Think Mini
Old Feb 4th, 2008, 02:12 PM   #1
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 04:01 PM
Crank pulleys...
I've been contemplating the crank pulley upgrade, but have been reading a lot about pulling the harmonic damper off and putting one without not being that great of an idea due to vibration.
What are everyones thoughts on this? I mean for a track car who cares as you are trying to maximize performance but for a daily driver, I would rather not shorten the engine bearing life for the extra power.
Comments?
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 03:07 PM   #2 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Local Time: 10:01 PM
Very interested in this myself too.... good question.
235+ BHP "Works" Eater
United Kingdom Male View batou's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 03:16 PM   #3 (permalink)
Snowie
Snowie's Avatar
I have GTT + 3% crank pulley, it has been on for about 10,000 miles
There is no noticeable difference in engine vibration at all. A very discrete way of achieving more SC boost.
Alan
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 03:17 PM   #4 (permalink)
DaFlake
DaFlake's Avatar
There apparently was a huge debate on this at NAM, but nothing ever came of it. I am just curious as to what the thoughts of our vendors might be and from people that have done the mod.
It just seems to me that you would be putting a lot of stress on the engine by getting rid of the damper.
Global Moderator
Old Feb 4th, 2008, 04:10 PM   #5 (permalink)
Fisher
Send a message via MSN to Fisher
I am thinking about the lightened crank pulley but I have already got the lightened flywheel.
What about that combination? It's OK to get the pulley too or not?
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 05:00 PM   #6 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 09:01 PM
I'm running a +1% and no vibration. It's a lightweight one too
Old Feb 4th, 2008, 05:07 PM   #7 (permalink)
Keano
I found this:
Mini Harmonic Damper
explains the need / purpose of the harmonic damper...
hope it helps
My understanding of this is that the harmonic damper dampens the larger vibrations associated with the natural frequency (frequency at which the amplitude of vibration is larger than normal) of the crank.
The article implies (to me) that any alteration to the rotational mass of the crank would result in the need for an adjustment to the harmonic damper to compensate. Removal of the damper would mean that there is no dampening of forces from the crank which could potentially cause damage. However there doesnt seem to be anyone who has actualy had a problem with a lightened crank pulley (that I have seen) so maybe these forces are negligible. It may also be that if the crank is designed well enough in the first place that there may not be a need for the damper...
Keano
Last edited by Keano : Feb 4th, 2008 at 07:21 PM. Reason: Explaining my interpretation of the link
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 07:59 PM   #8 (permalink)
MINIMANIAUK
MINI2 Sponsor
On some engines the damper can have a huge effect and engine life be shortened drastically, the crank mass and stiffness are the main problems -larger engines and longer engines v8/v6 would be very susceptible, however the MINI is blessed with a small engine ,low mass crank with good torsional stiffness so less of an issue
External items driven by the crank also have an effect on the resonant frequency (read supercharger) so changing s/c pulley also has an effect on vibration
Any major effect on longevity would have shown up by now with bearing failure and oil pressure issues .
If chasing large power outputs a degree of loss of longevity must be accepted,but I doubt the damper is a major issue
Old Feb 4th, 2008, 08:43 PM   #9 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Send a message via Skype™ to sam_a156
Alan
Second that. I also have the GTT +3% crank and I am happy with it. No noticeable downsides, just more midrange punch.
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2008, 09:09 PM   #10 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
I have a GTT +1% crank or +4MM not sure im confused on that one still. But my experiences seem to be different from others but then maybe its either my setup or im really picky and notice everything.
I find that the engine feels rough compared to with the standard and very heavy crank(Wow its heavy! and mines a facelift model!) and most of all in summer when you put the air con on it feels like the engine is being dragged down so bad. You really know when the air con clutch goes big time. **Click** suddenly the revs go down and come back up again but then the engine justs feels really rough and then **Click ** the clutch disengages and the revs jump slightly and back down again to normal smoothish drive till the clutch goes again.
Ok so thats not the worst thing in the world... but.....I drive one of the first facelifts and as many people know the idles are rubbish and erratic sometimes. So add aircon being on at the same time as a minute of rough idle and you either switch the air con off, rev it for a sec or get one hell of a vibration massage.
