Tags: , , ,
Old Jan 29th, 2008, 06:20 PM   #1
minioneandrew
minioneandrew's Avatar
Local Time: 06:34 PM
Send a message via MSN to minioneandrew
Shorter ratio gearbox in R53
Started this thread to get some advice:
My clutch release bearing is away (i think), making a screeching noise when the clutch is lifted when pulling away in 1st.
So basically im going to have to take the gearbox out to fix this. So getting a sports clutch, and lightened flywheel done at the same time makes sense right?
However my gearbox has had the infamous "gearbox knock in neutral" noise since i got it. Is it broken i do not know? What im wanting to know is can you get the shorter ratio box from the 05+ cars? How much this is likely to cost, and can somewhere like 1320 supply one? Some suggestions for the clutch and flywheel would be much appreciated aswell! Hoping to spend as little money as possible
Many thnaks
Drew
Superchargedddddddddd!
Scotland Male View minioneandrew's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 29th, 2008, 06:29 PM   #2 (permalink)
Jaw_F430
Jaw_F430's Avatar
Many thnaks
Drew
If I was too replace my clutch and flywheel I would buy the exedy clutch and flywheel (around £900 ). See either 1320 or GTT
Regards
James
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 29th, 2008, 06:41 PM   #3 (permalink)
Paul Webster
Paul Webster's Avatar
Andrew, at the moment we have a 27k 06 gearbox with factory lsd in stock at £800 plus vat
Exedy chrome moly flywheel & Hyper clutch £850 incl vat
You might as well uprate the driveshafts made by Quaife exclusively for 1320autos.com which will be availble in approx 12 weeks, price £200 plus vat
(sorry, shameless plug, you dont need them)
Good luck
It's not how much you spend but how well you spend it
Old Jan 29th, 2008, 06:52 PM   #4 (permalink)
minioneandrew
lol at the plug
Thanks for the quick replys
The cars still running ok, just making loud funny noises
What year was the getrag box changed to the shorter ratio? And was the LSD standard or was it an option?
thanks
Old Jan 29th, 2008, 06:53 PM   #5 (permalink)
Paul Webster
july 04 and its an option apart at some point it became std on the chilli pack but I cant remember when that was.
Old Jan 29th, 2008, 07:00 PM   #6 (permalink)
MiniPetrolHead
263bhp / 284.55Nm Torque
MiniPetrolHead's Avatar
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
My clutch makes a strange noise when i pull away in 1st especially when its cold. Its like some sort of rubbing noise. What could be causing this and is it a common fault?
BMW tell me its the auxillery drive belt tensioner???? But i think im being fobbed off!
Alex
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 29th, 2008, 07:06 PM   #7 (permalink)
minioneandrew
My mini has always made the noise to a ceratin extent, but its just got worse and worse. Sounded like rubbing at 1st! Now is definantly like metal on metal
Ill have to start saving, cant afford to fix it this week , luckily its still running fine, and ive got a 2nd car!
Old Jan 29th, 2008, 07:22 PM   #8 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Old Jan 29th, 2008, 10:30 PM   #9 (permalink)
MarsLandingParty
Lobster Boy
MarsLandingParty's Avatar
Send a message via MSN to MarsLandingParty
might i say, the Cooper S gearbox conversion on the Cooper is the best thing i've ever done to my MINI, highly recommended
United Kingdom Male View MarsLandingParty's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 30th, 2008, 07:27 AM   #10 (permalink)
Ant FR
mine makes the same noise too, when i spoke to Roland the other week on the same subject he recommended the Exceedy too.
Somthing about the Fidanza flywheel he previously used ended up munching his entire gearbox.
i also read some bits on the LSD and according Tony Franks the Quaife ATB is better than the standard BMW LSD.
However i'm not sure i prefer the lightened flywheel due to losing even more engine braking capability. Think i may just get an uprated clutch and then a standard flywheel.
Old Jan 30th, 2008, 08:26 PM   #11 (permalink)
Alan Wolfe
Alan Wolfe's Avatar
Local Time: 12:34 PM
Actually a lightened flywheel will give you more engine braking. Its that inertia thing - objects in motion tend to stay in motion.
