| Tags: boost, gauge |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 07:22 PM
Offline | Calling people who have fitted a boost gauge Just fitted my boost gauge today. Just want to see what idle vac pressure others have seen. Mine is around -16 when on vac. Also when you put your foot down (so the gauge goes from vac to boost) I have noticed a slight noise on the gauge, is this normal as its quite annoying ![]() James Last edited by Jaw_F430 : Apr 19th, 2008 at 02:34 PM. |
Offline | The gauge is a autometer pro comp ultra lite. Install was quite easy, my car is a 2005 so were normally you need to punch a hole in the grommet to get through the firewall, mine had a nipple there already-just need to cut the end off it. I have not connected the 12V supply yet though,just want to be sure I am keeping it before splice into a cable. |
| | #6 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 07:22 PM
Offline | yeah I would have said around -10 too.... I use the T-MAP sensor for my boost readings and thats usually about 5PSIA at idle so must be arouind -10PSI at sea level ![]() |
| | #8 (permalink) |
Offline | All the post above are leading me towards having a faulty gauge maybe. I will have to look in to the further tomorrow just to check that the nylon pipe is not touching anything when it boosts. |
| | #10 (permalink) |
| Mighty Mouse Join Date: Feb 2007 Location: Maitland Local Time: 04:22 AM
Online | G'day James I've fitted an Autometer Ultra Lite boost gauge into my car and the sound your hearing when your car suddenly goes into boost is normal for the mechanical gauge. The sound is usually only apparent when you jam your foot down on the go pedal - I've grown to enjoy the sound. Besides with a CAI and exhaust the sound all blends together nicely .Cheers Darrin |
| | #11 (permalink) |
| Cruising In The Minge | I have the OEM upper gauge kit MINI Cooper S Gauge Kit: Boost + Volt Meter Perfect as it matches all the other gauges, about -10 on idle and off the dial on full boost ![]() No noise. ![]() 2002 PS/PS JCW MC 1970 BRG/W MK2 Morris Cooper S |
| | #13 (permalink) |
| JCW 210 "apparently" Join Date: Feb 2007 Local Time: 07:22 PM
Offline | I have the OEM upper gauge kit when I fitted it I did notice a very faint noise that wasn't there before, what it was for me is I did not push the grommet back where I ran the vac pipe through, I see about -10ish idle and about -20 on engine brake |
| | #18 (permalink) |
Offline | May end up taking the boost gauge off the I cannot get rid of the noise as it does my head in ![]() Spoke to the supplier of the gauge and they said its a normal noise due to the movement. Going to make a restrictor for it as I cannot find one the size I need and if noise can still be heard then there will be a boost gauge for sale ![]() ![]() James |
| just fitted my boost gauge | Munnster | General Discussion | 6 | Apr 19th, 2005 06:25 PM |
| Boost Cass --> Boost CD upgrade (HK fitted) | john_o | Interior & Ice | 0 | Jan 10th, 2005 07:36 PM |
| Calling all people who are from aston or birmingham uni. | eddie_DV52_CCZ | UK & Ireland Discussion & Event Planning | 1 | Oct 13th, 2004 01:25 PM |
| has any 1 fitted one of these boost gauge packs b4 | Munnster | Interior & Ice | 4 | May 12th, 2004 12:15 PM |
| Has anyone fitted a boost gauge? | ingesson | Engine & Drivetrain Tuning | 4 | May 6th, 2003 09:40 AM |
