| Tags: crank, diameter, pulley, supercharger |
| Supercharger Noiseaholic | Supercharging info/ratios/speeds Right, i've seen a few threads asking about the Cooper S supercharger ratios / speeds I've managed to source all the info for the stock pulley and for the Eaton M45 so here goes: The stock crank pulley size is stated by MINI as 140mm The stock supercharger pulley is stated by EATON as 65.5mm This gives a ratio of 2.13 meaning at 6,750 rpm the supercharger is spinning at 14,427 RPM Eaton state the maximum RPM for the M45 is 16,000rpm So to stay within their tolerances when getting a smaller supercharger puller, the smallest you could get would be ~59mm So that would equate to approximately a 10% pulley For boost pressure i've had to base it on 4 degrees of overlap as i can't find any other info: So with standard pulleys the supercharger produces 14.63 PSI With a 15% pulley the supercharger produces 19.87 PSI With a 17% pulley the supercharger produces 20.84 PSI With a 19% pulley the supercharger produces 21.66 PSI All of these are based on theory, they don't take into account thermal inefficienies due to going over the max RPM If anyone wants to look at the excel spreadsheet i've created to work these out, PM me |
| MINI2 Newbie | I got probs to understand ![]() So you mean, with a 15% pulley, it is already out of tolerances ? 'cause i doubt JCW will go out of tolerance, on the GP it is 14.xx pulley and 7250rpm ! If you can explain me please ![]() And all Cooper S Tech docs said 11,60PSI (0,8bar) with the orginal pulley ! |
| Supercharger Noiseaholic | Ok, the equation i used for the pressure from the supercharger is as follows: Pulley Stock S/C CC/rev 750 Engine CC 1600 Pulley Ratio 2.13 Atmospheric Pressure 14.7 Valve Overlap 4 (((750/(1600/2)*2.13*14.7)-14.7)-((4/10)*0.05) = 14.6340625 Boost 14.6340625 Do point out anything you think is amiss from it, i'm going to see if i can remember any other equations, and if i can find the info for the valve overlap on a standard cam (the 4 degrees is a shrick fast road cam) |
| | #7 (permalink) |
| Trailer Trash Join Date: Mar 2005 Location: Pipe Creek, Texas Local Time: 08:39 AM
Offline | Silent1, I’ll add tolerance stacking and differences in volumetric efficiency as other variables. On my vehicle with head/valves & exhaust manifold improvements, the highest pressure documented was 17psi, on a 101 F day with a 19%. Stock head, cat back, and 15%, saw 16psi on a very hot day, both attained on a dyno. I know this is an exercise and thank you for the effort. tirlibibi, the JCW pulley is 58 mm OD. If you use the Eaton OD stock measurement it would be ~11.5% smaller. I’ve measured more than a few of both pulleys and have not seen anything smaller than ~10.9% reduction in comparison. |
| | #9 (permalink) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 02:39 PM
Offline | and dont forget the supercharger power comsumption from crank is non linear and rpm dependent.and the effect of turbulence within charger,and altered clearances between rotor/case, and altitude -give up yet ![]() |
| | #10 (permalink) |
Offline | Here is something else to consider, boost is formed in the intake manifold, not the Roots SC. Eaton’s supercharger is not a compressor, it moves air into the IM faster than it can be consumed, and air stacks behind the intake valves creating pressure above atmospheric. This is the reason changes downstream of the supercharger (VE improvements, valve overlap/cam profile, etc.) can affect boost and why best case pressure calculations are not valid in all situations; although, good for SC rpm comparisons. |
| | #17 (permalink) |
Offline | No its not rocket science,but there are a lot of things happening at the same time ,not many of them linear, so trying to do spreadsheets and ratios ,and get accurate data is impossible . even the throttle size/opening and filter and all intake pipework ,can effect the boost ,and the quality of air output Im sure your efforts and intentions are good ,but the answers not that easy to predict. and the biggest and most important of all the factors are thermal inefficiencies ,a combination of effects. Quality of boost air pressure is more important than the quantity of boost pressure,and Flow is what should be investigated and tabulated . |
| | #18 (permalink) |
| Supercharger Noiseaholic | Where did i suggest it was? Oh indeed, that's why i don't intend on produce 'a' formula, i intend on measuring and looking up the study of it and coming back with a range of answers. The main reason i'm doing it is to see what can be done with the standard set up as i refuse to beleive it can't be improved and it's easier to replace when it goes bang |
| Supercharging a Cooper | craigoz | Engine & Drivetrain Tuning | 5 | May 12th, 2006 04:52 AM |
| Turbocharging Vs Supercharging | Themikanic | MINI Cooper S | 16 | Jan 12th, 2005 03:47 AM |
| Supercharging a Mini One | Miniheffer | Engine & Drivetrain Tuning | 2 | Aug 17th, 2004 09:37 PM |
| Supercharging standard cooper | Claire Elise | MINI Cooper | 15 | Nov 10th, 2003 12:57 AM |
| Negative Supercharging | GordonD | Engine & Drivetrain Tuning | 6 | May 13th, 2003 12:06 AM |
