Visit Lohen!
Tags: , ,
Old Mar 11th, 2008, 06:06 PM   #61
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Local Time: 08:57 PM
If people are really worried and want to be really safe then there's an answer..... unbolt the supercharger and throw it away. The cause of most of the problems!
Old Mar 11th, 2008, 06:16 PM   #62 (permalink)
Snowie
Snowie's Avatar
Local Time: 09:57 PM
Quote: Originally Posted by MINI-Morgan (original)
Wasnt that EGTs instead?
I think that is what he constantly monitors now but I also believe he has mapped AFR this way as he has been moding the car.
I may be wrong which is why I say talk to Lucky Dave
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 11th, 2008, 06:21 PM   #63 (permalink)
Paul Webster
Paul Webster's Avatar
Yeah he's tight and didn't want to put an 02 sensor in each pipe as well
It's not how much you spend but how well you spend it
Old Mar 11th, 2008, 07:29 PM   #64 (permalink)
Lucky Dave
Thinking Minis
Yes its 4 egts and only 1 O2 sensor, in fact its now 2 wideband O2 sensors but they are next to each other as a backup! and they now run the ecu in closed loop.
And both the stock O2 sensors are in there as well ! But they dont do anything but keep the heater warning lights off.
I must add my RR results may be a little to do with the gears used, I dont get much chance of max rpm in 4th due to keeping on the right side of the law and its all bendy roads round here!
Most of my testing is in 3rd at WOT.
running AF of around 11.4 my max egt is around 850-860 when AF is 12.2 my max egt was nearly 880
The innovate gear is good, I bought direct from the USA and had the full kit with a box full of dials!
If I had to point a finger about the plugs I would suspect the map? I doubt its a JCW map as your plugs would be black and sooty!! is it stock or aftermarket?
When its running maybe we could hook up a temp wideband logger on your next track day? im willing in the name of research
For All Your Mini's Needs
01905 620011
Old Mar 11th, 2008, 07:44 PM   #65 (permalink)
Paul Webster
MAybe we should chip in for some det earpones for Big Show, is there anyway we can make them work so they give him a little electric shock as well
Joking aside will you ever be able to not have a car that doesn't det with a stock cyl head
Browser Warning
Old Mar 11th, 2008, 08:10 PM   #66 (permalink)
alski
dyno-mite, might not....
alski's Avatar
Browser Warning
the ting ting sounds slightly familiar, shall be pulling me plugs out for a once over, luckily my car never gets ragged as much as others, good link also on injectors as well Paul cheers
can any one say here with any confidence that a big valve head + injectors is bomb proof, ie bye bye plug/cylinder one issues, or just moves the problem up 20hp and 500rpm or so
carefree
Old Mar 11th, 2008, 08:47 PM   #67 (permalink)
BigShow
Tunnel Runner
Back from Lohen/Mini Pirate so now have my exhaust hanging where it should be and some nice viper stripes
Lohen are going to send off the plugs to Denso to get some opinions and I'm going to send off a sample of oil for analysis to see whats going on inside the engine.
The next step is for Paul to fit the RMW head, 440cc injectors, oil sump baffle, powerflex bushes, coilovers, adj control arms and give it an oil service...then once its all fitted RMW/1320 will live map it ready for road and track. Also being added by me are cooling vents on the drivers side of the bonnet to allow manifold heat to escape and an Ociari air vent scoop to the passenger side to ram more air into the CAI........ but before it goes on track for some hot laps I will ensure it's been data logged for the first few laps to check everything is ok.
If inlet temps are still too high and its still detonating or something isn't right I'll pour petrol over it and light a match.
Old Mar 11th, 2008, 08:56 PM   #68 (permalink)
lucachiarelli
Banned
Good luck with your car Bigshow.
Should be running nicely with the new bits on their way.
England Male View lucachiarelli's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 12th, 2008, 12:22 AM   #69 (permalink)
-G-
Chasing 295bhp!
-G-'s Avatar
Quote: Originally Posted by BigShow (original)
Back from Lohen/Mini Pirate so now have my exhaust hanging where it should be and some nice viper stripes Lohen are going to send off the plugs to Denso to get some opinions.......