Alan
Old Feb 4th, 2008, 04:34 PM   #12 (permalink)
minioneandrew
The exedy clutch and flywheel setup is pretty expensive, anyone recommend a cheaper alternative? I may even go with a BMW clutch, depending on the price - anyone had one done recently?
Or would i be better, keeping the drivetrain standard, and use the money to buy, pulley, intercooler etc???
Old Feb 4th, 2008, 04:45 PM   #13 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Alan
I think your getting confused hear..... A lightend flywheel will stay in motion as you say, objects in motion stay in moton..... a standard heavy flywheel will slow down quicker and have more engine braking because of its weight. A LF will stay in motion as there is less mass/weight for the engine to turn hence less engine braking as it stays in motion longer.
Old Feb 4th, 2008, 04:51 PM   #14 (permalink)
Damo
MINI2fosi
Damo's Avatar
Send a message via MSN to Damo
I always thought the LSD became part of the Chili pack as soon as the LSD came out. I didn't think it came out so soon either otherwse my mate Windy would of definitly opted for it. Unless I'm reading it wrong. Do you mean the lower ratio's came out in July 04 (makes more sense) as I know the LSD came out later than the facelift....
Now when I got my car it was already available, and it was weird how they did it. They made it part of the Chili pack but had added £100.00 onto the price of the Chili pack, but you could "opt out" of the LSD and the Chili pack droped in price, but £100. Basicly making it an option for £100
Thats asuuming my memory isn't fuzzy.
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 05:04 PM   #15 (permalink)
Loui
230whp an counting
Loui's Avatar
LSD wasnt available till jan 05 an was included in chili pack for £100. The ratios were changed as paul said in the july cause mine is a shorter ratio box with no lsd, but it has had a quaife put in
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 07:28 PM   #16 (permalink)
Damo
MINI2fosi
Damo's Avatar
Hows the MINI OEM LSD compared with the Quiafe anyone know
Old Feb 4th, 2008, 08:29 PM   #17 (permalink)
Alan Wolfe
Alan Wolfe's Avatar
Nope, the reason an engine has a flywheel is so it continues to turn between power strocks. A heavier flywheel has more inertia and provides for smoother idle. It also slows down the engines change in rpm - either speeding up when throttle is applied, or slowing down when throttle is removed. That's why people change to a lightened flywheel, so the engine will speed up faster when throttle is applied. And it also allows the engine to slow down faster when throttle is removed.
Alan
Old Feb 4th, 2008, 08:35 PM   #18 (permalink)
Fisher
Local Time: 07:34 PM
Send a message via MSN to Fisher
Fidanza flywheel and OEM clutch works great.
14.106@103.83 60ft-2.465sec
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 08:36 PM   #19 (permalink)
Alan Wolfe
Alan Wolfe's Avatar
The MINI OEM lsd is a friction plate lsd. It is a simple effective design, but the friction plates do wear out over time. A Quaife is a automatic torque biasing (ATB) helical lsd. It has no parts that are designed to wear as part of normal operation. Thus the warranty for life. Quaife is widely used in motorsports. I don't know of any friction plate lsd used in motorsports. If a Quaife is not used, then a locker diff is usually used.
Alan
Old Feb 4th, 2008, 08:38 PM   #20 (permalink)
Damo
MINI2fosi
Damo's Avatar
Alan
10k's or 100k's Or does it depend on how you drive it
Mini Close-ratio gearbox and more.. ceddyluv82 Engine & Drivetrain Tuning 10 Sep 7th, 2005 05:42 AM
Shorter 05 gear ratio into 04 ?? PYUGALA MINI Cooper S 6 Mar 19th, 2005 02:55 PM
Order time can be shorter in the US than UK WHY ? Si5Bellies MINI Cooper S 4 Jun 11th, 2004 11:57 PM
shorter shifter maninblack Engine & Drivetrain Tuning 1 Apr 6th, 2004 01:48 PM
CD Changer - Shorter wires GTT 280 Interior & Ice 2 Apr 20th, 2003 12:29 AM
