| Tags: help me |
| MINI2 Regular | Blow Off Valve? Can anyone tell me if you could fit a blow off valve to a MCS?? if you can how do you do it?? |
| MINI2 Master | you can do it on an R53, but is a bugger to get it set up, as technically thats what the bypass walve is and it sounds ****. loads of the G60 boys do it on their golfs and corados. But there would be no gain so ultimately no point. Try ebay for an elctric dump valve, if you are that desperate for the sound. Even on the R56 it sounds crap. |
| | #7 (permalink) |
| MINI2 Regular | No hes after an actual dump valve, which can only be fitted to turbocharged cars, the noise when coming off the throttle is the realease of built up air pressure outside the engine because the turbine still spins using momentum which cant go inside the engine because of the closed throttle. r56's are turbos so you can fit bovs to them |
| BOV aka. Blow-Off Valve? | burack | 2nd Gen Engine & Drivetrain Tuning | 3 | May 8th, 2007 09:36 AM |
| blow off valve on copper s | beef | Engine & Drivetrain Tuning | 17 | Jul 19th, 2005 10:32 PM |
| blow off valve on cooper s? | djscooby | MINI Cooper S | 11 | Sep 15th, 2004 04:18 AM |
| Blow Off Valve? | DFL18 | Engine & Drivetrain Tuning | 2 | Jan 13th, 2003 07:14 PM |
| Supercharger Blow-off valve? ::: | Badtz | Engine & Drivetrain Tuning | 13 | Aug 22nd, 2002 02:44 AM |
