| Tags: crank pulley |
| MINI2 Regular | crank pulley Can someone confirm that i'm understanding this correctly. I currently have a stock 210 cooper s which as part of the JCW mod has a 11% reduction on the supercharger. I'm going to fit a lightend crank pulley & i was thinking of the GTT one that is +4%. This will give me a total of 15% increase on the supercharger running speed which as i understand it is the max recommended increase unless i fit a larger intercooler to reduce the inlet temp.. |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 09:03 PM
Offline | Worth double checking if its +4% on the crank or equal to +4% on the SC pulley. Makes quite some difference! The GTT website doesnt list the sizes other than +4MM on the crank from what I remember. |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 09:03 PM
Offline | 4% is probably a little high. I believe GTT crank biggest off the shelf size is 3% increase over stock. On a JCW/GP this is OK, but I'd suggest a change of intercooler as my car on a 15% used to get red hot. The GP IC is pretty reasonable, theres GP with + cranks running with GP IC and they eem pretty good for power. |
| Cruising In The Minge | I have been considering putting my 3% CP back on, though I have changed SC pulley to 17% now on my JCW. I have the GTT intercooler. Has anyone got this combo? I know some folks on here run 19% and even 21% SC pulleys. Is the 17% and 3% too much over the top? ![]() 2002 PS/PS JCW MC 1970 BRG/W MK2 Morris Cooper S |
| | #13 (permalink) |
![]() MINI2 Master Join Date: Aug 2006 Location: Modena IT /Camberley Local Time: 10:03 PM
Offline | Not noticed any less engine braking effect can not hear any increased whirring sound - probably killed by my exhaust as I also can not now hear the SC whine increasing In Italy |
| | #15 (permalink) |
| MINI2 Master | mines more as if there is an air leak from somewhere ( which there is'nt) and is very noticable. I think i'll get Roland to have another listen on Saturday when i go for oil change and general check over, ( will be hitting the big 1000 miles on saturday. run -in in a fortnight.!! |
| | #17 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 09:03 PM
Offline | Ive never heard a whirring sound after fitting a crank pulley. There are no bearings in it ,it rotates 'as a whole' with the crank. More likely aircon or alternator or sc . ![]() |
| | #19 (permalink) |
Offline | Hey I get that too! lol figured it was just the drawing of air through the partly open throttle body. I still have it after the removal of the lightened crank so cant be that ![]() Have to say my MINI is quite different with the heavy stock crank back on.... |
| | #20 (permalink) |
Offline | Its is the drawing of air. If you fit an air intake it turns from a triccling/running water noise to a sort of whitle on part throttle....esp if the scuttle panel is removed! |
| 17% S/C Pulley + 2% Crank | futureal33 | Engine & Drivetrain Tuning | 6 | Feb 8th, 2007 09:23 PM |
| 05 Crank pulley different to O3? | Drewski | Engine & Drivetrain Tuning | 3 | Sep 10th, 2006 09:32 PM |
| 2% crank pulley ?? | brady | Engine & Drivetrain Tuning | 10 | Dec 3rd, 2005 05:37 PM |
| MCS Crank Pulley | gt40guy | Engine & Drivetrain Tuning | 5 | Jan 18th, 2004 06:32 PM |
