2 (mm)L1 (mm)70130185
SUGGESTED UP TO 1.600 CC
On the BMC website it says the kit I have will fit the 1.6 One and there is a seperate version intended for the Cooper S which has the following dimensions:
Code : CDASP-10
D1 (mm)D2 (mm)L1 (mm)70150160
D1 is the connection to the engine which is the same on both filters, D2 is the width of the filter and L1 is the length of the filter. It appears that the model I have will connect to the car but with the length being 25mm longer will I run into problems? By looking in the engine bay it appears to fit!?!
Also after I've removed the standard airbox where do I go about attaching the battery terminal? Do I simply leave it hanging? Is there anything else that would need securing?
Thanks in advance for any helpful advice!
Mark
United Kingdom Male View mkone's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 26th, 2007, 12:01 PM   #2 (permalink)
kalv
kalv's Avatar
Local Time: 10:56 PM
Trial and error... take it apart and have a go... shouldn't take you more than an hr...
As for the battery terminal... not so sure...
"bhp sells cars, torque makes them move..."
Old Jun 26th, 2007, 02:46 PM   #3 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 01:56 PM
Online
Perhaps the battery terminal can be attached to the filter canister mounting bracket ...
Old Jun 26th, 2007, 04:53 PM   #4 (permalink)
mkone
I didnt think to attach it to the cannister mounting bracket thanks for that! I'm going to give it a go fitting this weekend if I can, fitting on my old car proved something of a nightmare lets hope this trial install goes ok. When it was on my old car it sounded perfect so cant wait to see if it fits ok.
Intake kit which one is better Alta vs BMC CDA? asinn Engine & Drivetrain Tuning 15 Feb 18th, 2006 05:19 PM
best place to get BMC CDA intake for MCS asinn Engine & Drivetrain Tuning 1 Sep 2nd, 2004 06:07 PM
BMC CDA Induction for Cooper lmassauk Engine & Drivetrain Tuning 0 Jun 30th, 2004 02:47 PM
BMC Replacement Air Filter wongakh Engine & Drivetrain Tuning 2 Jul 25th, 2003 11:58 PM
