| Tags: dyno, jcw |
| | #21 |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 12:57 PM
Offline | Not to be too negative but id be very suprised if you hit near 250 with those mods. With a big valve ported head and cams then it will be running very nicely ![]() |
| | #22 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 12:57 PM
Online | 46hp and 37 hp drivetrain loss, you would like to see it more consistant than that otherwise how will you be able to compare? I seem to remember Jan and Brian making 186whp Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #24 (permalink) |
| The Power Cube | Actual / Relative I don't think you can say drive train loss is xx%. It has nothing to do with power does it? The loss you'd experience would be the same for a 100bhp, 200bhp, or 300bhp car. A wheel is a wheel and so forth ![]() I may be wrong... Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| | #28 (permalink) |
| Chasing 295bhp! Join Date: May 2005 Location: Lancashire Local Time: 12:57 PM
Offline | I just wanted before and after figures so I can see what my money has got me after its been to Lohen. This is only for my piece of mind and not for bragging rights As its only for me it doesn't need to be exact does it! GP 1021 |
| | #29 (permalink) |
Offline | So there is a problem with my car? Or the Rolling Road? If there is a problem with my car what could it be? Just so I can get BMW to sort it or at least look at it Im very green to all this as you can probably tell ![]() GP 1021 |
| | #31 (permalink) |
Offline | I look forward to your results Should be a great little toy will all that on...roughly 270bhp maybe but the torque increase is where you are going to feel it most when you stamp on it at 4K rpm ![]() Not sure if you said or not but might be worth added some brake upgrades somewhere. ![]() |
| | #32 (permalink) |
| 230whp an counting Join Date: May 2002 Location: Mini Addiction Local Time: 12:57 PM
Offline | I very much doubt it, just that RR seems to high % wise transmisson loss. Mine lost about 17% on 1320`s RR the last timeit went on BTW the re route pipe wont fit on a JCW exhaust |
| | #35 (permalink) |
Offline | Good good! Wouldnt want you damaging your new new found power. Things certainly come at you much faster and the standard brakes cook very quick.Also track days then become great fun ![]() |
| | #36 (permalink) |
| Team VaVaVoom 2008 | You can't compare 1320's rolling road with the one at TB Turbos. Different models of rolling roads will always give different readings to each other. I read that 1320s is a Hoffmann unit and TBs is a Dastek 4WD unit. I will be getting my new Evo on the rollers at TBs as soon as i get it, to compare with the reading it has on Powerstation's. I've been to TBs rolling road on a number of occasions and it is spot on. We have even had a race car on the rollers and the result was spot on ![]() ![]() 330 BHP + 0-60 in 4.3 Seconds = ![]() ![]() ![]() 2008 Elf Renaultsport Clio Cup Team - I'm looking for sponsors, pm me if interested ![]() |
| | #37 (permalink) |
| MINI2fosi Join Date: Nov 2001 Location: MINItorque.com Local Time: 12:57 PM
Offline | I suspect you may need to invest in some new wheels to then. The daft offset the JCW (including the GP wheels) wheels have of 52, and the little clearence you offer means spacers of 25mm I think. Some 18" ultraleggera's in black with more than likely an 8mm spacer should look very tasty ![]() ![]() |
| | #38 (permalink) |
Offline | I would expect either the percetage to stay the same, or for it to increase in loss as the power went up. The way i was thinking was as the other parts are are under increaseing stresses. But then your right a wheel l will still weigh the same. Taking the 5 off that thread I posted, I know Graham's and Snowie's wheels are light so that would of helped with their percentages. I would not expect the drivetrain loss to be a set figure though (all things being equal) as power went up. I would possiby expect at best that the percentage in oss may decrease slightly but for the drivetrain loss amount (in hp) not to stay constant. But then thats just a guess based on what I 'think' I know lol ![]() ![]() |
| | #40 (permalink) |
| Flying Finn | Where the both runs done on the same gear? I did a couple of runs dyno runs this week. The first run was 213hp/4th gear and the second one 222hp/5th gear. interestingly, on both runs the whp figure was the same: about 190whp. This was on V-Tech Dyno. |
| MCS JCW Dyno results... | sam_a156 | Engine & Drivetrain Tuning | 47 | Feb 7th, 2007 10:41 PM |
| Dyno results - what to do next? | indimini | Engine & Drivetrain Tuning | 14 | May 4th, 2005 05:26 PM |
