| Tags: engine tuning |
| MINI2 Newbie Join Date: Oct 2007 Local Time: 09:59 PM
Offline | Flat mini !!!!! Hi guys & girls finally found a great website dedicated to the mini!! woohoo. I have a slight problem though with my 2004 mini cooper. It has the 1.6 litre crysler neon engine in and is totally standard. When driving it from a standing still nothing much happens until 3800rpm !!! it seems pretty flat from 900rpm (idle) to 3800rpm. I have had it checked out by a main dealer and no faults were found, i decided on a second opinion, again another garage had it for 3 days and found nothing!!! I have been told a superchip will give 6-8bhp more but it wont really do much for the flat spot im feeling. An induction kit apparently would make matters worse! Does anyone have any advice of how to overcome this problem. I dont mind spending £300 on it but dont want to start going too mad. Its a shame it has this problem as its a superb car. Looking forward to your help guys and girls Andy ![]() |
| Trained Monkey | It's hard to comment really, if two garages have tested it all and everything checks out, who's to say what's the problem? The Cooper engine doesn't really kick in until about the 4k rev range as you mention, basically that's where the Cooper engine is different to the MINI One, the MINI One carries on pretty much in a steady line where as the Cooper has extra "oomph" higher up the rev range. It shouldn't feel totally flat before then, but it's not a super sports car, so maybe it's your expectations not the car that aren't quite where they should be? The first thing I would do was to get driving at least one other example of a first generation Cooper to see how it feels back to back compared to yours. Then you'll know for sure if yours is poor or if that's just the nature of the beast. If you want more "zip" then there's plenty you can do, but if your car is "pre facelift" (ie built before July 2004) you've got to be careful of the gearbox which is (allegedly) made mostly from straw and chewing gum. Our trials and tribulations living in a "bleeding edge" eco house... Oxley Woods Living |
Offline | thanks paul i shall try it against another cooper of the same reg. What can i do for more zip without going stupid? It may be, as you say more of my expectations as this is my girlfriends car i own something which is turbocharged so maybe i should accept it is a naturally aspirated car!?!?! Andy |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 08:59 PM
Offline | You're experiencing a lack of torque which your turbo car will have whatever it is, weight is another thing that a lot of people assume that the Mini has a lack off but it hasn't, also depending on the extras your girlfriends car has this will add to the weight and effect the power -weight ratio. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
Offline | 1 Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it Last edited by Paul Webster : Oct 20th, 2007 at 03:43 PM. Reason: sorry wrong thread |
| | #7 (permalink) |
Offline | i appreciate all your replies guys thanks i think ihave resigned myself to that fact that the mini is not so mini hahaha, so like you say its a hot of different things power, weight, revs etc etc Cheers |
| | #8 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 08:59 PM
Offline | Get a Cooper S instead If you are still really worried about it try a rolling road to see what you power curve looks like. The Cooper however like all NA cars needs to be rev'ed to the power band before you get any real acceleration. |
| | #9 (permalink) |
![]() Some have THICK skins!!!! | It really does make a huge difference what fuel you put in. ALWAYS go for high octane unleaded, this will help give you better pulling lower down than normal or heaven forbid cheapo supermarket fuel. Recently I have had to use the cheapo Tesco 99 ron fuel but yesterday I made a special trip to my nearest shell garage for v power - the difference was instantly noticeable - and my car has always had the higher ron petrol from new. If your girlfirends hasn't it will make a difference. I always say that it depends how you drive the car too. After a good run and a bit of a thrashing the car always performs better - the ecu leans your driving style and adjusts accordingly. So after a few weeks of just commuter driving etc I can feel my car get slow. I take it out for a thrashing (all legal speeds of course - just keeping the revs up the high end and having a ball) and the next day the car is back to normal. Have a go at both of those and you will get the MINI hahaha feeling ![]() and don't believe all these S drivers - if you work a Cooper properly I have em struggling to keep up with me ![]() ![]() |
| | #10 (permalink) |
Offline | Ahem Tesco 99 is the best commercial petrol on the market for modified cars and nothing cheap about it. If its making your Cooper Slower than its more likely that it isnt burning the ethanol properly and higher octane doesnt always mean more power. |
| | #11 (permalink) |
Offline | MINISOOPERCOOPER i just went to fill my GF cooper up at shell using vpower... YOU WERE RIGHT, im never using the supermarket stuff again!! the car does seem a lil more responsive lower down. MINI MORGAN: my father runs a chain of garages and has 40+ years experience nothing faulty found at all, mechanically or electronically full ecu test and software update!! It also went on a piece of tuning equipment too, checking various things plus had it on the rollers!! again nothing. Having put vpower petrol in my girlfriends car im seriously satisfied with what the mini is doing now, dont get me wrong its not in yer face but it has certtainly helped rid the car of the flat spot somewhat!! I was told by a reputable mini dealer that changing up to the cooper s will give me more ooomf but with only 167bhp its still not mind blowing like a supercharged car should be then again its only for my gf to pootle around in, it does 2000 miles a year really!!! Only time it gets used is when i get in it and thrash it a lil hahaha Cheers guys |
| | #13 (permalink) |
| MINI2 Master Join Date: May 2006 Location: Over 4.5k RPM Local Time: 08:59 PM
Offline | Had a Cooper the power band is between 4 - 6.5k RPM. There is a falt spot around 3.5 from what I can remember. Get a 'Works sound kit' from a dealer. Takes out flat spots and raises the limiter to 7,200Rpm. Consists of exhaust, new air intake (filter, pipe and box) and a remap for around £650. Plus keeps your warranty which is important as I found out. OR get a S Check air filter incase its dirty, and new spark plug. Cheaper alternative |
| | #15 (permalink) |
| Sing-a-long MINIer Join Date: Jan 2004 Location: Hampshire Local Time: 08:59 PM
Offline | Best to point out that the sound kit doesn't give any more power (realistically you may achieve 3bhp more with it on), but as you say it does iron out the flat spots with the remap ![]() ![]() |
| | #16 (permalink) |
Offline | I didnt mention faulty? Nothing has to be wrong for it to perform less..... If you only count hp then you missed the point of the supercharger altogether. At the end of the day enjoying what you drive and having fun is whats most important really ![]() |
| | #19 (permalink) |
Offline | The last bit i agree with totally hence why i drive a veedub golf mk4 289.2bhp and 327lbsft and its a diesel no smoke !! Im staying with the v power on her mini as she is very happy with how it feels now, personally i think she is just agreeing with me. But it has made a difference so for 5p per litre more i get a too lol cheers for all your help guys |
| Run Flat v's Non Run Flat.....Ride Quality | Mini Soph | Wheels, Tyres & Brakes | 84 | Oct 17th, 2006 07:23 PM |
| towing MINI on a flat bed? | Toddodie | General Discussion | 3 | Jan 29th, 2006 11:53 PM |
| Flat Towing Mini-- does mileage accrue? | flibmeister | General Discussion | 3 | Jan 11th, 2005 04:15 PM |
| Do I have a flat or is it low pressure???? (run-flat related) | cspuryear | Wheels, Tyres & Brakes | 1 | Feb 22nd, 2004 04:58 PM |
| flat towing a mini | groeshl | General Discussion | 1 | Apr 24th, 2003 12:18 PM |
