| Tags: manifold |
| MINI2 Regular | manifold fitting has any one fitted an exhaust manifold on a gen 1 coopers. If so is it diffcult & can it be done on axle stands |
![]() Obsessive Car Cleaner OCC | It can be done but its gotta be done on the highest setting on axle stands, out of 5 i would say its a 3 for difficulty, 1, remove the heat sheild under the bonnet above the manifold. 2, undo the 8 bolts on the manifold 3, jack up high as possible 4, take the heat sheilding off around the cat area 5, remove the 2 sensors on the manifold 6, undo the 2 bolts on the cat, this is were it got difficult for me, it was that tight and rusted i snapped a bolt had to heat it up with oxy, acetalene and knock the snaped bolt off and replace then heat the other bolt up to remove it. The hardest areas i thought were removing the Manifold from the bottom of the car as it very tight and lining the holes up when replacing, ohh and the snapped bolt. Scott |
| Fitting manifold? | minioneandrew | Engine & Drivetrain Tuning | 24 | Mar 4th, 2007 01:50 PM |
| Fitting GTT Manifold Help !! | blaze1235 | Engine & Drivetrain Tuning | 11 | Nov 14th, 2006 10:13 PM |
| manifold fitting | A13EX F Cooper S | Engine & Drivetrain Tuning | 6 | Aug 14th, 2006 03:39 AM |
| Manifold Fitting? | TallAndy | Engine & Drivetrain Tuning | 5 | Jan 9th, 2006 12:11 PM |
| Fitting New Manifold and Exhaust | thesupermario69 | Engine & Drivetrain Tuning | 2 | Jul 2nd, 2004 11:07 PM |
