Carccessory.com
Tags: ,
Old Aug 28th, 2007, 01:17 PM   #1
lucachiarelli
Banned
Local Time: 11:09 AM
which option do you think?
I am down at GTT next week to have the gtt manifold fitted. I have a little extra money to spend so I have two options.
Option one: Larger fuel injectors with existing bluefin map or going back to standard map with larger fuel injectors. Try both out on the day to see which is best.
Option two:
Enlarged throttle body. Maybe changing back to standard map.
both options are to accompany the manifold.
Current mods:
2006 mcs
15% pulley with reduced belt
Minisport bluefin map to suit pulley mod
Alta CAI
GTT top mount intercooler
Milltek catback exhaust
Oil catch can
Upper and lower strut braces
England Male View lucachiarelli's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 28th, 2007, 01:19 PM   #2 (permalink)
minicabrio
Back in a MINI
minicabrio's Avatar
Online
I haven't got a clue to be honest, but enjoy it whichever you decide to go with
Old Aug 28th, 2007, 01:53 PM   #3 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Do the crank pulley
Personally I'd say bigger throttle body as long as curent injectors are 380 JCWs. If they are not then for a bit of safety I'd probably go for 380 or 400 (depends on what Roland recomends) injectors instead of the throttle body
Old Aug 28th, 2007, 02:50 PM   #4 (permalink)
lucachiarelli
Banned
I have standard mcs fuel injectors. ill probably end up going for both if i can afford it. Ill try and strike a deal with roland
Old Aug 28th, 2007, 06:07 PM   #5 (permalink)
Damo
MINI2fosi
Damo's Avatar
Send a message via MSN to Damo
Quote: Originally Posted by Richard Crofts (original)
Do the crank pulley
What he said, Injectors.
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 28th, 2007, 06:24 PM   #6 (permalink)
uncle albert
uncle albert's Avatar
Injectors.
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 29th, 2007, 04:29 AM   #7 (permalink)
Minipnut
Local Time: 08:09 PM
Send a message via MSN to Minipnut
injectors unless you wanna be runing lean in the top end *gasp*
Old Aug 29th, 2007, 07:50 AM   #8 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Online
...or maybe the GTT Adjustable FPR ?.....We are fitting one tommorow . Need to make sure we can get more made in time first.
Best Regards Roland GTT
Old Aug 29th, 2007, 08:11 AM   #9 (permalink)
Snowie
Snowie's Avatar
Hopefully you are fitting it today and testing it tomorrow
Alan
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 29th, 2007, 07:32 PM   #10 (permalink)
Ant FR
Roland, will the adjustable FPR help with stopping detonation, or would you still need to uprate the injectors to allow the fuel through
Old Aug 30th, 2007, 11:11 AM   #11 (permalink)
lucachiarelli
Banned
should i get the 380cc injectors or larger ones?
Old Aug 30th, 2007, 11:27 AM   #12 (permalink)
Richard Crofts
THE STICK
Both ant FR. The FPR means the fuel pressure does not drop so starving the injector...but the injector needs to be big enough to flow the right fuel (to provide good af mix) anyhow.
380cc is JCW and roland seems to think these do ok on most stuff. I think he likes to recomend 400s for the over 240 stuff if you can afford them as its a bit more piece at mind. I'm sure a quick discussion with roland will tell you all you need to know
Which option (s) ? supa-dupa-cooper General Discussion 28 Jun 2nd, 2008 03:34 PM
Best Option jdr21 Interior & Ice 1 Oct 9th, 2005 10:29 AM
Is the Chrome line interior a factory option or an accessory option? dave316 Interior & Ice 7 Aug 30th, 2004 03:46 PM
new option ? mini mad General Discussion 3 Jun 15th, 2004 03:20 PM
if I order the navigation option, would I still need trip computer option? dualceleron General Discussion 2 Aug 10th, 2002 04:15 PM
