| Tags: 1320, bhp, rmw |
| | #181 |
| Tunnel Runner | Come on guys, would I realy try and make my car permanentl quieter? My Tunnel Running credentials would be ruined forever In fact after hearing Joel's on the last TR I was even thinking about fitting a Borla Race version Still haven't found out what system he was running.The stock one will just be for Bedford. The noise limits at Bedford Autodrome are 101dB(A) static (measured 0.5m from the exhaust at a 45’ angle at ¾ maximum revs) and 87.5 dB(A) drive-by at 20 metres. They are now operating a ‘one strike and you’re out’ rule. This effectively means that if your car exceeds the drive-by limit, the driver will be black flagged and that car will not be allowed to take any further part in the track day. So it's just not worth taking the risk. Last time I hit 98db static but it's the drive-by level I'm worried about as the car is now considerably louder under WOT... did think about a silencer for bolting on, but getting one to fit the milltek won't be cheap so 1320 can fit a second hand stock exhaust easy enough which also enables me to prove what the gains or otherwise are available by having the Milltek too. Tempted to put a stock CAI back on too and just having... GRS, Cam, Head, Plugs, Janspeed, 17% Pulley, Remap, Injectors... just imagine if that little lot gave more than 281 bhp... that's some cheap power right there if it does ![]() But I would miss the S/C whine and it goes without saying I need the exhaust for future tunnel runs (next one 10th May btw). |
| | #182 (permalink) |
![]() MINI2 Master Join Date: Aug 2006 Location: Modena IT /Camberley Local Time: 10:05 PM
Offline | MMMM I think I would fail both of those tests Pity I can not do the next tunnel run, it would be good to hear mine rasping through those tunnels. In Italy |
| | #183 (permalink) |
| MINI2 Master Join Date: Jul 2005 Location: Beds Cambs Northants Local Time: 09:05 PM
Offline | I would have to bring ear defenders along if you came along ![]() Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #184 (permalink) |
| I can't get no sleep Join Date: May 2002 Location: Capital of Culture Local Time: 09:05 PM
Online | Why are the noise limits so low at race tracks? A customer took me out in a Ferarri 360 Challenge Stradale today - now that was noisy ![]() But we was moaning about not getting let on tracks |
| | #186 (permalink) |
Offline | We're about 3 -4 miles away as the crow flies and if its a still day we can here them going around the track. Unfortunatkey the residents were there before the race track , drag racers use to moan about not making noise as new housing estates were built nearby but then found that puting mufflers (silencers) back on actually gained them trq / hp.Personally I rather have a real quiet exhaust sytem so I can nail it when I want to without people knowing. If everyone had to run a really quiet exhaust sytem to keep a track open you would adapt to that situation. The funniest thing was sitting in old red strapped in with my helmet on in the fire up road and I could here Ben going up the strip at the Pod. Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #187 (permalink) |
| Tunnel Runner | The Stradale can't get on any UK circuit now because once the exhaust valves open its like having a team of really small F1 engineers benchtesting one of their V8's inside your ear drum... and that's just from the inside! De-cat it and put a Capristo Stage 3 on and it's indistinguishable from an F1 V8 at 8,250+ Most tracks are now clamping down because of complaints from residents who live nearby, even Silverstone has reduced its db level to 105 ![]() That was with the old Powerflow with the one branch single silencer and squashed bean can exit pipe... Good times ![]() |
| | #190 (permalink) |
| MINI2 Senior | Look what we started paul! Somehow I damaged my milltek, it was fine when I first had it but then I had this annoying noise, I did breifly ask Paul when I took my car to 1320s but it was so hard to diagnose and we were at the end of the day. The symptons was a small rattle as the engine came under load from pulling away, you could hear it more so If I slowly let the clutch out as if I was about to stall. I was convinced it was the tail pipes rattling against the rear bumper, anyway it was diagnosed. Probably just a one off or something, in every other way the Milltek was fantastic! Follower of 1320autos + GTTuning |
| | #191 (permalink) |
Offline | Yup like I said earler it was "just one of those things" but we new something wasn't right and we just had to work out which part wasn't doing the job as it should ![]() Though the 2nd owner of said system felt the difference on his butt dyno and then confirmed it on our dyno ![]() Slicks 11.77@115.92mph Street tyres 12.162 @ 119.02 It's not how much you spend but how well you spend it |
| | #193 (permalink) |
| MINI2 Master | Also where can i purchase one of these German JCW systems from, I have to admit i keep looking at these OMP group N systems, as i guy i know has one on a Fiesta ST and it sounds the ****, keeps making me think i'm standing in the Welsh forests on a stage when i hear it, |
| | #195 (permalink) |
Offline | Ant If you want a German JCW back box system mine will be available soon. Send me a PM My current system is JCM 4/2/1 manifold, high flow sports cat and JCM German challenge rear box setup. It is what is known as full pipe - the whole length of the silencer pipe is drilled In the GP it is just too loud, will be changing the back box set up to JCM UK Challenge soon, this is a half pipe set up - only half of the silencer pipe is drilled so much quieter but still free flowing. Neither set up has the flat piece as found in The JCW standard set up In Italy |
| | #198 (permalink) |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 09:05 PM
Offline | The thing with exhausts is that the are designed for one application, Knowing the back pressure is a guide to the flow of the exhaust , but they are tuned length pipes and the engine provides pulses of exhaust pressure, and sound pulses these shoot down the pipe and back and the timing and frequency of these effect the flow of exhaust gases and hence the power As soon as you change something like a pulley or head you alter the speed of the air flow ,this alters the pressure wave , and alters the temperature of the exhaust gas , The tuned length pipe is no longer tuned to your engine!!!! All exhausts are built and designed for the stock application,and may or may not work well with altered components. Most manufacturers dont have the budget for long development programs and test on one stock car, its when you fit an exhaust on a stock car and it drops power that there is a fundamental design flaw ( these are usually found on ebay) ![]() |
| The Following 2 Users Say Thank You to MINIMANIAUK For This Useful Post: |
| | #199 (permalink) |
| Tunnel Runner | Cheers.. on the second run the 'crackling' as my car overtakes another Mini is just the sonic boom Once its remapped next week and the 440's are on I'll do a proper video and publish my Evo style write up with independant dyno results and performance box figures for those that are interested. |
| RMW Power Pack Arrives | BigShow | Engine & Drivetrain Tuning | 48 | Apr 18th, 2008 08:22 PM |
| RMW (Jan) Tune - Best mod by far | Bzzz Bom | Engine & Drivetrain Tuning | 78 | Dec 30th, 2007 02:26 AM |
| Car on the rollers at 1320 today Results! | lucachiarelli | Engine & Drivetrain Tuning | 24 | Nov 24th, 2007 09:45 PM |
| Tuning results posted by companies, diff for 163 vs 170? | sam_pd | Engine & Drivetrain Tuning | 7 | Jan 21st, 2007 01:29 PM |
| GT TUNING / MILWAY R'Road Day -RESULTS! see post#1) | roland2003 | UK & Ireland Discussion & Event Planning | 145 | Mar 16th, 2005 05:44 PM |
