Think Mini
Tags: ,
Old Sep 12th, 2007, 03:26 PM   #1
RCMini
RCMini
RCMini's Avatar
Local Time: 10:59 PM
Lightened crank pulley
I have plans on installing Alta's lightened crank pulley on my mini. I have looked for how to's and have come up short. I am currently hanging out in Korea and not able to take a look at my car and I want to check it all out before I put a pulley on order so its there when I get home. Does anyone know if there is a how to out there or have any of you changed you own pulley and taken some good pictures of the process. I installed my own supercharger pulley and several other on some friends' cars so I am not worried about doing it. I read several times that it is much easier because of the ease of access. If anyone can help me out please post it here.
Italy Male   Reply With Quote
Old Sep 13th, 2007, 06:18 AM   #2 (permalink)
BlueMax
BlueMax
Local Time: 11:59 PM
This should sort you out. I will be fitting a GTT 3% crank pulley towards the end of the month, removal of stock pulley same for Alta and GTT, GTT install different because of the inner steel bush that must be heated up (interference fit on crank nose).
South Africa View BlueMax's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 13th, 2007, 08:16 PM   #3 (permalink)
Lucky Dave
Thinking Minis
Local Time: 09:59 PM
Online
I have seen one of these move on the crankshaft after a few hundred miles
It made a mess of the crankshaft and pully, not sure how it was fitted though, I did not think the alloy to steel shaft interferance fit was good practice.
For All Your Mini's Needs
01905 620011
Old Sep 14th, 2007, 06:12 AM   #4 (permalink)
BlueMax
BlueMax
That is the nice thing about the GTT pulley, it uses a stainless steel bush/collar for an interference fit on the crankshaft. The aluminium pulley is then bolted to the collar (photos on the GTT website). The Alta pulley is all aluminium, not good practice fitting it directly onto steel!
19% + 3% crank pulley james l Engine & Drivetrain Tuning 31 May 24th, 2007 05:58 PM
Oversized, Lightened Crank Pulley futureal33 Engine & Drivetrain Tuning 27 Feb 28th, 2007 01:46 PM
17% S/C Pulley + 2% Crank futureal33 Engine & Drivetrain Tuning 6 Feb 8th, 2007 09:23 PM
2% crank pulley ?? brady Engine & Drivetrain Tuning 10 Dec 3rd, 2005 05:37 PM
Lightened crank pulley suprchrgdmini Engine & Drivetrain Tuning 10 May 9th, 2003 11:47 AM