Nice to meet you today mate, Im glad to say my car seems to be running fine again now the standard Throttle Body has been put back on
Let me know what Denso & Lohen have to say about the plugs
GP 1021
Old Mar 12th, 2008, 08:09 AM   #70 (permalink)
BigShow
Tunnel Runner
Good to meet you too, your car looked awesome, especially those seats . Glad to hear all is ok, seems the fault was defo with the TB then so worth the trip.
I'll start a new post once Lohen have spoken to Denso as I've hijacked yours enough already
Old Mar 12th, 2008, 12:08 PM   #71 (permalink)
-G-
Chasing 295bhp!
-G-'s Avatar
Cheers mate, forget about my seats thou how good did the Gen 2 JCWs look in that R53 Cooper S
Need them in mine now haha
GP 1021
Old Mar 12th, 2008, 05:43 PM   #72 (permalink)
sanja14
Please Contact me re your account
Quote: Originally Posted by roland2003 (original)
People need to understand that checking adjusting AF ratio on the RR is very risky....it will run considerably leaner on the road. Thats why we would only set set it/check it on the road.
The difference is quite large sometimes too. As Dave says you can tune to achieve impressive power on the RR OR tune for road performance + good reliability headroom.
Hey Roland, can you please contact me regarding your account at sanja@autoforums.com
or 416-341-8950
Sanja
Account Manager
Autoforums.com ( MINI2.com )
Canada   Reply With Quote
Old Mar 13th, 2008, 02:12 AM   #73 (permalink)
BigShow
Tunnel Runner
Lol.. they were awesome but I'm not even going there, even at £1525 for the pair... well... I say that now but they were soooooo nice Mmm.
Old Mar 13th, 2008, 02:30 AM   #74 (permalink)
BigShow
Tunnel Runner
Old Mar 13th, 2008, 03:56 PM   #75 (permalink)
-G-
Chasing 295bhp!
-G-'s Avatar
Check it out -G-... at this price surely you can't resist wading in
Price is more expensive if you order them in full leather isn't it mate? Extra £141?
1500 quid for Proper Gen 2 JCWs From Chris @ Derek Woodman..... Sounds like a bargain to me haha, I had a quick chat to him yesterday about them
GP 1021
Old Mar 13th, 2008, 04:04 PM   #76 (permalink)
BigShow
Tunnel Runner
Thats a good point but I won't tell anyone if you go for a bit of faux leather instead Come on -G- don't toy with me, have you just got your wallet out and bought some nice new Gen 2's? Don't do it for me , do it for the pride in knowing you'll have better seats in your motor than your boss does
Old Mar 13th, 2008, 09:14 PM   #77 (permalink)
-G-
Chasing 295bhp!
-G-'s Avatar
Thats a good point............... Come on -G- don't toy with me, have you just got your wallet out and bought some nice new Gen 2's?
No not yet mate, Loads of other stuff planned before the seats Also I need to know what is involved with regards to fitting
GP 1021
Old Mar 14th, 2008, 05:50 AM   #78 (permalink)
Silent1
Supercharger Noiseaholic
Silent1's Avatar
Send a message via MSN to Silent1
or 416-341-8950
Sanja
Account Manager
WTF Are PMs/telephones no good any more?
United Kingdom Male View Silent1's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 16th, 2008, 01:18 AM   #79 (permalink)
Revolution Mini Works
Mini2 Sponsor & Tuner
Local Time: 12:57 PM
thats about 1580d Farenheit
How long did it take you to get to that EGT?
Mine will run 1450 F on the track in the long straights in 4th/5th
I think the highest I saw it was 1530-1550
Manufacturer and Custom Mini Tuning
Old Mar 16th, 2008, 09:49 PM   #80 (permalink)
2 much
keep the faith i am sure all will be well when its been done i like the sound of the cooling vents looking forward to seeing them
England   Reply With Quote
Lohen throttle body? minioneandrew Engine & Drivetrain Tuning 3 Oct 16th, 2006 07:29 PM
NEW! Lohen 58mm Throttle body for the One/Cooper Lohen Engine & Drivetrain Tuning 0 Sep 18th, 2006 10:07 PM
NEW! Lohen 64mm Throttle body now available Lohen Engine & Drivetrain Tuning 9 Feb 1st, 2006 10:44 PM
M7 Throttle body jonnyc Engine & Drivetrain Tuning 17 Jun 27th, 2005 11:09 AM
Throttle body. GTT 280 Engine & Drivetrain Tuning 1 Feb 2nd, 2005 04:22 PM
