Performance Torque
Old Sep 20th, 2007, 08:38 PM   #1
flatland69
Local Time: 11:00 PM
6 Speed Conversion Questions
Hey guys, I've searched the forums, and I came up with the following items needed to fit a Cooper S gearbox into a Cooper:
6 Speed box (obviously)
Gearbox Mounts
Sideshafts
Flywheel
Clutch
What else would I need? Just want to be very sure! I'd love to go to 1320 autos, but it's a bit far from South Africa
South Africa   Reply With Quote
Old Sep 20th, 2007, 08:53 PM   #2 (permalink)
Paul Webster
Paul Webster's Avatar
Local Time: 09:00 PM
Gear Stick and cables
Try and get an ally flywheel if you can because the stock one is so heavy.
It's not how much you spend but how well you spend it
Old Sep 21st, 2007, 08:16 AM   #3 (permalink)
flatland69
Awesome! Thanks so much... I was also wondering, is the flywheel and clutch swop just for strength, or is it absolutely necessary? If so why? Also, where could I get a flywheel? Thanks so much 1320!
Old Sep 21st, 2007, 09:21 AM   #4 (permalink)
Paul Webster
The input shaft is much bigger and beefier splines, so thus you have no choice but to change it.
The clutch on the s is physically bigger and can hold more power.
The cheapest option is put the original S flywheel and clutch but its very heavy
The next option is ally flywheel and stock clutch if you want a OEM feeling pedal
The final option is uprated clutch and flywheel like a clutchmasters or exedy both what we can supply but the pedal will be a lot firmer due to the uprated cover.
It all depends how you drive your car and what you want from it.
I knew there was something else; Starter Motor
Old Sep 21st, 2007, 09:48 AM   #5 (permalink)
flatland69
hmmm...yeah I'd love a light flywheel and fancy clutch but I'm on a bit of a tight budget! I can get the gearbox for R2500, which I guess is about 180pound? Not bad I thought...guess it's the same story with the driveshafts?oh well,guess it'll be worth it! my midlands has done 100000km!so I guess it'll be worth it...
Old Sep 21st, 2007, 10:17 AM   #6 (permalink)
Paul Webster
What year is the S?? Its defibtley worth it
Old Sep 21st, 2007, 01:30 PM   #7 (permalink)
flatland69
I haven't actually asked, but I will now! Thanks for reminding me. I DO know that it's only done 7000km...
Old Sep 21st, 2007, 01:37 PM   #8 (permalink)
Paul Webster
Check the front mounting where the clutch slave bolts to these usually break off in an accident.
Old Sep 21st, 2007, 04:34 PM   #9 (permalink)
flatland69
Sweet, will do! Hope it's all ok...
Old Sep 21st, 2007, 05:10 PM   #10 (permalink)
flatland69
Dude this guy sounds a bit dodgey, he can't give me a straight answer about this gearbox regarding where it came from...is there any way I can check it while it's on the floor? For bearings synchros etc that its all fine? Damn, I was so excited
Old Sep 21st, 2007, 05:22 PM   #11 (permalink)
Paul Webster
Not really apart from a visual check of the slave cylinder mounting. has he got all the other bits you need??
Old Sep 21st, 2007, 05:23 PM   #12 (permalink)
JCW_MC
I LOVE MY MINI
JCW_MC's Avatar
Local Time: 10:00 PM
what benifits are there to adding a cooper s gearbox? the one in my cooper is about to soon (i think) and i allways thought the cooper could do with another gear but i never thought you could put a cooper s gearbox on a cooper engine. but this would definatly be a great option. do 1320 do this service themselves?
Northern Ireland Male   Reply With Quote
Old Sep 21st, 2007, 06:05 PM   #13 (permalink)
Paul Webster
Yes we do, see this thread
http://www.mini2.com/forum/engine-dr...-feedback.html
Old Sep 22nd, 2007, 07:04 AM   #14 (permalink)
flatland69
Nope, he just has the gearbox, and that's what's so odd- why does he just have a gearbox? I'm worried it's one that's been replaced and now he's trying to make a few bucks off me...
Old Sep 22nd, 2007, 07:08 AM   #15 (permalink)
Paul Webster
At that price I would have it just for the casing
Old Sep 22nd, 2007, 01:18 PM   #16 (permalink)
flatland69
Perhaps I should just get it, and if I need to repair it it will probably still be worth it?
6 Speed Gearbox Conversion - Feedback MarsLandingParty Engine & Drivetrain Tuning 11 Dec 27th, 2007 12:54 PM
PDA Sat Nav + Speed Camra Detector. Questions. Phrozen Interior & Ice 3 Oct 13th, 2004 09:10 PM
This is one for the experts to answer, 5 speed or 6 speed with supercharger... eddie_DV52_CCZ Engine & Drivetrain Tuning 4 Jan 21st, 2004 12:43 AM
MCS 6 speed vs OneD 6 speed bigbaddaboom Engine & Drivetrain Tuning 9 Aug 15th, 2003 11:43 AM
5 speed vs: 6 speed design bondobob General Discussion 3 Nov 25th, 2002 03:04 PM
