| Tags: stuttering jcw |
| MINI2 Regular | JCW 210 stuttering I just picked up my car after having the JCW 210 kit fitted. It's awesome - great noise, big power and lovely delivery. However, after a long motorway drive, the engine began to hesitate slightly when I floored it from low revs, anyone else experienced this? It's just a slight stutter, as if something's not right with the tuning or something, is this a normal early conversion gremlin? A quic search suggests it might be the crank case breather hose - could this cause the stuttering I'm experiencing? cheers, Jake Last edited by MINIAC : Dec 12th, 2007 at 11:41 PM. |
| MINI2 Newbie Join Date: Nov 2007 Local Time: 10:03 PM
Offline | The pressure in the crank case will be higher when running more boost so it could be a blocked crank case breather. If the oil vapour cannot escape from the crank case you will end up burning it in the combustion chamber intead. This has the effect of reducing octane and increase the chance of detonation. It could make the car feel stuttery I guess. Did they change the plugs as a part of the upgrade too? |
| MINI2 Regular | cheers for the info Baz, I think it could be the breather as the stuttering is often accompanied by pops from the exhaust. is it still safe to drive if this is the case? if it is the crankcase breather pipe, do I need to replace the pipe or just un-block it? Does anyone have a picture of this pipe or a part number for it? (I have to explain it to the garage in Zurich, where they only speak German!) yes, they did change the plugs as part of the conversion, so I don't think it's a spark problem. Last edited by MadUsa1 : Dec 13th, 2007 at 09:35 AM. Reason: part number |
| | #6 (permalink) |
| Back To My Old Self Join Date: Jun 2006 Location: In The Wind Local Time: 09:03 PM
Offline | A friend has recently had a stumbling problem with their 210 JCW. The scenario was when sitting at 60 or so (about 2700 rpm), then flooring it the car would "stumble" at about 3000rpm. This would happen in any gear. I describe it as a stumble as it felt like a misfire and the car felt as though something had tugged it backwards sharply. It was sometimes very obvious, others a bit more subtle, but always there. A new supercharger valve seems to have sorted it. I will add that this car had just had new plugs/leads but these did not solve the problem in this case. ![]() MODERN MINI OSCARS 2008 - BEST COOPER NOMINEE |
| | #7 (permalink) |
| MINI2 Regular | Hi all, took the car back to BMW yesterday. Quick ten minute drive with the mechanic was enough for him to conclude it was the spark plugs. Got the spark plugs changed under guarantee and sure enough, no more stuttering. Surprising, since the JCW 210 kit comes with new spark plugs - either they weren't changed, they were changed but broke soon after, or they were changed but just happened to be faulty. Either way the car's now running perfectly, just in time for a trackday on friday ![]() |
| Stuttering speedo | DrJ | Faults & Fixes | 6 | Apr 20th, 2005 12:10 PM |
| yoyo / stuttering | notone | Faults & Fixes | 6 | Oct 10th, 2003 06:41 PM |
| stuttering and warning lamps | bebop | Faults & Fixes | 1 | Apr 14th, 2003 06:51 PM |
