Old Dec 30th, 2007, 05:39 PM   #1
MiniNat
Local Time: 09:48 AM
Newbie Question about pulley diameters
Hello everyone, im hoping someone can help me. i need to know the diameter of the crankshaft pulley on the supercharged engine. I need the diameter of the pulley that the supercharger drive belt runs on. (i know that the supercharger pulley is 62mm dia).
thanks for any help you can give. (its for a project im doing at uni)
Nat
Old Dec 31st, 2007, 02:06 AM   #2 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 10:48 AM
Study
Nat
...be sure to remain consistent in your measurements... the pulleys are v-grooved.
I guess its arbitrary though, so just make a value up. I think it is about 5 times greater in diameter so not too far from being around 250mm - 300mm. Both pulleys that you mention come in a number of sizes and i think there must be over 15 or so combinations that you can have.
Alternatively wait for a mechano-geek to provide the exact micrometer reading
Cheers,
K.
Old Dec 31st, 2007, 03:07 PM   #3 (permalink)
Fisher
Local Time: 11:48 AM
Send a message via MSN to Fisher
ratio is 2.07 so you can calculate it.
14.106@103.83 60ft-2.465sec
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 31st, 2007, 04:04 PM   #4 (permalink)
MiniNat
thanks for that Fisher, exaclty what i needed to know, cheers.
Old Dec 31st, 2007, 05:18 PM   #5 (permalink)
Fisher
Sorry I have check it once again and its 2.06 and NO 2.07 (I have said from my head in first reply).
Happy project and new year.
Bye
Old Jan 1st, 2008, 08:02 AM   #6 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
... so based on a 62mm SCharger pulley the crank pulley is 127.72mm (using a ratio of 2.06)
If i run a 15% scharger pulley then it would be 52.7mm and the crank would remain at 127.72mm resulting in a 2.42 ratio.
But i run a 1% oversized crank pulley so this would result in a crank pulley of 128.99mm which means my ratio is 2.45 based on a 15% pulley (values rounded up)
Or is that all wrong?
Cheers,
Albert.
Old Jan 30th, 2008, 06:21 PM   #7 (permalink)
Fisher
Cheers,
Albert.
I have seen somewhere the supercharger pulley is 65.5mm.
Old Jan 31st, 2008, 01:03 PM   #8 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
So my ratio is 2.51. Thats interesting
Oh wait... or is it 2.56 as the GTT Crank is +4mm.
Has anyone done any testing as to what causes less load on the engine between a +1% crank or just getting a smaller SC pulley?
Supercharger Pulley Question (Newbie) Tomato Engine & Drivetrain Tuning 2 May 23rd, 2005 11:57 AM
newbie w/ aftermarket pulley sideshowblah Engine & Drivetrain Tuning 4 May 9th, 2005 08:26 PM
Pulley change - ECU or No ECU upgrade? Newbie needs help, please. lwlam Engine & Drivetrain Tuning 31 Jan 20th, 2005 03:39 PM
FYI : Pulley diameters Boris Engine & Drivetrain Tuning 1 May 15th, 2004 09:21 PM
Newbie question about H/K MP3 HU etc Brett1 Interior & Ice 7 Mar 14th, 2004 05:51 PM
