Visit Mini Mania UK
Old May 19th, 2008, 09:14 AM   #81
Japper
Japper's Avatar
Local Time: 09:11 PM
Quote: Originally Posted by MINIMANIAUK (original)
OK ,another positive report ! -so far only R53 and R56 cooper s its not quite the same as wearing bigger boots is it ?
So far all the reports from customers have been positive ,none returned,no faults,-japper is the only one I have heard of with a problem and none from any we have sent out .
They have been fitted on both remapped and stock ecus and both cases with positive results.
I have no idea why the ONE /COOPER owners are slow to take up the boosters?
Nothing wrong with the supplier or the actual product, just a addition required to the instructions from Sprint Booster them selves. Don't know which models of cars ( R53 / R56 etc. ) but on mine and many other BMW / Audi's you have to leave the car to stand without key in ignition for 20-30 mins, before attempting to fit this unit.
06 HB/W MCS Chilli
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 21st, 2008, 03:29 PM   #82 (permalink)
Den W
Now Aero Kitted!
Den W's Avatar
I'm really interested in getting this for my car,my only reservation is what haapens when/if the car goes back to Mini for servicing or warranty work would the ECU show up fault codes do you think? I've never worried so much about a car!! Want to mod things but so worried about voiding my warranty. If i never had one I would be bankrupt by now without a doubt the amount of times it's been back (i.e cold start issues, complete replacement of timimng gear to name but a few and its rattling again ).....still love the car tho!!
Den
United Kingdom Male View Den W's Lightning Blue & Body Color 2nd Gen MINI Cooper S Profile   Reply With Quote
Old May 21st, 2008, 05:08 PM   #83 (permalink)
Japper
Japper's Avatar
Den
It's a 5 min job to take off, but not sure about the ECU logging it's presence at all. Anybody have this fitted and access to scangauge?.
06 HB/W MCS Chilli
Old May 22nd, 2008, 02:12 AM   #84 (permalink)
Babes
Cruising In The Minge
Babes's Avatar
Local Time: 06:11 AM
Just waiting for mine to arrive and having it fitted at dealers so will ask them if it shows on their equipment. Well out of warranty now and they have fitted all my mods.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
1970 BRG/W MK2 Morris Cooper S
Australia Male View Babes's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 24th, 2008, 12:56 AM   #85 (permalink)
D-MAN
Local Time: 08:11 AM
Just bought one and I so how do you loosen the accelerator pedal module from the floorboard?
Australia   Reply With Quote
Old May 24th, 2008, 02:26 AM   #86 (permalink)
D-MAN
Just found the link posted by K-huevo earlier!!!!!
Old May 27th, 2008, 08:06 PM   #87 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Need some help please.
I not have sprint booster, Ive been trying to get the pedal off for the last hour. I can get it to move a little but then stops? I realise this may be the double catch thing, but how on earth do you get it all the way?
What tool did you use? Ive tried with a small penknive and a medium flat screw driver but just cant get it past. Any ideas?
Sorry, following the minimania instructions: SPRINT BOOSTER THROTTLE REMAP MODULE INSTALL R50/52/53 - MiniMania.com
United Kingdom Male View Mess's Astro Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old May 27th, 2008, 08:46 PM   #88 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 01:11 PM
Online
The DIY says ...
Press down the retaining tab (1) and remove the pedal from the adaptor plate by sliding it to the left.
Detach the plug connector (2).
Old May 27th, 2008, 09:00 PM   #89 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Quote: Originally Posted by MINIAC (original)
The DIY says ...
WOW! Gee Why didnt i think of that and following those instructions? Thats becase i dont need them! (following minimania guide )
If i wanted some instructions on how to remove it i would have asked, but again, if you read my original post correctly you will find im having trouble removing the catch! Thats i what i want help with! Not instructions!
Old May 27th, 2008, 09:12 PM   #90 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
Perhaps you should post some pictures so we know what you're talking about
Old May 28th, 2008, 04:23 AM   #91 (permalink)
k-huevo
Trailer Trash
Local Time: 04:11 PM
I used a brake shoe adjusting tool which has flat blades on both ends, but one end is at a right angle, this allows the longer shaft to lay relatively flat without a handle in the way. The shaft can extend the blade inside to release the latch from the back without binding against the channel. If the pedal housing is cocked it may not allow linear lateral movement.
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 28th, 2008, 04:55 AM   #92 (permalink)
Babes
Babes's Avatar
Got mine installed earlier today, got it done at dealers so as not to have any worries as the dude above seems to have, plus mine came minus any instructions. Luckily I had read the how to on here and told the dude what was required, im completely useless at this type of thing so wasnt even going to try myself.
