Tags: , ,
Old Feb 16th, 2008, 04:35 PM   #1
minioneandrew
minioneandrew's Avatar
Local Time: 07:18 PM
Online
Send a message via MSN to minioneandrew
Help with pulley install?
Hi
Started the procedure today to remove my stock supercharger pulley. Managed to get to the point of lifting the engine (which made some very strange noises on the way up) Eventually the engine would go up no further, and the car was being lifted off the axle stands.
After lowering the engine back in, and securing the motor mount bolts, im kinda baffled why it didnt work.
I was using the instrucions from NAM, and they said not to remove the cast iron engine mounts, just to remove the nut from the left, and a big long horizontal bolt from the right. The alta instructions however, say to remove both cast iron engine mounts?
Ive attched a foto of each. Some help would be greatly appreciated!
ID:	142428  Click image for larger version
Superchargedddddddddd!
Scotland Male View minioneandrew's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 16th, 2008, 05:05 PM   #2 (permalink)
k-huevo
Trailer Trash
Local Time: 01:18 PM
Don’t forget the lower engine vibration mount at the back of the oil pan. This job requires two jacks, one under the gear box side to lower, and the other under the outside corner of the oil pan to raise that end. If you only have one jack, remove the lower engine vibration mount’s bolt; disconnect the transmission mount bolt while supported with the jack, lower about four inches and support with a stand, then move the jack to the oil pan end to raise. Be sure to follow the directions for disconnecting the coolant hose from the intake manifold and other bits.
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 16th, 2008, 05:13 PM   #3 (permalink)
minioneandrew
Online
We did remove the lower engine mount bolt, i wasnt aware of the gearbox mount having to be removed? Hope we havent broke it.
So basically having a jack at each side of the engine and gearbox? I will need to aqquire another jack...
Old Feb 16th, 2008, 05:40 PM   #4 (permalink)
k-huevo
Trailer Trash
I didn't say anything about removing the gear box mount.
Old Feb 16th, 2008, 07:13 PM   #5 (permalink)
minioneandrew
Online
Sorry misread
Old Feb 16th, 2008, 11:40 PM   #6 (permalink)
Fisher
Local Time: 08:18 PM
Send a message via MSN to Fisher
Actually it's not necessary to remove lower engine mount. I have never remove it and always do my job easy.
14.106@103.83 60ft-2.465sec
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
So Cal shop to install pulley? atomiK Southern California Region 4 Apr 20th, 2005 04:00 PM
Ever install a JCW pulley on MCS? zooooom Engine & Drivetrain Tuning 5 Feb 18th, 2005 08:55 PM
Pulley Install, Yes or No? rmorin Engine & Drivetrain Tuning 8 Feb 9th, 2005 01:44 AM
Urgent Need help with pulley install dhayashi Engine & Drivetrain Tuning 3 Oct 17th, 2004 02:08 AM
Did it myself - Pulley Install BluMiniMe Engine & Drivetrain Tuning 0 May 30th, 2004 08:20 AM
