Think Mini
Tags: , ,
Old Oct 17th, 2007, 08:16 PM   #1
Mess
Go Go Gadget Mini
Mess's Avatar
Local Time: 08:57 PM
Online
DIY Change Spark Plugs
Hi, Ive just got some new Iridium spark plugs (BKR7EIX) and wanting to change them over the weekend.
I want to know is it just a simple case of pulling the old out and in with the new? Or do i need a degree in mechanics and spark plug development & history? Do they need Gapping? and i dont have a socket set so can i do it with a simple spanner?
Also what do these pictures mean on the side of 1 of the plug boxes? No.2 in particular.
United Kingdom Male View Mess's Astro Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 17th, 2007, 09:49 PM   #2 (permalink)
Buz999
What mod next?
Buz999's Avatar
Its a simple job but impossible for you and your spanner as you will need a plug socket!
England Male View Buz999's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 17th, 2007, 10:08 PM   #3 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
so if i get a plug socket is it then just a case of taking the others out and put the new 1 in, 1 at a time?
Old Oct 17th, 2007, 10:46 PM   #4 (permalink)
AlexBRGCooper
British Racing Dirt
AlexBRGCooper's Avatar
Online
Yup one at a time. The rubber HT lead cover pulls off with a bit of persuasion. You'll need a 16mm socket. I've got one if you want to wait a couple of weeks to borrow it? If you can't wait one will set you back about £15
edit - put them back in hand tight and nip about 1/16th of a turn. I think its 22nm if you have a torque wrench
Scotland Male View AlexBRGCooper's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 18th, 2007, 09:35 AM   #5 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi Guys, check out the next edition of Modern Mini mag. There's a GTT guide to fitting plugs in there, with pics.
Old Oct 18th, 2007, 11:17 AM   #6 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Yep its a simple 1 replaces one job out of the box (well my NGK irridium range 7 ones were) The gap out of the box was so close to the haynes manual measurements I didn't change the gap.
Old Oct 18th, 2007, 11:24 AM   #7 (permalink)
roland2003
The 3 things 9/10 people forget to do are:-
1) Tighten them up sufficiently (They undo & strip the threads if you dont)
2) Copper slip the threads (they sieze in the head if you dont)
3) Use Dielectric grease on the nipple. (without it the leads are impossible to remove if left a long time ...can end in the connector at the end of the lead breaking off and leaving it behind on the plug)
Simple jobs done incorrectly can cause major expensive problems.
Best Regards Roland GTT
Old Oct 18th, 2007, 01:05 PM   #8 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Rolland what do you mean by cooper slip the threads?
Sorry for all the questions but id rather learn how to do this my self rather than pay someone 60 quid to do it.
Old Oct 18th, 2007, 01:13 PM   #9 (permalink)
AlexBRGCooper
British Racing Dirt
Online
Does what it says on the tin! I've got some of this as well.
Get an old paintbrush [or your fingers] and run it around the thread before you put the plug in. I've never used grease on nipple [rhubarb] so there's something I've learned.
Old Oct 18th, 2007, 02:10 PM   #10 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Alex can i come to yours and borrow your tool shed?
Old Oct 18th, 2007, 04:25 PM   #11 (permalink)
AlexBRGCooper
British Racing Dirt
Online
My boot is my tool shed! It goes where I go, like some kind of new age traveller
its also probably why I'm the slowest out on runs as my car weighs twice as much as everyone elses
Old Oct 21st, 2007, 03:59 PM   #12 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Thumbs up
lol that might explain the speed issue
Got them changed on Saturday. A big thank you to Marcy for the help.
What a change in the drive of the car with them changed. Better fuel consumption. Gone from a measly 30mpg to a massive 35-37mpg, depending on how heavy my foot is. And if i took it easier im sure it will go higher still.
Car is smoother to drive aswell, it seems to pull better when my foot goes down and accelerates easier. A real good change.
Would recommend changing the plugs to any one now.
Old Oct 30th, 2007, 04:18 PM   #13 (permalink)
MINIdriver85
Local Time: 09:57 PM
I was wondering...on a modded MINI ONE, would you get oem spark plugs or would you recommend something different?
Take into account that I'm going to fit sport manifold, complete cat-back exhaust, Gruppe M airbox, Shrick cams, ported head (possibly with larger exhaust valves) and obviously a remap.
Italy   Reply With Quote
Old Oct 30th, 2007, 04:29 PM   #14 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
With those engine mods i deffo recommend changing to the iridium plugs. they will then be able to cope with the extra heat generated in your engine more easily.
Old Oct 30th, 2007, 04:34 PM   #15 (permalink)
MINIdriver85
Thanks for the suggestion, I'll keep it in mind for when I fit these things on my engine (not all together, but still...)
Spark Plugs texas Engine & Drivetrain Tuning 27 Oct 18th, 2006 02:13 AM
Which spark Plugs? DWS MINI Cooper S 1 Jul 18th, 2006 11:57 PM
Spark Plugs? G-Man Engine & Drivetrain Tuning 5 Sep 16th, 2005 03:55 PM
Spark Plugs venox22 Engine & Drivetrain Tuning 2 Jun 24th, 2005 03:43 PM
Change spark plugs after pulley? Faat Engine & Drivetrain Tuning 10 May 20th, 2004 01:23 PM