The difference this has made to the car is outstanding! i have a heavily modified 03 JCW and this mod had me giggling like a kid all the way home from the dealers. At one stage i was running a 3%CP with JCW SC pulley but didnt like the way the car drove with it, so switched to 17%SC pulley and stock CP.
This mod gives me far superior pick up than what the lightened CP did. As has been said before it doesnt give you more power, just makes it available alot earlier in the rev range, same as a lightweight CP.
Without a doubt a must have mod. The service manager at the dealers was also very impressed and said he would recommend it to those who complained about throttle response. It was also undetecatable to the service computers.
2003 BRG/W JCW MCS
2002 PS/PS JCW MC
Old May 28th, 2008, 05:00 AM   #93 (permalink)
D-MAN
Quote: Originally Posted by k-huevo (original)
My experience may be different because throttle maps and other torque management features have previously been altered in my MINI via DimSport enabled tuning (John Behe/LDG). I felt throttle response after the LDG tune was as close to having a cable attached to the throttle plate as one could get; now with the Sprint Booster added, it’s telepathic.
Thanks for the tip K-huevo (you the man), I have had the sprint booster on for a week now and BROOOOM BROOOOM!
Heaps of fun, I was skeptical of how much of an improvement it would make to the throttle response of my car as I have an after market Thumper head and custom Dimsport tune along with a few other bits, but it was well worth the money (considering my wife spends more on shoes each month....).
After the head it was the best mod I have added.
Also it was the easiest mod I have added only took 30 seconds!
D-MAN
Old May 28th, 2008, 05:22 AM   #94 (permalink)
Silent1
Supercharger Noiseaholic
Silent1's Avatar
Local Time: 10:11 PM
Send a message via MSN to Silent1
I find this quite interesting, when i mash the pedal in my 'S the boost gauge rockets up at the same time, there's no delay.
Adam am i right in presuming this tricks the stepper motor into banging open the throttle butterfly exacerbating the problem the 'S has of going lean when you first go WOT
United Kingdom Male View Silent1's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 28th, 2008, 06:21 AM   #95 (permalink)
MINIMANIAUK
MINI2 Sponsor
The throttle plate is opened faster not further so boost comes up faster not more. The injector reaction is far quicker than any throttle speed and on throttle opening the sense line pre charger adds fuel -so running lean should not happen.
I sense that some of the early scepticism is reducing -they do work!! and becoming a "must have mod"
Old May 28th, 2008, 09:38 PM   #96 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Had another go this morning with a smaller screw driver (the one that came with the mini car jack actually) And came off straight away!
Plug and play! Great Stuff! took 2mins.
Start it up and WOW. Throttle response is immediate.
Power there straight away instead of having to rev it all the way up. Yes i doesnt give more power, its just there sooner. Couldnt stop laughing and grinning all the time i was driving, so much fun.
Even in 5th gear at 70+ when you push the thottle, it just blows you away!
Well worth the money!
Oh and i have an 06 Reg R50 Cooper!
Old May 28th, 2008, 11:58 PM   #97 (permalink)
MINIMANIAUK
MINI2 Sponsor
from pre fitment .......
"Yeah your right. Price is a little high for what it is.
I think ill not be investing in 1 until they a little cheaper."
to post fitment .....
"Couldnt stop laughing and grinning all the time i was driving, so much fun.
Well worth the money! "
Old May 29th, 2008, 08:26 AM   #98 (permalink)
alski
dyno-mite, might not....
alski's Avatar
almost embarrassed to bring this up, but has anyone done b4 and after 0-60 0r 30-70 etc
on private road etc, etc, with proper timing equipment etc, etc,
carefree
Old May 29th, 2008, 12:25 PM   #99 (permalink)
Mess
Go Go Gadget Mini
Mess's Avatar
Online
Thumbs up
lol touche
Old May 30th, 2008, 01:45 PM   #100 (permalink)
MINIMANIAUK
MINI2 Sponsor
Via a satellite live link to the atomic clock and taking into account the curvature of the earth - it was faster !!!!
OAT =20
air pressure 1022mb
wind =1 kt
alt 200 asl
driver -fat
18" wheels
Sprint Booster Throttle Remap MINIMANIAUK MiniManiaUK 11 Nov 7th, 2008 04:12 PM
Sparco Sprint leon1982 Interior & Ice 7 Oct 22nd, 2003 03:26 PM
Abingdon Sprint - JCW Report John Cooper Works MINI in Motorsport 13 Jun 14th, 2002 04:42 AM
Sprint @ Abingdon Dom MINI in Motorsport 14 Apr 5th, 2002 10:40 AM
MINI Sprint monsta Future Variants 5 Feb 28th, 2002 08:02 AM
