Tags: ,
Old Jul 26th, 2007, 04:36 PM   #1
Promini
'03 Turbo Cooper S
Promini's Avatar
Local Time: 05:07 PM
Supersprint Center Exit Exhaust for Mini Cooper
Hey Everyone,
Supersprint NA, has decided to run a limited time discount on the Center Exit Supersprint Retrofit for the Cooper, The Cooper center exit exhaust has been in our program for several years. The system was designed to give the S look to the normal Cooper and is constructed of 100% 304 stainless steel. The system is quite popular in Europe. It does require the removal of the spare tire and associated mounting hardware. This is the same concept as the Cooper S, relying on the run flat tires without a spare. The advantages are that you now have a much broader choice of aerodynamic kits, since many kits are design only for the Cooper S. You save a huge amount of weight (almost 35 lbs.) with spare tire and factory muffler assembly removed. The project is totally reversible with the exception of the black rear trim panel. You have a choice of 6 aggressive tip designs.
Since our choice here at Promini/Supersprint NA was to increase the sound somewhat we opted to install the Supersprint mandrel bent center pipe and rear muffler. For a quieter tone, the alternative would be to use the Supersprint center resonator in place of the center pipes.
Click the Link below for a sound clip...
***(The system in the sound clip below is the system shown in the following pictures and is of the Non-Resonated Center Pipe, Center Exit Muffler, and BMP RS Tips)***
http://www.supersprintna.com/multime...CenterExit.mp3
Center Pipe (Resonator Replacement)
022 830 413
Price: $172.40
Center Exit Muffler
022 830 504
Price: $329.60
Viper Tip (for Center Exit Muffler)
022 830 567
Price: $237.02
Dual BMP RS Tips (for Center Exit Muffler)
022 830 556
Price: $166.37
Dual DTM Tips (for Center Exit Muffler)
022 830 566
Price: $215.48
Dual Round Tips (for Center Exit Muffler)
022 830 516
Price: $215.48
Dual Rectangle Tips (for Center Exit Muffler)
022 830 518
Price: $210.69-------------------------------
Cooper Center Exit Muffler Install:
Step 1:
Using a liberal supply of WD40 on all fasteners, remove the two 10mm nuts at the rear of the catalytic converter. With the help of an assistant to support the muffler, remove the center resonator support and the two 13mm nuts securing the lower muffler bracket. Now remove the assembly as one unit.
Step 2:
Remove the spare tire and all the associated hardware. You will need to trim away a portion of the factory muffler heat shield, leaving the portion that protects the center pipe or resonator.
Step 3:
Using new gaskets and hardware as needed, install the Supersprint center pipe or resonator. Do not fully tighten the fasteners in case you need to make some adjustments.
Step 4:
Install the Supersprint rear muffler with your choice of tail pipe tip. Leave hangers loose until all final adjustments are made. Raise the muffler until it contacts with the lower black trim lip of the rear bumper. Attach the supplied template to the trim piece with masking tape. Use the reverse light assembly as a centering guide for the placement of the cut out template. Confirm the muffler is centered and will attach to the hangers in the centered position of the template. Use a coping saw to cut out the muffler exit opening. (this can be purchased at most building supply stores for approx. $7.00) Note: you must save the cut out section since it will be used to create the plug for the original side exit opening.
Step 5:
With a Dremel tool or a round wood dowel wrapped with sand paper, smooth out the edges of the opening.
Step 6:
Place the small cut out piece over the original opening and from the inside trace or outline the new plug shape. Sand and trim the plug to fit the opening. From the outside of the trim panel use masking tape to hold the piece in position. From the behind use black silicone adhesive to attach the plug and allow to dry overnight.
Step 7:
Lift the muffler into position and attach using the original as well as new hangers provided, making sure the tip exits the trim piece without making contact. If needed, you may need to trim the opening slightly for additional clearance.
Jonathan Daniels of Promini, BMP Design, and Supersprint North America...
What center exit exhaust have you got on your mini one/cooper .Boyracer. Exterior 3 Aug 13th, 2005 03:32 PM
Laser Twin Center Exit Exhaust Wanted For Mini One .Boyracer. Exterior 1 Jun 7th, 2005 07:54 PM
Laser Center Exit Exhaust ..lee1.. Exterior 0 Apr 26th, 2005 10:51 PM
Center exit exhaust on Cooper modmanmini Engine & Drivetrain Tuning 3 May 10th, 2004 02:13 AM
Center Exit Exhaust For Cooper?! supercuper Exterior 5 Dec 11th, 2002 12:57 AM
