Old Feb 7th, 2008, 10:22 PM   #1
Meeerrrk
Local Time: 10:01 PM
Send a message via MSN to Meeerrrk
GTT230 Spec, what next?
My car is now at the GTT230 stage, i had GTT220 fitted but have since fitted the exhaust re-route pipe, GRS intercooler & Samco inlet hose.
So what's next?? I am spending some money on other area's of the car at the moment so i dont have bottomless pockets for headwork, turbo conversions etc. Plus i've only just moved into my first own house
I am happy with the performance of my car, but you can always have more! I can keep with my mates Remapped LCR but keeping up just isnt enough...
What would be the next logical step for reasonable money, that will give me the best increases for my cash?
thanks, listening with interest.
Mark
United Kingdom Male View Meeerrrk's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 7th, 2008, 10:29 PM   #2 (permalink)
BigShow
Tunnel Runner
Local Time: 09:01 PM
In order... Leakdown test, dyno run, 440cc injectors, 1320 cam, dyno run, smile smugly at 240 bhp+ results.
Old Feb 7th, 2008, 10:31 PM   #3 (permalink)
Meeerrrk
leak down test? talk to me....
what kind of money are we talking for injectors and 1320 cam, including fitting?
i like the sound of the results
Old Feb 8th, 2008, 12:05 AM   #4 (permalink)
BigShow
Tunnel Runner
Leakdown test info:
http://www.mini2.com/forum/engine-dr...t-results.html
it's worth doing the leakdown as a health check before trying to increase BHP on what could be a poorly engine.
Best mods to do next and prices (440cc injectors shouldn't cost much more than the 380cc ones):
http://www.mini2.com/forum/engine-dr...-cyl-head.html
http://www.mini2.com/forum/engine-dr...ling-road.html
Old Feb 8th, 2008, 03:01 AM   #5 (permalink)
drumzz
drumzz's Avatar
what is a remapped LCR??
Old Feb 8th, 2008, 08:31 AM   #6 (permalink)
Meeerrrk
LCR; remapped Leon Cupra R, 265-270bhp
Old Feb 8th, 2008, 08:31 AM   #7 (permalink)
Meeerrrk
Quote: Originally Posted by BigShow (original)
Leakdown test info:
ok brill thanks
Old Feb 8th, 2008, 08:49 AM   #8 (permalink)
Babes
Cruising In The Minge
Babes's Avatar
Local Time: 06:01 AM
if you havnt already got them fitted a strut brace and rear sway bar do absolute wonders for the handling. Had i known the difference it would have been one of the first mods i did.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
1970 BRG/W MK2 Morris Cooper S
Australia Male View Babes's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 8th, 2008, 09:25 AM   #9 (permalink)
Meeerrrk
it sounds like my first step is a manifold and sports cat!
keep suggestions flowing though!
Old Feb 8th, 2008, 09:34 AM   #10 (permalink)
Loui
230whp an counting
Loui's Avatar
I think you`d need a remap as well Ben as 440`s will be a bit rich on their own from what ive heard. Paul was telling me the 272bhp car was coping still on 380`s but only needed the 440`s for the top end as it was starting to lean out a bit
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 8th, 2008, 09:51 AM   #11 (permalink)
Jaw_F430
Jaw_F430's Avatar
Pretty much the same as Big Show said + manifold and cat and remap if you fit the 440cc as Loui said
If you do have some extra money or save up and buy the cylinder head. This will give you a very good gain!
Enjoy
James
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 8th, 2008, 01:34 PM   #12 (permalink)
alski
dyno-mite, might not....
alski's Avatar
got a BBK after getting to gtt 230, assume your not on s-spokes - next thing i am looking at is upgrade rear anti roll bar..
carefree
Old Feb 8th, 2008, 02:33 PM   #13 (permalink)
neilobe
Manifold mate, or the whole Milteck System, thats wat i ran on my GTT 230 upgrade makes a nice sound too
Check my videos on youtube
Gives you an idea of sound ..
Old Feb 8th, 2008, 03:26 PM   #14 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Hi, Mark go for the GTT 2pc manifold next , then 440cc injectors fitted + our GTT Adjustable fuel pressure regulator. This is alot cheaper than a remap and allows you to adjust the overall open loop fuelling as required as you mod further. Also prevents fuel pressure over manifold pressure dipping off above approx 17psi as it will with the stock reg. You can then have the Shrick cam fitted later and the pressure tweaked very easily at no extra charge if done at the same time.
We have applied this setup to a number of cars now, and wide band tested verified the AF ratios on the road under all conditions of load/rpm/gear/roadspeed.
Or as mentioned a quartet of GTT braces would do wonders for the handling !
best Regards Roland GTT
Old Feb 8th, 2008, 05:32 PM   #15 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
Go for the braces
Vroooom Vroooom
Old Feb 8th, 2008, 05:39 PM   #16 (permalink)
Meeerrrk
Quote: Originally Posted by Aberdeen Al (original)
Go for the braces
braces? but my trousers dont fall down?!
Old Feb 8th, 2008, 06:14 PM   #17 (permalink)
BigShow
Tunnel Runner
True but rich equals flames
In that case Meeerrrk stick with the 380's and no remap... I know you said you didn't have deep pockets and mani's aren't cheap and in my case a janspeed mani with sports cat and milltek only gave 5-7bhp but it does sound the nuts, although much louder than neilobe's video and darn expensive.
So for big bangs for smallish bucks I don't think you can beat the 1320 cam and 380cc injectors.
As with everything though it pays to get an all inclusive quote from all the tuners as well as asking for expected bhp gains, and then ask for a tuner penalty of £25 for every BHP the conversion doesn't release
Old Feb 8th, 2008, 07:53 PM   #18 (permalink)
uncle albert
uncle albert's Avatar
You're giving me ideas for what to put on my GTT shopping list this year Roland! (The boot brace doesn't count - that was a brucey bonus! )
James
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 8th, 2008, 10:58 PM   #19 (permalink)
Meeerrrk
thanks for the info everyone, very interesting. Some food for thought there.
Manifold and cat sounds like the first port of call then, i can see im getting more air in but i am not opening up it's route out!
Then maybe later in the year go for injectors and a cam.
Thanks everyone
Old Feb 9th, 2008, 11:52 AM   #20 (permalink)
Rigsey
Thanks everyone
I can highly recommend the GTT manifold and sports CAT
GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road
England Male View Rigsey's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Comparison for GTT230 Capsaisin Finance & Insurance 0 Oct 5th, 2006 07:12 PM
MCS JCW210 or GTT230...Just an idea... MarkW19 MINI Cooper S 27 Jul 31st, 2006 11:08 PM
Full Spec S, trade for bare spec JCW?? tenshipb MINI Cooper S 2 Dec 30th, 2003 08:53 AM
Converting US Spec Mini Cooper S to UK Spec ilstratakis General Discussion 19 Oct 15th, 2003 08:40 AM
date for 2003 spec? sport wheelpic? spec? mikeythemini MINI Cooper S 0 Jul 27th, 2002 05:29 AM
