GizzmoUSA
Old Apr 22nd, 2008, 08:03 PM   #1
Jaw_F430
Jaw_F430's Avatar
Local Time: 09:06 PM
Gaskets for Janspeed manifold to cat
What gaskets are people using for the cat when fitting their Janspeed manifold. I have the OEM ones at the moment but ideally I am after a thicker gasket that can be squashed slightly to give better seals as the flanges are not 100% square.
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 22nd, 2008, 08:39 PM   #2 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Cat back is usually stock and the manifold to cat is usually a metallic mix gasket that fills the gaps Well thats my experience on other brands.....
Old Apr 22nd, 2008, 09:40 PM   #3 (permalink)
Jaw_F430
Jaw_F430's Avatar
Do you know where I can get one from?
Old Apr 22nd, 2008, 09:42 PM   #4 (permalink)
Lucky Dave
Thinking Minis
I went to a local motorfactor and they found one that fitted spot on, I find the OEM one is not large enough and did not seal mine.
For All Your Mini's Needs
01905 620011
Old Apr 22nd, 2008, 10:03 PM   #5 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
Are you going to port match your manifold + gasket with your stage 4 gtt head ?
Old Apr 22nd, 2008, 10:11 PM   #6 (permalink)
Jaw_F430
Jaw_F430's Avatar
Quote: Originally Posted by 300GP (original)
Are you going to port match your manifold + gaskit with your head ?
Done that when I had the head and mani on the bench, just when I put the mani+cat on I can hear a slight hissing noise which sounds like there is a leak around the cat but on tick over if I put my hand over the cat I cannot feel a leak.
I am thinking it happens when under load and want to seal it better
Old Apr 22nd, 2008, 10:18 PM   #7 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
jaw Fit two copper gaskets it gives a great seal Robertshaw racing does it, it works great...
Old Apr 22nd, 2008, 11:01 PM   #8 (permalink)
MINI-Morgan
MINI Obsessed...
Old Apr 23rd, 2008, 05:41 PM   #9 (permalink)
Jaw_F430
Jaw_F430's Avatar
Do you know where I can get copper ones?
Group Buy: 1st Gen Janspeed Manifold & Cat £379 (Inc vat) Vecchio Engineering Vecchio Engineering 25 May 22nd, 2008 11:18 AM
Janspeed Manifold & Cat batou Lohen 9 Apr 22nd, 2008 03:25 PM
NEW! Janspeed Manifold and removable high-flow cat Lohen Engine & Drivetrain Tuning 15 Mar 2nd, 2006 02:43 PM
GT Tuning& Janspeed Sports Cat&Manifold SPECIAL Mini2 PRICE £349+ vat See Post 6 roland2003 Engine & Drivetrain Tuning 45 Feb 1st, 2005 01:26 PM
