Tags: , , , ,
Old Oct 10th, 2007, 09:12 AM   #1
Babes
Cruising In The Minge
Babes's Avatar
Local Time: 05:59 AM
Custom Unichip - My results
Ok a few folks have been asking about my custom unichip install and the following are the results.
Firstly let me say take the dyno numbers with a pinch of salt, just look at the percentages. As there is no standard for dyno's results vary widely and alot of arguments ensue.
The place I had the unichip installed says he has probably the lowest dyno in all of Western Australia. He says he could move a sensor here or put in a correction factor there but it's percentage gain he is looking at. Recently Perth Street Car mag sent the same car to 6 dynos on the same day, the results varied from where i had mine done as the lowest to a staggering 100whp more at another dyno. On to the results!
First time dynoed was about 3 years ago at the same place as a stock standard 200bhp JCW. The result was 124whp
Let the modding begin:
17% Alta V2
GTT intercooler
GTT snoot boots
GTT Oil catch can
GTT expansion tank
GTT power steering resevoir
GTT oil cap
GTT dipstick
GTT air filter
GTT twin bearing idle pulley
JCW airbox with butterfly flap removed
Alta air inatke tube
X force headers
JCW exhaust with resonator removed
Alta radiator hose kit
Screamin deamon coil
Nology hotwires
MTH map - was made when i had JCW pulley and 3% crank pulley. Was told no need for updated map to run stock CP and 17% SC as no difference.
Dyno result before unichip 134whp
Dyno result after custom unichip map 160whp, which equates to 20%whp gain. Like i said, forget what the whp figures are as i can go to another which will read 100whp more than this one, look at the percentage.
I can say there is a huge noticable difference and well worth the A$1450. The MTH map was ok for the price back when i got it for $490 and supposed free upgrades for a year, now with their current price i would highly recommend going a customised map for slightly more.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
1970 BRG/W MK2 Morris Cooper S
Australia Male View Babes's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 10th, 2007, 09:23 AM   #2 (permalink)
Lucky Dave
Thinking Minis
Local Time: 08:59 PM
Im surprised you needed a map at all, the JCW 210 map is quite suited to more mods.
How did you get the alto air intake tube on the JCW airbox as its a different size?
Either way I bet it drives much better now! Do you have any flat spots or hesitations at around 3000 rpm under half load / trailing throttle ?
For All Your Mini's Needs
01905 620011
Old Oct 10th, 2007, 09:24 AM   #3 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Babes, I reckon you had an airleak or other simple fault (such as a clamp fitted out of position on the intercooler bellows ). If the Unichip dealer spots this and refits the clamp correctly (takes 2 minutes) this alone would gain 20 horsepower. The pre unichip power is so low that this or similar must be the case. I wouldnt have thought the mth map would be any worse than stock .-Still its running well now
Old Oct 10th, 2007, 10:04 AM   #4 (permalink)
Babes
Babes's Avatar
Lucky Dave yes I did have a stumble at 3000rpm which was at WOT and only happened 50% of the time, went in to refit the flap at the back of airbox as the dealer thought this might be the cause.
When i got there we could not get it to do it for the life of us, he had just reset the ecu as I had asked him to check all the fault codes and give it a once over as i was doing a 1500km drive that weekend so maybe that sorted it. Dont really know though, just happy it has stopped.
Air intake tube was a bit of a drama, dealer said it wouldnt fit but went to a MINI2 members house who had fitted one himself and it popped on no worries at all. He is also going to do the bypass valve mod for me too.
Roland not sure what the go was, car certainly seemed to drive very well before the unichip, was just wanting to get the very best tune i could. Just rang him and he says he did nothing but the chip which required a bit of wiring, didnt move any clamps around the intercooler so who knows.
As the title of the thread says this is my results, maybe not everyone will have the same results unless they wear red undies and hold their mouth just right on the day!
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Oct 10th, 2007, 10:08 AM   #5 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Was the rev limit changed also? At what revs does the engine reach peak HP before and after? Like Roland I still believe there was a fault of some kind beforehand which possibly was over fuelling if nothing was touched in the engine bay before and after. Also during a remap the fuel compensation memory is pretty much always wiped like in an ECU reset which might have helped. Glad its running as it should now though and you can enjoy it to its full as it should be
Old Oct 10th, 2007, 10:12 AM   #6 (permalink)
Paul Webster
Paul Webster's Avatar
I thought you guys measured in KW?