So if you dont have aircon I would seriously recommend one especially on a works But I would recommend an enlarged alternator pulley too. Some will laugh but I witnessed a major drop in mpg when I have the music going on a journey with the sub going. Related or not.... well I do believe that anything connecting to the crank pulley will cause much more drag on the engine with an enlarged pulley.
But hey mines coming off in the next couple of weeks so I will be interested to see how it performs then.
P.s. how many of the +3%s have Works? All? Mines 17% and a +1 so I do think mines a bit too far to be smooth.
Old Feb 4th, 2008, 11:42 PM   #11 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
My works has had a +3% crank on it for 32k miles now with no problems. I didnt notice anything with regards to smoothness or idle after it was done.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 5th, 2008, 03:07 AM   #12 (permalink)
Revolution Mini Works
Mini2 Sponsor & Tuner
Local Time: 01:01 PM
I know this is a touchy subject but I have seen personally 4 engines break oil pump gears and all 4 of them had crank pulleys......
take it for what it's worth
Manufacturer and Custom Mini Tuning
Old Feb 5th, 2008, 05:41 AM   #13 (permalink)
DaFlake
DaFlake's Avatar
Guys, just to make this clear, this is not vibration that you would feel but rather vibration that your engine would. Your engine mounts would dampen the effects of what you, as a driver, feel.
MINIManiaUK has a very interesting point but where my concern lies is that MINI was concerned enough to put a more expensive crank pulley on there then why do it? However, his response does make sense.
Global Moderator
Old Feb 5th, 2008, 05:43 AM   #14 (permalink)
DaFlake
DaFlake's Avatar
Hmmm... Could it be that we are finally starting to see the affects of this? I mean failure wouldn't be right away but over a period of time.
Global Moderator
Old Feb 5th, 2008, 05:52 AM   #15 (permalink)
these were all 230whp+ cars with crank pulleys.... the oil pump gears are made of powdered metal. We will be designing some that are billet
Old Feb 5th, 2008, 06:37 AM   #16 (permalink)
DaFlake
DaFlake's Avatar
It is the age ol debate.... I want more power without sacrifice. The idea is to get more power without severely shortening the life of the engine so I am a bit concerned about this mod.
Global Moderator
Old Feb 5th, 2008, 09:02 AM   #17 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Cool Upgrading power...
...ah, so you do need to upgrade other parts to become more resiliant when upgrading the power.
Cheers,
K.
Old Feb 5th, 2008, 09:27 AM   #18 (permalink)
Paul Webster
Paul Webster's Avatar
Cheers,
K.
How big was your smile when you read that
You will always find more weak links as power levels and rpm are raised, I suppose thats what they call progression.
Thinking about it Karl it might be worth you putting a 15lb pressure oil light in before your next outing, a light is better than a guage because I defintley dont look at mine
Auto Meter Pro-Lite Pressure Loss Warning Light - JEGS
It's not how much you spend but how well you spend it
Old Feb 5th, 2008, 09:46 AM   #19 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Ha ha, yes, indeed
An interesting gauge. Is it easy to fit something like that?
I am getting the DashDyno SPD and that can take 4 external sensors - perhaps one could be an oil pressure sensor?
Cheers,
K.
Old Feb 5th, 2008, 09:49 AM   #20 (permalink)
DaFlake
DaFlake's Avatar
I think that is pretty normal when you are taking a stock engine and trying to increase power. Parts have a certain threshold that if crossed will cause failure. It isn't like we are taking a an engine, breaking it down and then rebuilding it will better specs. Ah the good ol days... I remember building that 450 in my friends garage with this dad. What fun....
Global Moderator
Pulleys foggyMCS Engine & Drivetrain Tuning 2 Jan 11th, 2008 04:13 PM
how much are the 05 and later stock crank pulleys fozworth Engine & Drivetrain Tuning 3 May 7th, 2007 09:07 AM
Lightweight crank pulleys & impact on reliability KiwiJCW Engine & Drivetrain Tuning 8 Oct 17th, 2006 09:12 AM
15%-17%-19% pulleys!!! KMK163 Engine & Drivetrain Tuning 25 Sep 28th, 2006 11:50 PM
Pulleys Fisher Engine & Drivetrain Tuning 0 Jun 28th, 2006 12:59 PM
