| Tags: oil |
| MINI2 Master | Oil temp gauges Ok, i have seen various gauges over the last few years. I am currently considering the JCW optional oil temp kit that goes under the window switches. But also wondered on some of these SPA gauges, i have seen the ones in GRS's car which look nice again down below the switches, or i was thinking of going for Alta pod set that can go around the rev counter. Any ideas people. Don;t want spend loads ( i kinda can't ) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 07:16 PM
Offline | The cheapest option would be an A pillar pod £25 and gauge of your choice various available,plus the temp sensor and a bit of wiring- The greatest cost is the installation ,but if you DIY ,all up under £100 |
| MINI2 Senior | These SPA gauge aren't cheap, however you can set parameters so the red flashing light can come on at a preset value. This means you can keep your eyes on the track and not worry too much about looking at extra gauges, if the oil pressure does drop to a parameter set then you'll see a flashing light in the corner of your eye ![]() Graham ![]() |
| | #8 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 07:16 PM
Offline | If only I could find a pod that has blue lights, dial that can be set to anyone of the readings and monitors water, oil temp & pressure and boost. All on the LCD display but pressing a button to make the dial read the correct value for that input. With max and minimum threshold alarms. Wouldn't that just be really cool?? Or am I just after the moon on a stick? |
| | #9 (permalink) |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 07:16 PM
Online | Have you had a look at that dynodash? I know its not a gauge but its an LCD display that will monitor all of the above. Just wonder if the LEDs flash when one limit is reached? ![]() Regards James |
| Boost - Oil Temp gauges | ScottyBoy | MINI Cooper S | 11 | Jul 30th, 2007 08:39 PM |
| Boost and temp gauges! | marc-s | Engine & Drivetrain Tuning | 6 | Feb 22nd, 2007 10:15 PM |
| oil press /temp gauges | CC07ERS | Interior & Ice | 0 | Sep 24th, 2006 08:09 AM |
| Aux Gauges Oil temp bouncing around | twig | Faults & Fixes | 2 | Jun 27th, 2005 10:23 PM |
| Auxilliary Battrey Voltage+Oil Temp. Gauges | FREEZE BOX | Interior & Ice | 15 | Jun 24th, 2003 05:16 PM |
