| Tags: mpg, pulley |
| MINI2 Regular | Fuel consumption with pulleys? Planning on modifying the car slightly: GTT induction kit (already have) Janspeed manifold with decat (already have) Smaller pulley, probably 15% Bigger intercooler Bigger injectors One ball exhaust Should this be good for about 230bhp? My main fear is fuel consumption, im a poor student, drive to uni every day. So fuel is already quite an issue. Will i notice a big decrease in mpg? Also thinking possibly about nitrous (as a kind of a weekend toy), the advantage i can see is that ill only be using lots of fuel when the magic button is pressed? Anyone share some experience with me ![]() Superchargedddddddddd! |
| MINI2 Senior | GTT220+ kit GTT manifold +1% crank pulley Schrick cam 450cc injectors GRS intercooler 63mm throttle body JCW exhaust Flowed & ported head Just recently had an MTH re-map - letting it bed in for now but will get a RR session booked in order to gauge benefits of the re-map. Vroooom Vroooom |
| | #7 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 08:40 AM
Offline | I still getting much better fuel consumption with a modified S. 40+mpg on the motorway and 32mpg around town and by town I mean sloooooow! Al with your mods you should be nearly 250bhp or more. Andrew you might see worse fuel consumption with the larger injectors too. |
| | #8 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 08:40 AM
Offline | Lucky git ... mine is around the 240 per tank with motorway and below 200 with mixed town and A road. But fitting the pulley made virtually no change as this is pretty much what I was getting before |
| | #9 (permalink) |
![]() Obsessive Car Cleaner OCC | Mines pretty much the same as yours Richard, sitting at 70MPH on the A1 was about 31MPG and i have a 210 mile trip from home to work and i usually have around 60 mile in the tank when i get back but the petrol light comes on between 40 - 50 mile left. Around town i average between 190 - 210 per tank full ![]() |
| | #10 (permalink) |
| MINI2 Regular | Aberdeen Al, i would have expected this to be 250 bhp + with that setup, maybe your map will bring it up. Well that sounds promising, im getting excited about getting this done now. Are the larger injectors neccesary? My friend did a 17% and nothing else, and he felt it was leaning out top end.... Thanks for the replys ![]() Superchargedddddddddd! |
| | #11 (permalink) |
Offline | Wow that is really low.... I noticed a big improvement after Roland had done his work. So I can only say the bypass valve must have improved my consumption and I have the modified inlet plenum that was a big test near 2 years ago now. I can easily cruise at 70mph and get 350+miles from a tank and if im super careful nearly 400miles. Even tested it recently when I drove to Essex which was 230miles and only used just over half a tank to do it And im running 215/40 R17 tyres too. Seems to be back to its old self after a nice intercooler clean, MINI-Mania Manifold and a good oil change ![]() |
| | #13 (permalink) |
| my other car is a smart.. | That depends on your boost. If your running a high boost pressure the this open the fuel pressure reg and it happened on mine where the pump could not keep up, and I chose bigger injectors and a lower fuel pressure reg instead of a bigger pump. Lucky is a way of life (tm) 243.5 bhp & 205.3 ft lb |
| | #17 (permalink) |
| Banned Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 08:40 AM
Offline | Dave I would suggest you have other issues, we've seen 356bhp on WOT with grip, so thus good G's force forcing the fuel back as well and still reading low 10s air / fuel ![]() |
| | #18 (permalink) |
| my other car is a smart.. | I never said the pump could not supply enough fuel. Also changing the duration of the injector cycle will not change fuel pressure. The regulator is a mecanical device controlled by boost pressure. In an ideal world the fuel pressure should raise as the boost does. If you raise the boost a lot the fuel reg runs out of head room. I doubt it can be seen on a car fitted with a 15% pulley. Im not here to argue about it, Im offering to share my findings which are backed by data. It became very apparent to me when I fitted a boost gauge next to my fuel pressure gauge, under load the both raise at the same rate, which they have to as the fuel reg is driven by boost pressure. But at around 16-17 psi the boost was still raising but the fuel pressure stalled and sat at pump pressure, even though the boost was asking for more. So dispite the injector duration its rate of delivery will change as the injectors supply rate will change with pressure changes. I hope I have explained correctly? Lucky is a way of life (tm) 243.5 bhp & 205.3 ft lb |
| | #20 (permalink) |
| a.k.a. BrainRush Join Date: Oct 2006 Location: NorCal Local Time: 12:40 AM
Offline | I'm running a 15% pulley, and I just installed a CAI, and from what Ican tell, it seems when I push hard I think I'm getting a little knock ( sounds like a someone tappng a screwdriver in there? I'm kinda new too), but it shouldn't be anything that a colder range of plugs can't fix. Other than that, I think that with an oil catch can I'll be knock free... Mods: |
| Fuel Consumption | tolmie | General Discussion | 22 | Apr 27th, 2007 06:25 PM |
| Fuel consumption and RPM | luVlee | Engine & Drivetrain Tuning | 8 | Feb 9th, 2007 04:04 AM |
| Fuel Consumption | RobHardyUK | MINI Cooper | 8 | Jun 30th, 2004 01:26 PM |
| Best Ever Fuel Consumption....... | Wobert | MINI Cooper S | 15 | Jun 28th, 2004 11:43 AM |
| Fuel Consumption | jcuthell | MINI Cooper S | 81 | Jun 27th, 2003 07:12 PM |
