Visit Lohen!
Old Oct 17th, 2007, 04:59 PM   #1
redmachine
Local Time: 09:03 PM
Performance after oil change?
Just had an oil change on my 44k Cooper - cant believe the difference!
Driving it home it felt like that had put a new engine in, never mind new oil!
Is it normal to get such a nippier, more responsive car after an oil change? Even sat in traffic the whole car sounded much happier.
Old Oct 17th, 2007, 05:50 PM   #2 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Should sound smoother and less tapping but better performance... hmmm if the oil is really bad beforehand I guess.
Hope you have checked the oil level as dealers are totally rubbish at measuring oil.
Old Oct 17th, 2007, 06:03 PM   #3 (permalink)
redmachine
Thanks I go check it later!
Old Oct 17th, 2007, 07:03 PM   #4 (permalink)
adamos o3,cooper s
Local Time: 10:03 PM
Change The Air Filter
Old Oct 17th, 2007, 07:09 PM   #5 (permalink)
redmachine
The "micro filter" is done as part of the oil service - is that what you mean?
Or has the filter change caused the up in performance?
Old Oct 17th, 2007, 08:00 PM   #6 (permalink)
MINI-Morgan
MINI Obsessed...
If it was really dirty then almost defiantly you will see a performance boost on a brand new one.
Old Oct 18th, 2007, 04:18 PM   #7 (permalink)
Ant FR
is it possible just that pyschologic effect. ie mine always feels quicker after i have cleaned, if you know what i mean.
Old Oct 18th, 2007, 04:24 PM   #8 (permalink)
85NIXMIN
MINI on the brain!!!
85NIXMIN's Avatar
Local Time: 07:03 AM
same here!!!!!!!!! and I thought I was being silly... haha
If the world didn't suck we'd all fall off!
Australia Female View 85NIXMIN's Cosmos Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 21st, 2007, 04:38 PM   #9 (permalink)
NeuroBeaker
Must.. keep... smiling...
NeuroBeaker's Avatar
I had the same thing... I don't think it's a psychological difference, I think it's real. The engine seems to rev more freely after an oil change!
NeuroBeaker - Proud owner of "Zeus" (a 'slightly modified' 2004 MINI ONE).
*WARNING!* Thesis writing in progress. Experiments continue. Multi-tasking? Explosion imminent!
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Oct 21st, 2007, 08:41 PM   #10 (permalink)
MINI-Morgan
MINI Obsessed...
Me too! I thought it was less drag from dirty paintwork and water on the intercooler
Old Oct 22nd, 2007, 06:55 AM   #11 (permalink)
Dave Elliott
Dave Elliott's Avatar
Local Time: 05:03 AM
I gave my 2002 S a new oil filter, air-filter and oil & spark plug change about a month ago.
It too seemed a lot more responsive however I had put it down to the new air filter (however the old did not seem dirty at all).
I had also changed from OEM spark plugs to NGK Iridium.
I bought the S secondhand so I don't know what type of oil was used for its previous oil change. It's possible it was a higher viscosity than is recommended.
I used Castrol Edge 0W40. The engine starts quieter in the mornings (used to have slight valve train noise before).
It's definitely a different car after the service, however I still have cold start problems. I was hoping the Iridiums would cure the "only starts after 2nd turn of key problem", but they had no effect.
Cheers,
Dave
Australia Male View Dave Elliott's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Oil Pressure Light After Oil Change tpwmini Engine & Drivetrain Tuning 6 Apr 20th, 2005 03:50 PM
Oil Pressure Light after Oil Change tpwmini Faults & Fixes 0 Apr 16th, 2005 04:46 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 05:20 PM
oil cooler-Does it drain when when having oil change? yorobby MINI Cooper S 4 Sep 29th, 2004 01:00 AM
First oil change> Do I have to drain oil cooler ? yorobby Maintenance & MINI Care 3 Sep 26th, 2002 08:44 PM
