GizzmoUSA
Old Jun 2nd, 2008, 06:06 PM   #21
Berthil
Berthil's Avatar
Local Time: 09:56 PM
The Innovate LC-1/LM-1 is a replacement for the original pre-cat O2 sensor, no welding needed!
If not connected right the Mini will not run closed loop because of the lambda heater absence but it can be done if you simulate a heater with a resistance.
I had a sensor broken and for the cost of a new one at the stealers I bought the innovate LC-1.
I use it in conjuction with a LMA-3. If you buy the LM-1 you can also do data-logging in the daisy chain.
From left to right, Air Fuel Ratio (AFR), Exhaust Gas Temperature (EGT) and Boost.
EB/W R53 MCS Highly Modified
Netherlands Male View Berthil's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 3rd, 2008, 05:24 AM   #22 (permalink)
alski
dyno-mite, might not....
alski's Avatar
Local Time: 08:56 PM
can we have a bigger picture please
carefree
Old Jun 3rd, 2008, 01:16 PM   #23 (permalink)
MINIMANIAUK
MINI2 Sponsor
I do like that set up !! both a quick ref outer indication and digital presentation -nice
Old Jun 3rd, 2008, 01:35 PM   #24 (permalink)
Paul Webster
Paul Webster's Avatar
Berthil, you and Tuls would get on like a house on fire he's a lover off carbon, nice set up by the way.
It's not how much you spend but how well you spend it
Old Jun 3rd, 2008, 03:03 PM   #25 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Personally im a big fan of the ZR-2 You can even set threshold now where the optional red warning light can be activated.
ZR-2
Old Jun 3rd, 2008, 03:04 PM   #26 (permalink)
MINI-Morgan
MINI Obsessed...
Quote: Originally Posted by MarkXR (original)
lot of cars run closed loop with only 1 sensor
True.... aslong as the precat sensor is present the ecu will run closed loop and vary the short and long term fuel trims. Which is a big pain in the ass for me as it keeps screwing up my open loop fueling! Grrrrr! I need a remap......
Brake Light Sensor & Sensor replacement help needed wrxtomini Faults & Fixes 7 Apr 20th, 2006 08:55 AM
Oxygen Sensor or Coolant sensor???? maximusrp Engine & Drivetrain Tuning 5 May 30th, 2004 07:33 PM
O2 Sensor ECU Fix Soulbringer Engine & Drivetrain Tuning 13 Jan 8th, 2004 08:19 PM
Map Sensor PW51CAR Engine & Drivetrain Tuning 13 Jan 1st, 2004 06:32 AM
Wideband A/F Meter is ALIVE! Andy@Ross-Tech.com Engine & Drivetrain Tuning 14 Feb 6th, 2003 03:30 PM
