| Tags: gtt cylinder head |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 12:10 PM
Offline | 244bhp from GTT Head etc Hi Guys, one of our customers has just sent us over a RR printout of his car on an independant RR. The only mods are as follows:- GTT Stage 3 head Shrick cam GTT17% pulley GTT Re Route pipe GTT/JCW hybrid filter upgrade JCW injectors Re-Map Power..... 244bhp. Prior to the head the power was 210bhp (on a different RR) Car has stock intercooler and stock cat. Apparantly the RR operator said this was easily the most powerful MCS he had tested & judging by the the graph the power was still climbing at the 6800 soft cut rev limit. I dont know any more than this, but is looking good ![]() Best Regards Roland GTT ![]() GTT CNC MILLED HEADS With our heads not only do we mill out the exhaust ports (3D) but also the valve throats (again 3D). Im not aware of anyone else doing the latter. The head was supplied to the customer for DIY fit with ONLY the milling parts done ,(normally we hand fettle them a fair bit more) and was fitted to the engine just about 'as it came off the mill'. With the fettling fully completed there may? have been even more power. . |
Offline | Hi guys, we also do a stage 4 head(even larger exhaust valves). This is now on our turbo'd MCS Were also putting 3 angles on the valve seats, this too is all CNC interpolated ![]() -See this car on the track at the Castle Combe Mini day in Sept. ![]() Best Regards Roland GTT ![]() |
| | #7 (permalink) |
| Overly excited!! Join Date: Aug 2006 Location: Worcestershire Local Time: 12:10 PM
Offline | Is the stage 4 head useable on a standard-ish engine? Then if someone wants to upgrade to the turbo kit you do they dont need to buy that part of it? Last edited by Bhozar : Jun 30th, 2007 at 09:37 PM. |
| | #8 (permalink) |
Offline | Ant...Hi, pm/telephone and we will work out some prices. Al....Difficult to quantify the difference,but our car had GTT stage 2 when it made 273 bhp (240 wheel horse power). Just prior to taking our car off the road for the GTT300 turbo conversion,we put a GTTstage 4 on in pllace of the Stage 2 (no other changes). The car was definatly quicker particularly at high rpm,but its not a massive difference. Bhozar.... This is a good point. As it happens we have a car coming down in 2 weeks for GTT stage 4 head & cam,with the intention of bringing it back again in 3 months for GTT300+ treatment. The car is a ex JCW challenge car,and I know its going to get some serious stick on trackdays. GTT300 uses stock head,our car with GTTStage 4 head is dubbed GTT350.There are other minor differences such as 3 bar MAP and even bigger injectors. This runs (and holds) 24psi to redline. GTT300 will run (and hold) 21psi to redline. Rev limit only slightly raised to 7200 which is 7000 'soft cut' . Stage 4 head on a mildly modded car is absolutly fine. Best Regards Roland GTT ![]() Karl.....stop it! ![]() |
| | #9 (permalink) |
| 230whp an counting Join Date: May 2002 Location: Mini Addiction Local Time: 12:10 PM
Offline | Blooming eck roland at that you should have held the fastest quarter mile time for a M45 superchargd mini. Cause this was a fair while ago now. What times did you run? |
| | #10 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 12:10 PM
Offline | Nice 34bhp delta there Roland, has the customer got the 210 dyno sheet or can he overlay them. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #11 (permalink) |
Offline | Hi Guys, we never dragged it with 270bhp. In fact the only time was when it had GTT220 (plus IIRC GTT Re-Route & GTT 63mm Throttle Body & early GTT prototype stage 2 head &cam ) at the pod with usual strong headwind 14.21 secs and 100mph. I'll see if hes got the original plot before the cam& head were added. Best Regards Roland GTT ![]() Last edited by roland2003 : Jul 3rd, 2007 at 07:08 AM. |
| | #12 (permalink) |
| Mini2 Sponsor & Tuner Join Date: Jun 2005 Local Time: 04:10 AM
