Tags: , , , , ,
Old Aug 29th, 2007, 05:35 PM   #1
roland2003
MINI 2 Sponsor GT Tuning
Local Time: 10:03 PM
GTT Adjustable Fuel Pressure Regulator -TESTING .
Hi Guys, just spent along time testing our new AFPR today...John was sick in the GP (just kidding!) and Im still high from the fuel vapour...That fuel rail came off a total of 15 times.You can adjust pressure without removing it but we wanted to monitor the spring preload in the AFPR at the same time..
The 2 things we wanted to establish were (a) What range of pressure adjustment is available, &
(b) what effect on Air Fuel Ratio 'x amount' of change in fuel pressure achieves.
With the softer spring and no spacer the adjustment range is approx 2 bar right upto 3.5 Bar (which is stock rail pressure with vacuum pipe disconnected). With spacer ifitted,min pressure is 2.9 Bar upto 4 Bar. One thing we found is max rail pressure 4.7Bar. Therefore at more than 1.2 Bar boost (18psi), fuel pressure cannot increase to maintain 3.5 Bar above manifold pressure.
For higher boost idealy you should reduce fuel pressure and use larger injectors at the same time. Eg on this car we settled for 2.75 Bar fuel pressure and 450cc Injectors . (This is a GP not a GTT300 Turbo).
Regarding the effect on Lambda we tested up and down the road dozens of times monitoring Wide Band Air Fuel Ratio and fuel pressure ,adjusting this accordingly.
Around 0.5 Bar 'change' in fuel pressure alters AF ratio by around 0.5-0.8........certainly significant!
Another test we did was check 2 stock regs variation was 0.1 Bar (1.5 psi)
All in all the GTT AFPR does everything I'd hoped for..We have added notches to the outside of the body now, this allows adjustment by removing only the intercooler...simply rotate the body using a screwdriver to push it round on the notches...works well.
All good Fun..Best Regards Roland GTT
Old Aug 29th, 2007, 05:37 PM   #2 (permalink)
Snowie
Snowie's Avatar
Local Time: 11:03 PM
So it is going well then
trying to call you but line is engaged
Alan
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 29th, 2007, 05:39 PM   #3 (permalink)
roland2003
Still here (for another 10 minutes)
Old Aug 29th, 2007, 11:27 PM   #4 (permalink)
supercoopers
supercoopers's Avatar
Excellent!
Old Aug 31st, 2007, 05:31 PM   #5 (permalink)
Lucky Dave
Thinking Minis
Online
I just have to complete my wideband installation and then I can give you some more results.
For All Your Mini's Needs
01905 620011
New GTT Adjustable fuel Pressure Regulator +PICS! roland2003 GT Tuning 43 Sep 11th, 2008 01:56 PM
GTT Exhaust Back Pressure - Measuring& Results roland2003 Engine & Drivetrain Tuning 156 Nov 23rd, 2007 03:12 PM
Fuel Pressure.... TomB Engine & Drivetrain Tuning 1 Jul 19th, 2005 03:16 AM
More Magnehelic Air Intake Pressure Testing Andy@Ross-Tech.com Engine & Drivetrain Tuning 15 Jun 7th, 2003 11:22 AM
Windshield Cowl Pressure Testing At Speed Andy@Ross-Tech.com Engine & Drivetrain Tuning 41 Apr 10th, 2003 07:56 PM
