| Tags: milltek |
![]() I can't get no sleep Join Date: Feb 2007 Location: Errr somewhere. Local Time: 10:06 AM
Offline | Milltek exhaust adjustment??? Can anyone help I've got a milltek on me MCS and it vibrating on the rear valance, its only just contacting is there any way to adjust it as its getting on me love lumps. |
| | #6 (permalink) |
| MINI2 Newbie Join Date: Mar 2006 Location: Northampton Local Time: 09:06 AM
Offline | Lucachiarelli, How did you get on with getting your Milltek fixed? I've got the same issue (not lining up correctly in the centre of the rear bumper) how did they fix it? Thanks |
| | #7 (permalink) |
![]() MINI2 Master Join Date: Jul 2006 Location: Essex Local Time: 10:06 AM
Offline | I had the same issue and just pushed it away from the valance by hand slightly and it has stopped vibrating, you only need to move it a few mm so a slight push is all thats needed ![]() ![]() ![]() ![]() ![]() |
| | #8 (permalink) |
| Banned | Hi Dibby, I took it back to where i got it fitted. They said the clamps that hold the back boxes up werent very strong and did not fit correctly. He said that he bent the clamps as much as he could so that it would keep still. Ive driven it for a week since and had no problems at all. He did say that if the problem came back he would make me up some stronger clamps that fit perfectly. He also said he has stopped dealing with milltek as their exhaust do not fit cars perfectly as they always need adjusting. Take your car down to any exhaust specialist and they will sort it out for you. I only paid £8 which seems pretty reasonable to me. Hope this helps |
| | #10 (permalink) |
Offline | Just out of interest where did you get yours fitted/adjusted ?? I see your from Darwen I live in Bolton always good to know where to take your car if you recomend them ![]() |
| | #11 (permalink) |
| Banned | Hi i took my car to dms in burnley. It used to be top gear. Theyre very good with exhausts as they make their own custom powerflow exhausts and can supply many other exhaust systems such as milltek. Theyre off J9 m65 burnley. Got any pics of your mini? As i am over in bolton quite alot so i can look out for yours. I always have to drive to bolton to get Shell V power as its the closest shell garage to me. |
| | #13 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 10:06 AM
Offline | Hi guys ,we see Milteks that sit too high/knock/dont sit central alot. This is partly a small design fault but tbh most professional fitters should be able to get round it....clearly few can be bothered to. A pity as is a fine cat back. When we fit we use 8 spacers to space it down a few mm. We also use jubilee clips on the hanger pegs to centralise and prevent left/right movement. -Takes longer but definatly worth it. Unfortunatly to space down 'after' someones fitted it too high means taking the whole lot off again.... Best Regards Roland GTT ![]() |
| | #14 (permalink) |
| Blue is the colour! Join Date: Jul 2003 Location: Canberra, Australia Local Time: 08:06 PM
Offline | Yes, I had this problem. http://www.mini2.com/forum/engine-dr...ml#post1885828 Although, it may still be worth taking further precaution as my tips have still melted the valance slightly. ![]() |
| | #17 (permalink) |
| Thinking Minis | Its the 8 vertical bolts in the boot floor, the studs are long enough to accept about an 6mm drop if required. Having fittem may exhausts I would say the Miltek is a top one if fitted correctly. I used 3 chunky washers under each bolt to space the cars exhaust mounts lower and all is fine. For All Your Mini's Needs ![]() 01905 620011 |
| | #18 (permalink) |
| MINI2 Master Join Date: May 2006 Location: Over 4.5k RPM Local Time: 10:06 AM
Offline | I put a jubilee clip on one of the far hanger brackets (I think the left one if your facing the back of the Mini) to pull the exhaust across plus lowered it 5-6mm with 4 spacers after having the exhaust fitted. Put the clip through a slot on the floor and around the bracket. Put the stock exhaust back on is nightmare in the driveway on axle stands. |
| | #19 (permalink) |
| MINI2 Regular | Thank's guys I'll give it a go. The milltek instructions say "Smear a small amount of exhaust assembly paste inside each slotted joint, this will help prevent leaks on start-up and prevent the pipes seizing together." Which are the slotted joints, does this mean round the gaskets, or around the pipe on the mid section that doesn't have a gasket. Should I use it on the gaskets also? Thanks Nick |
| | #20 (permalink) |
Offline | Yep on the manifold use wet and dry paper to clean the surface then put the paste onto both surfaces to make sure the gasket is completely covered. The paste will harden once the exhaust heats up. |
| Anyone got a Milltek exhaust on their One? | MrLee2006 | MINI One | 36 | Jul 12th, 2007 01:34 PM |
| Exhaust replacement (Milltek) | Rainbow-Walker | Engine & Drivetrain Tuning | 11 | Sep 26th, 2006 10:47 AM |
| milltek exhaust | kak | For Sale | 9 | Dec 2nd, 2005 04:30 PM |
| milltek exhaust for the one d | Pepper'D | MINI One Diesel | 36 | Mar 4th, 2005 05:20 AM |
| MC Milltek Exhaust | GregF | Engine & Drivetrain Tuning | 2 | Oct 16th, 2004 08:41 AM |
