| Tags: 15 pulley |
| MINIBUG | Sc Pulley Change - What's Involved When s tuner changes your SC Pulley, what's actually involved in the process ? I hear the engine has to be lifted to get at it, is this correct ? |
| JCW 210 apparently not! Join Date: Feb 2007 Local Time: 09:02 PM
Offline | Yep your correct. you lift the engine, undo the engine mounts and lift the engine. use a pulley removal tool, put un new pulley and ensure its tight. put on new belt to stop slipping, realign the engine and do up mounts. There are several guides over the net, you could also strip the engine from the front and get to it. |
| Lovin' every MINI of it! | 1. Car front end is put on jack stands. 2. Lower skid plate is removed. 3. Airbox/ECU is removed. 4. Various bolts are removed (including the three engine mount bolts. 5. Engine is slowly lifted to gain access to pulley. 6. Belt is removed. 7. Pulley is removed and the new one installed. Reverse the order to put it back together. Pretty simple actually. Global Moderator ![]() |
| | #10 (permalink) |
| Lovin' every MINI of it! | Doing it yourself is easy as long as you have the tools, a little know-how and patience. I do all of our car mech work, but I have been a mechanic for a long time. I was a crew chief in the military for many years. If you are unsure of your abilities, I do recommend Lucky Dave's path... Global Moderator ![]() |
| How do i change the supercharger pulley? | SamR | Engine & Drivetrain Tuning | 7 | Jan 30th, 2007 09:05 AM |
| Reduced Supercharger Pulley - what's involved? | Roofas | Engine & Drivetrain Tuning | 6 | Aug 4th, 2005 10:13 PM |
| Supercharger Pulley Change in Perth | Aldo | Australia | 5 | Jun 28th, 2005 07:29 AM |
| Pulley change - ECU or No ECU upgrade? Newbie needs help, please. | lwlam | Engine & Drivetrain Tuning | 31 | Jan 20th, 2005 04:39 PM |
| Pulley change: how complex it is? | lusomini | Engine & Drivetrain Tuning | 3 | Jun 25th, 2004 09:58 PM |