Enjoy your new found power
It's not how much you spend but how well you spend it
Old Oct 10th, 2007, 10:14 AM   #7 (permalink)
Babes
Babes's Avatar
No change to the rev limit, yeah whatever the pre chip story was it is much better now and would not have found the difference had I not gone the custom map.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Oct 13th, 2007, 02:17 PM   #8 (permalink)
Lucky Dave
Thinking Minis
Are you sure the bypass valve was not checked when the unchip was done? 20bhp is a lot!
01905 620011
Old Oct 15th, 2007, 12:43 AM   #9 (permalink)
Babes
Babes's Avatar
yes but not impossible gains if you read http://www.mini2.com/forum/engine-dr...ml#post3186197
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Oct 15th, 2007, 01:46 AM   #10 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Local Time: 07:59 AM
Good on you Babes, great that you got a good result.
The Unichip was shizen on my old Mk4 GTI, but I suspect that was more to do with the Tuner than the product itself. 2bobmcs has been running a Unichip piggyback for a couple of years now.
Cheers Liam
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 4th, 2007, 07:08 AM   #11 (permalink)
Babes
Babes's Avatar
UPDATE
Unichip removed from the car today. It was brilliant when first installed but gradually over the weeks various fault codes were thrown and it got to the stage as soon as the car came on boost it would just backfire and die.
Spent 2 hours on the dyno and the tuner could not work out what the problem is. They have sent the unichip back for fault testing but i have the feeling it will come back as working perfectly apparently.
Car runs sooo much better with it off though still misses slightly at WOT. Im having the 210JCW map reflashed tomorrow so hoping that sorts everything out.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Dec 4th, 2007, 01:35 PM   #12 (permalink)
Revolution Mini Works
Mini2 Sponsor & Tuner
Local Time: 12:59 PM
Quote: Originally Posted by Babes (original)
UPDATE
sorry to hear about that
we have seen this over and over with the Unichip and that is why we remap the ecu with our software program as it uses the ecu to make the changes. We have seen the Unichip go back to stock in a very short time as the ecu learns its way around the changes
Manufacturer and Custom Mini Tuning
Old Jul 13th, 2008, 07:29 AM   #13 (permalink)
Babes
Babes's Avatar
Update:
The unichip is back on and has been running great for the last 2 months. Previous problems were as a result of nology hotwires. I still run the MTH map too which gives me the higher redline and less intrusive traction control.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Jul 13th, 2008, 01:47 PM   #14 (permalink)
D-MAN
Update:
Glad to hear it is now working well
On a side note I have found most stock JCW cars on Aussie dynos will be around the 120kW mark... the dynos down under tend to read lower (at least 10-15%) than overseas dynos - don't know why!
160kW on an Aussie dyno is some serious power!
Australia   Reply With Quote
Old Jul 14th, 2008, 10:04 AM   #15 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Hi,
If you go back to the first post it is actually 160 wheel horse power, which is around 120kw at the wheels
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 14th, 2008, 11:26 AM   #16 (permalink)
D-MAN
Quote: Originally Posted by robbo mcs (original)
Hi,
Robbo
I think I need to start wearing my glasses a bit more...
Old Jul 19th, 2008, 11:50 PM   #17 (permalink)
Thumper460
United-States OK.. 6 months later....
How is the car running now??? I suggest you pm D-Man and see what his results are after a ported Head!! I gotta make it to Austrailia soon... that place seems to rock!!
Just me..............................
Thumper
Old Jul 20th, 2008, 08:35 AM   #18 (permalink)
Babes
Babes's Avatar
The car runs superb. As I said in my original post I dont go in much for what dyno/RR claim as whp or bhp. In Australia there is no standard for them, all have different set ups so I look at percentages gained and the gain was brilliant.
A few doubters among the folk on here, quite frankly i dont care what they think. I have done the RR for my own piece of mind and the gains were there. I have nothing to prove.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old Jul 20th, 2008, 09:10 AM   #19 (permalink)
D-MAN
I agree, I think a lot of people get caught up in the whole hp mine is bigger than yours thing... the main thing is how the car drives!
The gains you got are impressive.
Glad to hear it all has worked out
Unichip on CVT ? Shep CVT & Automatic 0 Jun 19th, 2006 03:52 PM
Unichip MNIMGK Engine & Drivetrain Tuning 5 May 3rd, 2006 04:27 PM
Mcs Mth Dyno Results GeoffMM Engine & Drivetrain Tuning 31 Oct 25th, 2005 09:22 PM
MTH or Unichip Francesco Engine & Drivetrain Tuning 2 Aug 24th, 2005 03:35 PM
MTH Cartune Vs. UNIchip Hartge Engine & Drivetrain Tuning 16 Sep 2nd, 2004 08:40 PM
