| Tags: inject |
| MINI2 Regular Join Date: Jan 2006 Location: OXFORD Local Time: 09:02 PM
Offline | What size injectors ? Come on guys what size injectors are you running on your MCS, as thinking of going up in size |
| | #7 (permalink) |
| MINI2 Senior Join Date: Jul 2003 Location: Nottinghamshire Local Time: 09:02 PM
Offline | What BBR conversion do you have ? Is it the BBR 220 ? Is so then you have a 19% reduction pulley….. I have this conversion and am using stock, however 380cc injectors would give a better if you plan to run your engine hard (track / high revs) as the standard injectors can lean out at the top end. But with 19% pulley there is no need to rev the car above 6,000 RPM as the all the power (torque) comes in at a lower RPM range. Cheers Perm ![]() |
| | #8 (permalink) |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 09:02 PM
Offline | Don't forget that no matter what the injector, there is an issue on how much fuel can be pushed through by the stock regulator. Bigger injectors alone will not always be the answer. There is a need in high boost cars to get a VFPR fitted to allow even smaller injectors to fuel properly, this can also be true even if running big injectors as the cycle of the injector and diameter of the injector matters not if your boost outstretches the stock 18psi that the standard pressure regulator is matched to! |
| | #10 (permalink) |
Offline | GTT do one, and its proved to be very handy on a few of my mates tuned cars that regularaly hit over 18psi, some run 450cc injectors some 380cc injectors. I even know someone running stock 330s with a higher pressure on a VFPR thats reduces a lot of the lean they were getting. |
| How much? jcw injectors | lucachiarelli | Engine & Drivetrain Tuning | 29 | Oct 10th, 2007 02:17 AM |
| Where to buy JCW injectors? | uncle albert | Engine & Drivetrain Tuning | 2 | Mar 11th, 2007 09:58 AM |
| Injectors | Fisher | Engine & Drivetrain Tuning | 5 | Nov 19th, 2005 02:58 PM |
| What Size Injectors? Decapping? | wrecky | Engine & Drivetrain Tuning | 2 | Aug 29th, 2005 04:38 PM |
| jcw 380 cc injectors | fasteddy | Engine & Drivetrain Tuning | 4 | Jul 14th, 2005 04:16 PM |