Offline | what was the correction factor they were using on the Dynodynamics dyno? If they dyno'd the car on a different dyno how can you be sure the delta was 34bhp? It makes it difficult to compare apples to apples when there are so many variables in the equation. Never-the-less , I am excited to see what your turbo car will produce with the stage 4 |
| | #13 (permalink) |
Offline | I put it down to age Roland, I know I do ![]() Went to Santa Pod Raceway yesterday for our 'debut'runs. Ambient 18degrees C.dry but cloudy,moderate/strong headwind plus uphill 3ft over the quarter! SPEC GT TUNING LTD Cooper S: GTT Cold Ram '360 degree' Intake, GTT Large Throttle body, GTT Stage 2 Cyl Head &Manifolds ,GTT Modified OE header with one cat removed, GTT Re-route pipe on OE exhaust (deletes one silencer),GTT Camshaft(With adjustable timing) GTT 15psi pulley plus GTT Idler pulley,GTT knife edged Snoot, STD intercooler, STD V37 Map, OZ 17" Wheels with Road Legal tyres , ie Dunlop Sport DO1J (Hardest compound) STD Diff, Pump fuel (UK97 Ron ,US 94?) WEIGHT : STD less substitute wheels /tyres&rearseat out. TIMES Best Quarter mile 14.21secs @99mph ,(also other 14.2's.) Best terminal speed 100mph ,Best 60 ft 2.4secs Regards Roland GT Tuning Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #14 (permalink) |
Offline | Well it was over 2 years ago,I knew I'd posted it somewhere. The clutch ((Standard)was never the same after the pod. , -I'll stick to the racetrack . I also occasionally have memory failure in the opposite direction aswell , I thought Tonys car made 210bhp prior to the GTT head & cam. It was actually only 204 (I'll put the graph up later), making a difference of 40 BHP not 34BHP! ![]() 1320 Autos.. ...BTW Is your RR able to measure (as opposed to adding a correction factor if required) the rundown losses? Best Regards Roland GTT ![]() |
| | #15 (permalink) |
Offline | Congrats on finding an extra 6bhp and you didn't even have to get your hands dirty. Its a Hoffman dyno and uses the TAT system to record all data etc etc Chassis Dyno Software Chassis Dynamometer Software Rolling Road Software Inertia Dyno Data Acquisition and Control , it is a heartbreaker of a dyno and most of the time I hate it because what I think will work doesn't. We made 19 runs experimenting yesterday and finally tuning the afc, I'm looking for more trq at the moment rather than peak numbers ![]() Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #17 (permalink) |
Offline | No,but a standard GP went on the same RR as this one a week later and made 202bhp (flywheel),which is 16bhp down on manufacturers claims,so it would appear this RR doesnt inflate figures .....possibly the opposite? Best Regards Roland GTT ![]() |
| | #18 (permalink) |
Offline | Thanks Roland, I took my GP to the same dyno we dyno'd our head on and it only pulled 180whp to the ground, the car with my head on it pulled 231.9whp. It happens to be a dyno dynamics , by the looks of it they are NOT using a correction factor of 12%. Regardless its still a nice gain. It's too bad everyone doesnt use the same correction factors as it's already difficult enough to compare apples to apples. btw... how is the turbo car coming along? Have you got the new head on it yet? |
| | #19 (permalink) |
Offline | Here's the dyno results that Roland is referring to in his GTT stage 4 head ...50bhp? title thread. Is this the Surrey Rolling Road we were at the other Saturday?? Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| CAI/Induction. Alta vs GTT vs JCW/GTT vs K&N etc... Which to choose? | AMF310182 | Engine & Drivetrain Tuning | 25 | Feb 24th, 2007 12:53 PM |
| GTT JCW Hybrid vs GTT CAI | cooper7 | Engine & Drivetrain Tuning | 1 | Aug 4th, 2006 09:07 AM |
| head gasket / knackered head arrgh | welsh_willo | Faults & Fixes | 0 | Feb 3rd, 2006 09:38 PM |
| head unit causing my head to spin!! | kars | Interior & Ice | 10 | Oct 29th, 2003 03:54 PM |
| Head Units doing my head in | soopacoopa | Interior & Ice | 3 | Aug 18th, 2003 02:15 PM |
