Wipac
Old Jan 23rd, 2008, 01:46 AM   #1
E-Gun
E-Gun's Avatar
Local Time: 08:03 AM
Send a message via ICQ to E-Gun
Watch out when fit header?
Hi guyz,
never fitted header b4, just wondering is there anything i need to watch out when fitting obx header?
Do i need to remove the heat shield ???
Do i need to fit the flex after extrator?
04 MCs Modification Alta version 2 CAI & 17% Supercharge Pulley, Remus cat back, Xenon Headlight, Oil Catch Can, Defi Boost Gauge
Australia   Reply With Quote
Old Jan 23rd, 2008, 10:46 AM   #2 (permalink)
steve11
Mad Modder
steve11's Avatar
Local Time: 07:03 AM
No you wont have to remove the heatshield as it's flexible.
Yes you should fit a flexjoint to the end of the extraxtors.
Australia Male View steve11's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 23rd, 2008, 03:38 PM   #3 (permalink)
k-huevo
Trailer Trash
Local Time: 04:03 PM
If this is being done on your back with the vehicle on stands, removing the left front heat shield will allow easier extraction and insertion. There are two 10mm body nuts and two 8mm screws fastening that heat shield, it is the one covering the rear O2 sensor connector and the shifter cables route through it.
Some more tips, replace the outer head flange bolts with studs like the ones used on the intake manifold, and use 13mm nuts with lock washers. This provides hangers for the header, not a big deal if you have help top side, but when R & R solo it helps big time. Use new fasteners; after a few heat cycles torque the fasteners again (18 ft-lb), and repeat after several more heat cycles.
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 24th, 2008, 09:53 AM   #4 (permalink)
E-Gun
E-Gun's Avatar
Ah ..
okok
Just fitted the header today with hi flow cat and resonator.
It pulls hard..
Thanks for the info, k-huevo and steve11
Header for MCs E-Gun Engine & Drivetrain Tuning 2 Mar 21st, 2006 01:15 PM
Considering a header for my MC, but... dansmini Engine & Drivetrain Tuning 6 Jan 10th, 2005 08:24 PM
BMP Header suprchrgdmini Engine & Drivetrain Tuning 5 Jan 28th, 2003 05:04 PM
header and cat suprchrgdmini Engine & Drivetrain Tuning 5 Oct 24th, 2002 10:27 AM
