Carccessory.com
Tags: , ,
Old Apr 24th, 2008, 07:43 AM   #1
Woolly44
woolly
Woolly44's Avatar
Local Time: 10:07 PM
Send a message via MSN to Woolly44
Cooper head to JCW head
Hi, i have recently bought a 210 bhp JCW cylinder head and am going to fit it to my 01 mini cooper, however i am unsure about the timing chain as i have only ever worked with cam belts has any1 ever performed this before? could anyone provide a step-by-step guide to removing the chain and head.
thanks Ben
United Kingdom Male View Woolly44's Blue Green Flip & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 24th, 2008, 08:36 AM   #2 (permalink)
MINIMANIAUK
MINI2 Sponsor
Local Time: 09:07 PM
If the change over is to increase the performance you will be dissapointed -the head is nearly identicle other than slightly larger exhaust ports ,and these were made larger for the cooper s application
The same inlet valve size ,cam,inlet ports would mean the same amount of air is being sucked in as previously hence no increase in performance.
If it is due the original head failing ,fine and I would suggest getting either a haynes manual or the better Bentley manual -then you have a permanent reference for future use
Old Apr 24th, 2008, 09:10 AM   #3 (permalink)
Woolly44
woolly
Woolly44's Avatar
when i spoke to someone i no at mini in sutton he said that the jcw head was polished and bored and the cam has a higher lift than that of a standard cam, and that the valves are bigger than normal, is this not true?
Old Apr 24th, 2008, 09:13 AM   #4 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 04:07 PM
+1 on Bentley.... I just got mine in the mail and it is one of the best that I have seen.
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 24th, 2008, 09:14 AM   #5 (permalink)
lucachiarelli
Banned
Dont think thats true. Did you buy cams, valves etc with it?
England Male View lucachiarelli's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 24th, 2008, 09:18 AM   #6 (permalink)
Woolly44
woolly
Woolly44's Avatar
nope the whole lot is already there valves, cam, even the plugs are there, its brand new in the box, i only paid 250 for it but bought all the gaskets and head bolts yesterday for it and was hoping to fit it this weekend
Old Apr 24th, 2008, 09:24 AM   #7 (permalink)
MINIMANIAUK
MINI2 Sponsor
All parts same cam valves etc -sorry
Old Apr 24th, 2008, 09:36 AM   #8 (permalink)
Woolly44
woolly
Woolly44's Avatar
ok thanks m8 looks like it will b going up for sale then
Old Apr 24th, 2008, 09:46 AM   #9 (permalink)
Ant FR
personally, i wouldnt have bothered as i know of a few guys who have done just that and have got no difference at all, 2 of them had dyno proof.
Although as mini mania and lohen will both tell you the right head and cam can make a difference on the cooper. As long as you have takled the usuall suspects first like manifold .
i remember when i was at Rolands i was able to see all the heads together and the JCW one really is a bit lacklustre, the difference was not a lot, Even when Roland compared it to the wilcox heads ( which i belive he still has a few left) it was notciably smaller. they were 349 from memory. and then there was a huge jump to stage 2 and 4.
Would it not be worth doing that. or at least pop a proper cam in, the schrik is what Lohen use in their demo car.
Just seems to me ripping off the head is not something you want to do all the time, so when you do it you may as well do it properly
Old Apr 24th, 2008, 09:55 AM   #10 (permalink)
Woolly44
woolly
Woolly44's Avatar
ye i mite by a new cam and maybe have the works head gas flowed and some bigger valves ground in. then put the complete head on instead of using mine, seems a shame to waste a brand new head.
Old Apr 24th, 2008, 09:58 AM   #11 (permalink)
minicabrio
Sing-a-long MINIer
minicabrio's Avatar
Just a thought too, as yours is an 01 Cooper, you may want to think about a gearbox upgrade to the Cooper S box first.... the Midland box is renowned as being a weak point, and if you're looking a cams, heads, manifolds etc - it may not last too long
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 24th, 2008, 10:07 AM   #12 (permalink)
Ant FR
Speak to 1320, hes done the 6 speeder conversion.
Old Apr 24th, 2008, 10:15 AM   #13 (permalink)
Woolly44
woolly
Woolly44's Avatar
cheers will do i could get a 6 speed box straight away as well as my friend has just wrote his cooper s off
Old Apr 24th, 2008, 02:01 PM   #14 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
I've got a brand new set of Ultrik Performance Valves (see MiniMania website for details) - £160 inc P&P - PM me if you are interested
Vroooom Vroooom
Difference in JCW head vs OEM head Jaw_F430 Engine & Drivetrain Tuning 6 Mar 31st, 2008 11:42 PM
jcw head CC07ERS Engine & Drivetrain Tuning 3 Sep 18th, 2006 06:29 PM
head gasket / knackered head arrgh welsh_willo Faults & Fixes 0 Feb 3rd, 2006 10:38 PM
JCW Cooper S head mods,what do they do to it exactly? roland2003 Engine & Drivetrain Tuning 7 Jul 21st, 2004 04:27 PM
head unit causing my head to spin!! kars Interior & Ice 10 Oct 29th, 2003 04:54 PM
