Visit Mini Mania UK
Old Mar 5th, 2008, 09:04 PM   #21
gpmick
GP 56 MCK 0774
gpmick's Avatar
Local Time: 08:57 PM
Heres my results
GP
DOB September 2006
10000 miles
tyres 205 40w18/ 35 psi
No mods to engine
Name:	rolling 1 (Small).JPG
Old Mar 23rd, 2008, 07:20 PM   #22 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Local Time: 09:57 PM
Send a message via Skype™ to sam_a156
John Cooper Works (JCW) 210hp Package:
-JCW catback (kink/flat part removed)
-JCW cylinder head
-JCW air intake (flap and mechanical parts removed)
-JCW supercharger
-JCW 380cc injectors
Plus:
-Mini Madness JCW intake filter kit
-GTT Exhaust Manifold
-GTT +3% Overdrive Crank shaft pulley
-GTT Modified bypass valve
-GTT Intercooler + Snoot boots
-Custom ECU map
222hp/250Nm(184lb-ft)
Hope to better that soon
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 24th, 2008, 09:02 AM   #23 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 07:57 AM
Hi,
Does anyone have a dyno showing AF ratio vs rpm they would like to share ???
I'm just interested what ratios people with modified engines are running on the dyno.
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 31st, 2008, 05:48 AM   #24 (permalink)
Darrin
Mighty Mouse
Darrin's Avatar
Quote: Originally Posted by robbo mcs (original)
Hi,
Robbo
Here's a dyno plot showing A/F ratio that I had done last week after fitting a -15% pulley. As can be seen from the plot A/F ratio remains very rich even after the addition of a pulley (stock map).
The stock intercooler heat soaked very quickly, however, the dyno operator conducted all tests with the bonnet up resulting in no forced air convection through the intercooler core. Personally I think the bonnet should have been closed, can someone shed some light on the correct way for testing cars fitted with a TMIC?
Australia Male View Darrin's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 31st, 2008, 10:34 AM   #25 (permalink)
BigShow
Tunnel Runner
Bonnet should defo be shut!!! That won't have helped your figures at all mate. Thanks for posting the graph.
Old Mar 31st, 2008, 12:50 PM   #26 (permalink)
Darrin
Mighty Mouse
Darrin's Avatar
I thought as much - you'd think an experienced dyno operator would know that!
Old Mar 31st, 2008, 04:15 PM   #27 (permalink)
BigShow
Tunnel Runner
It happens over here as well mate, people don't realise that the IC needs the scoop to channel the air otherwise no matter what fan they have, with the bonnet up you may as well just have an asmathic blowing on it through a straw!
Old Mar 31st, 2008, 11:33 PM   #28 (permalink)
black20vt
black20vt's Avatar
John Cooper Works (JCW) 200hp Package: 2004
-JCW catback (early one without kink)
-JCW cylinder head
-JCW supercharger
Plus:
-GTT CAI
-Janspeed Exhaust Manifold
233.1hp @ 7009
182.7lb-ft @ 6106
Name:	dyno run 220208.jpg
Last edited by black20vt : Apr 3rd, 2008 at 07:03 PM. Reason: changed ex manifold make - wasn't sure which one !
United Kingdom Male View black20vt's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2008, 12:17 PM   #29 (permalink)
BigShow
Tunnel Runner
GRS Intercooler
NGK Spark Plugs
Alta V2 CAI
Janspeed Manifold
Milltek Cat-Back
Superchips map
RMW Head
Alta V2 17% Pulley
1320 Camshaft
380cc Injectors
Power: 281.1 bhp @ 7,199 rpm
Torque: 210.6 lbs ft @ 6,532 rpm
Old Apr 10th, 2008, 08:44 PM   #30 (permalink)
MiniPetrolHead
263bhp / 284.55Nm Torque
MiniPetrolHead's Avatar
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
15% Supercharger Pulley
Iridium plugs
Alta pannel filter
MiniMania exhaust manifold
MiniMania fast road cam
GTT re-route pipe
MiniSpeed Stage 3 re-map
232bhp & 271nm torque
(soon to have: GRS intercooler, Miltek cat back, light weight crank pulley)
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 16th, 2008, 06:22 PM   #31 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Mods:
JCW supercharger
JCW 380cc injectors
JCW spark plugs
RMW cylinder head
Custom ECU map/Kreator Mocy (not optimized for RMW head)
Results w/ RMW head (approx 10C warmer than last time):
240hp/204whp
263Nm/231wNm (194Lb-ft / 170wLb-ft)
ID:	145049  Click image for larger version
Name:	mini wheels hp.jpg
R53 Turbo Only Dyno Graphs Paul Webster Engine & Drivetrain Tuning 1 Dec 20th, 2007 01:05 PM
ECU Tune Dyno Graphs - S. Fla dyno day ignote Engine & Drivetrain Tuning 1 Aug 7th, 2007 06:03 PM
ECU Tune Dyno Graphs - S. Fla dyno day ignote MINI Cooper S 0 Aug 7th, 2007 02:07 PM
just got pulley and new map,attached dyno graphs claudeG Engine & Drivetrain Tuning 7 Sep 8th, 2006 11:16 AM
