| Tags: strut brace |
| MINI2 Regular Join Date: Dec 2003 Location: Hemel Hempstead Local Time: 10:06 PM
Offline | Top & Bottom Strut Brace Fitted - Road Noise Hi, A couple of weeks back I had some Eibach springs fitted to the Cooper and to compliment them I have today fitted an OMP Upper and Lower Front Brace too. Took it for a drive and it feels really good, nice crisp turn in and more controlled. But the point is I did notice the road noise was more evident, is this the norm when fittng braces due to the fact your fixing suspension/chassis points together? I'm running 17" Dunlop Runflats if that makes a difference. Cheers, |
![]() :: 32mpg woo! :: | I've got the OMP upper and lower strut braces on my car, although with standard suspension and non-runflat tyres, and personally I didn't notice a difference in road noise. Although with mine being a cabrio there was probably more road noise to begin with anyway ![]() I wonder to what extent the Eibachs and Runflats may contribute to road noise? I've never had either so I can't compare. |
Offline | one thing I did do was remove the sound deading from under the bonnet to give a bit of clearance for the top brace, could be contributing to the noise. Did you get 4-wheel alignment done after fitting the braces? Wondered if I've knocked the settings out by undoing the lower bolts to cause the noise? I'll have a longer drive tomorrow and see how it feels/sounds. |
| | #6 (permalink) |
![]() :: 32mpg woo! :: | I removed my sound deadening too, but then my upper strut brace started rubbing on the bonnet, so I've now put a small pad on each side where the two make contact. My braces were fitted by the guys at Lohen and I don't think any wheel alignment was done... but I'm not sure. Let us know what you think after your longer drive.. If anything I would be tempted to change to normal tyres when you next need a set, as like GTT 270, I'm not a fan of runflats. I would have thought doing this should help reduce road noise slightly, and it might also take a little harshness out of the ride. ![]() |
| | #7 (permalink) |
Offline | Been for a longer drive today and happy to say all sounds OK, I think it was just me being a bit paranoid . It really does handle like it's on rails now, with long sweeping A-road bends a real buzz to drive through. Found myself pushing a little harder through roundabouts too .I've also placed a foam pad on the strut brace to stop contact with the bonnet, but called onto my local car shop and found some self-amalgamating (I think) tape which looks really robust, works upto 300C and only sticks to itself. Thought it might finish it off and protect a bit better on that contact point (a bit like Lohens pics). Try it out tomorrow and let you know how it goes |
| Has anybody fitted a Forge front strut brace | fozworth | Suspension | 0 | Sep 26th, 2006 07:26 PM |
| Has anybody fitted a Forge front strut brace | fozworth | Engine & Drivetrain Tuning | 0 | Sep 24th, 2006 07:46 PM |
| Problem with my FORGE top strut brace | fozworth | Engine & Drivetrain Tuning | 0 | Sep 17th, 2006 09:52 AM |
| New upper ánd lower strut brace fitted | Berthil | Suspension | 101 | Jul 7th, 2006 10:24 AM |
| JCW Strut Brace - Fitted to Cooper | minicabrio | Suspension | 24 | Jun 28th, 2006 08:45 AM |
