| Tags: idle, lohen, throttle body |
| | #21 |
| Tunnel Runner | |
| | #22 (permalink) |
| Chasing 295bhp! Join Date: May 2005 Location: Lancashire Local Time: 09:56 PM
Offline | Had a chat to Lohen today and Im going back tomorrow morning for them to look at the problem! They have a standard Throttle body in stock so fingers crossed after this is fitted my car will be ok again. Will also ask about the Denso plugs they fitted while Im there! ![]() GP 1021 |
| | #26 (permalink) |
| Thinking Minis | You can even see the dent marks on the plug body where the bits have been banging about. I have seen cars where a throttle body is changed and the intake seal to the charger is moved and then leaks causing poor idle. For All Your Mini's Needs ![]() 01905 620011 |
| | #27 (permalink) |
| MINI2 Master | Blimey, you put the post up a while ago slatting DENSO's but surely looking at that it can't be the plugs. Something more going on there to do that amount of damage In fact i just sent that pic to my mate, who is an authorised DENSO and NGK dealer and has 15yrs experience of the dam things and he's said straight away Detonation. |
| | #28 (permalink) |
| Tunnel Runner | It was detonation as I heard it before they went bang... Denso IK27's by the way... I was on the 3rd lap of some 'hot' laps when they went. At the time inlet temp was 51C, water temp 93C. Oh and the broken plug came from... you guessed it, cylinder 1! Fuel was Tesco 99 and oil had been checked before and was at good levels. 1320 are fitting a new head, injectors and servicing it shortly so I will send away a sample of oil for analysis to see what that brings up. When the last head was replaced 1320 cleaned off all carbon deposits that had built up in the combustion chamber and on the piston top so that wasn't the cause. That leaves very lean air/fuel ratios (checked on dyno and all good), heating of the charge air prior to entering the combustion chamber (51C), compression of the air molecules from forced induction (??), or poor heat dissipation through the cooling system (??) |
| | #32 (permalink) |
| MINI2 Master | Ok, my mate just sent me this. looking in my plug book they have a picture that looks like that Mini plug it says the causes of the plug would be over advanced ign timing, too lean fuel mixture, blocked inj, insufficent cooling, excessive deposits in the combustion chamber. its say the firing end temp would be in excess of 870 degrees!!!! But he also adds this little Ditto, and this is 15yrs experience talking there is always a reason why stuff happened and 90 % of the time its not the parts they blame just cos the plugs are like that dont mean they are @ fault, plugs do as there told not much can go wrong with em So be interesting to hear the responce. My mate has been supplying Sumo Power with Denso's for the last 5yrs and Sumo power run quite a few 1000bhp + cars without problem |
| | #33 (permalink) |
| Tunnel Runner | Standard ones at the moment, 440cc shortly when the RMW head goes on. I've not done anything different to my engine then any tuner would have done and as you know well enough, the smallest things can go wrong and have catastrophic effects... is that down to the engine being modified?? Probably... am I worried... not one bit... if after all the mods I've done my engine goes bang and I need a knew one so be it, thats what can happen when you change things from the OEM norm and you try and get more power than your car was designed to handle. If I wanted a modified car backed up by a warranty I'd have stuck with my AMD S4 as even after AMD strangled 420 bhp out of the V8 (std 339 bhp) it was still covered under my Audi Dealer warranty. But I'm too poor to have one of those now ![]() Does any Mini tuner give a complete car warranty after they've done mods... nope. So I'll happily keep tuning my car knowing that one day soon its going to go wrong. If you think any other way you're just going to be very disappointed. |
| | #40 (permalink) |
| dyno-mite, might not.... | not long, i think ben only ever does a few flying laps at bedford, always with a warm up cool down routine and he did not get there till afterlunch after being at the 1320 miniaddiction rr day also his car must have been static for a good half an hour while he took me to get my car sorted [db ] and navigated for me for a few laps ![]() carefree |
| Lohen throttle body? | minioneandrew | Engine & Drivetrain Tuning | 3 | Oct 16th, 2006 07:29 PM |
| NEW! Lohen 58mm Throttle body for the One/Cooper | Lohen | Engine & Drivetrain Tuning | 0 | Sep 18th, 2006 10:07 PM |
| NEW! Lohen 64mm Throttle body now available | Lohen | Engine & Drivetrain Tuning | 9 | Feb 1st, 2006 10:44 PM |
| M7 Throttle body | jonnyc | Engine & Drivetrain Tuning | 17 | Jun 27th, 2005 11:09 AM |
| Throttle body. | GTT 280 | Engine & Drivetrain Tuning | 1 | Feb 2nd, 2005 04:22 PM |
