| Tags: scangauge readings |
| MINI Profiler Join Date: Feb 2001 Location: City By The Bay Local Time: 04:19 AM
Offline | Utilizing Scangauge Readings Now that I've fitted a Scangauge, I'd like to know how to make the best use of the gauge readings to determine whether there is a problem. VLT (Battery Voltage) The User Manual is pretty clear on this one: WT (Water Temperature) Again from the Users Manual: What coolant temp should you see cruising at highway speeds? MAP (Manifold Absolute Pressure) I know the reading has to be adjusted by subtracting air pressure relative to altitude to determine boost. Do you correlate this reading to TPS (Throttle Position Setting) or LOD (Engine Load) or some other reading to determine if you have a boost leak? IGN (Ignition Timing) Anything to watch for here? |
| Flying Finn | My two pennies: WT - at least during the winter conditions here, it seems to sit at around 87C = 156F MAP - I am only looking at the absolute value of this at WOT and close to red line. I am typically seeing up to 32.5 absolute reading, i.e. 32.5-14.5 = 18 PSI boost (4th gear, WOT, close to redline). I guess you should just figure out the normal amount of boost for your mods (pulley, crank pulley etc) and compare the readings to see if you have a leak. (though I recommend having somebody else in the car - it is a bit hazardous to keep looking at the Scangauge @ WOT, 4th gear and close to redline )IGN - still trying to work this out myself. To my knowledge timing is adjusted e.g. when the intake air temps raise too much. Don't know what kind of readings I should be expecting though. |
| MINI2 Senior Join Date: Dec 2004 Location: Sittard (NL) Local Time: 01:19 PM
Offline | I have the Scangauge too, I look at intake air temperature, water temperature, iginition advance and open/closed loop. It's interesting to see how soon the open loop is engaged. This means that the Oxygen sensor is not regulating the mixture. In open loop the mixture is regulated by internal stored mixture tables. The ignition advance I also didn't work either, but I think the ScanGauge is too slow to capture ignition advance (and MAP) correctly because of the slow OBD protocol. EB/W R53 MCS Highly Modified |
| Scangauge 2 | Rigsey | Engine & Drivetrain Tuning | 107 | May 7th, 2008 08:43 AM |
| Scangauge VS. DashDyno VS. G-Tech | brainycheddar | Interior & Ice | 0 | Dec 13th, 2007 05:29 PM |
| Vacuum readings | obehave | Engine & Drivetrain Tuning | 7 | Jul 1st, 2006 03:07 AM |
| Boost Gauge Readings | LordNikon | Engine & Drivetrain Tuning | 2 | Dec 20th, 2004 03:09 AM |
| What Causes Outside Temp. Readings to Skyrocket? | kshapiro | General Discussion | 14 | Aug 18th, 2002 04:18 AM |
