| Tags: gtt, jcm, jcw, minimotorsport centre |
| | #41 |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 08:56 PM
Offline | Hi guys, just an observation regarding 30-70 times Ive made over the past few weeks. Early gearbox is about 0.5-0.6 seconds slower than a late car with its lower gearing. (based on a selection of cars with 220 ish bhp). Also remmember to mash the gas at 20mph and start the clock at 30mph like 1320 do. Best Regards Roland GTT ![]() |
| | #45 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 08:56 PM
Offline | Theres a few people recomending mods for Snowie, I think they have missed the point. Snowie is looking to keep the engine bay as standard as possible. Thats why he still runs a works airbox and GP intercooler. Now the Works box with GTT hybrid is actually very good IMO. Plus Snowie says that he is finding the GP IC pretty reasonable to...I am running a GP IC on my -15% car with modded bypass valve and the inlet and outlet horns on my car are bloody ice cold even on milder days, especially after fitting a modified M7 hoodscoop! My Stock IC would be hot beyond belief after only a few minutes even on a cold day! Thus Snowie is unlikely to be loosing much there, his main issue is probably that very high BP reading off the JCW exhaust....Custom all the way to the rear is probably the only thing to do and have powerflow weld the JCW final piece onto the custom sections nearer the front, or get them to do something totally custom that can still have the JCW tails fitted onto it. |
| | #46 (permalink) |
| MINI2 Senior | I agree to certain extent ... but if you have changed as much as Snowie has i.e. head, manifold, etc you may as well change the IC (if there is benefit to be had over the GP IC; which I cannot confirm) as its easily changed back for the stock look ![]() Snowie mentioned that he was going to try another IC during Saturday's rolling road session; I think we'll get our answer then. My money is still on the exhaust ![]() GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road |
| | #48 (permalink) |
![]() MINI2 Master Join Date: Aug 2006 Location: Modena IT /Camberley Local Time: 09:56 PM
Offline | Under investigation as there are a couple of issues - Having the JCM Mainifold and sports cat repostions everything before the flat Y piece backwards by about 600 mm Miltek is larger bore than JCW In Italy |
| | #49 (permalink) |
| MINI2 Master Join Date: Apr 2005 Location: Watford, Herts. UK Local Time: 08:56 PM
Offline | I see from your opening post that between dyno run 3 and 4, you had something called AFPR fitted. Can you tell me what these letters stand for , what AFPR actually does. Thanks. |
| | #52 (permalink) |
| MINI2 Newbie Join Date: Nov 2007 Local Time: 09:56 PM
Offline | Hi guys. Since its a pretty simple job, couldn't one of the GRS owners simply swap IC's with the GP owner and do a run before and after? This would be one way to settle it! I also think the fuel air ratio is too rich going by your dyno chart print out (says the man with a dirty jap car that runs rich as you like! ) so a custom remap could help out here.Have you checked your timing too? With that much fuel there might be room for a bit of advance to gain you a few more bhp. Very good work on the stage by stage mods though mate, well done! |
| | #54 (permalink) |
Offline | I think Alans car may benrfit from a bit more advance. Remmembe fuelling will be richer on the RR than on a real road. You need to set up fuelling & ignition on the road. Best Regrds Roland GTT ![]() |
| | #55 (permalink) |
| 230whp an counting Join Date: May 2002 Location: Mini Addiction Local Time: 08:56 PM
Offline | Thats funny when i was talking to one of the big jap specialists recently they said they dont bother setting up on the road only on their Dyna pack now??? An these guys setup 600 + HP skylines etc |
| | #56 (permalink) |
| Thinking Minis | Having just been on the dyno today and then on the road I can 100% confirm the fueling will be different for each. On the rollers my A/F was up and down all over the place, but on the real road its as smooth as you like! As with all things tuning wise, we will never stop and the car will never be finished! so for now im tuning for winter! For All Your Mini's Needs ![]() 01905 620011 |
| | #59 (permalink) |
Offline | Snowie is very happy Just come back in from Surrey Dyno day using the same RR as I have used for all mods. Today was B..... Cold so ideal for RR sessions Max 251.8 BHP with 211.7 at the wheels 4 runs all within 1 BHP Same power results with both GP and GRS intercoolers Boost is up with GRS cooler, this is also noticeable on the road as traction control trips in 3rd with GRS but with GP only does this in 4th. Also verified with the boost gauge - if you can keep your eye on it whilst giving the car a good blast and hanging on to the wheel On such a cold day no measureable differenece in BHP but most likely on a hot day the GRS IC will be better than the GP IC I will update the first post with runs 6 and 7 later tonight Alan In Italy |
| Tuning ? | omy | Engine & Drivetrain Tuning | 4 | Mar 27th, 2005 07:27 AM |
| BBR or West Tuning or GT Tuning? | spillers | Engine & Drivetrain Tuning | 81 | Nov 16th, 2004 07:49 PM |
| Tuning the S | Liono | Engine & Drivetrain Tuning | 2 | Oct 21st, 2003 06:34 PM |
| Tuning. | anthonyyule | Engine & Drivetrain Tuning | 3 | May 31st, 2003 12:07 AM |
