| Tags: dyno |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 10:29 PM
Offline | My dyno results Been to dyno dynamics today in Leeds and my results are shown on the graphs. Current mods: JCW exhaust JCW air intake GP I/C JCW 380cc injectors Cooler plugs JCW remap 15% pulley and shorter belt Any comments welcome Regards James |
Offline | Bonnet was open for first few runs and was making 195BHP, shut the bonnet and made 203BHP. Intake temp was 27 I thought their fan was very good, but I havent been to any other dyno. I have got sum pics so will post them it I can |
| | #9 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 10:29 PM
Online | When you say the intake temp was 27 deg, was that with a Scanguage 2? If so how many parameters were you monitoring? At a guess I would say that where the power is trailing off is because of the JW map being so rich / high intake temps / timing being retarded / slipping belt. I would do a compression / leakdown check just to make sure everything is a ok.. What was your 1/4 mile time ET and weight? Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #10 (permalink) |
Online | We have so many pulls done on the car I cant honestly remember, but if you consider that when all the air is going through the intercooler thus giving the car a lower IAT the ecu will respond by giving the engine more timing and and thus more power. Also when runs are done in 3rd gear even our software struggles to collect data quick enough. We must rember that JawF430 car hasn't an ex manifold fitted, this will help him out no end in the horsepower stakes. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 IT'S NOT HOW MUCH YOU SPEND BUT HOW WELL YOU SPEND IT |
| | #11 (permalink) |
Offline | I don't have a scangauge the inlet temp was on my dyno print out sheet. Ambient temp was 18. The A/F hit a low at about 10.7 but was around 11.5 average. The pulley belt is due for change as I fitted it around 10000-11000 miles ago. 1/4 mile time into very stong head wind was 14.9@94-95mph weight with me in was 2846lbs (half tank of fuel) I was expecting around 215-225bhp but I didnt dyno the car before I fitted any mods so can't be sure how much gain I actually have Some runs were done in 3rd but the best run of 203bhp was done in 4th even tho the sheet still says 3rd Regards James |
| | #15 (permalink) |
| Blue is the colour! Join Date: Jul 2003 Location: Canberra, Australia Local Time: 07:29 AM
Offline | Same. I'd also like to know their equation for working out the flywheel power figure? My April 04 build MCS dynoed at 106kW in stock trim and then on the same dyno after fitting ALTA CAI, Milltek cat-back, MTH Tuner file and ALTA 15% v1 pulley returned 136kW. In whp, it went from 142 stock -> 182 modded. As you say though, not having a baseline run from the same dyno makes any subsequent results guesswork. Haha, dyno results still leave you with guesswork at the best of times. For example, our Mk5 GTI has been on the dyno in stock trim twice. First result was 149kW at the wheels (200whp) and second result, on a different dyno, was 140kW (188whp). Not a bad drivetrain loss from a car rated at 147kW at the flywheel from factory. It would appear Volkswagen have clearly underquoted their figures. Or at least, it would if other stock GTIs weren't returning results around the 125-130kW mark. Ultimately, in most cases, if your car drives great and you're happy with the performance, a dyno result really only proves how much you can (or can't) brag to your mates. ![]() Cheers Liam |
| | #16 (permalink) |
| Banned | 203bhp is bang on the money using the 1/4 mile time and weight of the car, but I'd be expecting 210-215 bhp at the fly with those mods. As Paul said a leakdown test looks like the best bet as I know from experience that a leaky head can rob you of 10-12bhp easy. With the addition of a better manifold and good leak down results you should be at the 225bhp mark. |
| | #17 (permalink) |
Offline | Yes I used the calculator to work out my bhp and it was bang on, but my 1/4 mile run was done into a very strong head wind so on a calm day I would run a quicker time therefore using the calculator again my bhp would come out more. I was expecting my bhp to be closer to 215-225 as Loui's car ran a 14.7 1/4 mile on the same day as I did my 14.9 and his car is 203whp and about 241bhp, so I didn't think my car would be as much as 38bhp down for 0.2 of a second as the his car weight isn't much heavier than mine. I think I need a leakdown test doing Regards James |
| | #18 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 10:29 PM
Offline | Needs to have the sensor monitored really and I know cause it was registering stupidly high temps on a rolling road (Thanks Paul for spotting). And then testing out on the road it still would be consistantly upto 60+degrees C so the ECU would pull the time and dump more fuel to compensate. All sorted now though ![]() |
| Mcs Mth Dyno Results | GeoffMM | Engine & Drivetrain Tuning | 31 | Oct 25th, 2005 08:22 PM |
| Dyno results - what to do next? | indimini | Engine & Drivetrain Tuning | 14 | May 4th, 2005 05:26 PM |
| dyno results | SMG | Engine & Drivetrain Tuning | 35 | Jun 26th, 2003 12:31 PM |
| MC Dyno results | ddp | Engine & Drivetrain Tuning | 12 | Dec 29th, 2002 10:04 AM |
| Dyno Results | macncheese | Engine & Drivetrain Tuning | 43 | Jul 23rd, 2002 05:43 AM |
