| Tags: exhaust |
| MINI2 Senior | De-cat pipe Just interested to know how many of you guys are running De-cat pipes on the road Graham ![]() |
| Overly excited!! Join Date: Aug 2006 Location: Worcestershire Local Time: 10:36 PM
Offline | At the moment, I am. I blew a bit of a hole in my cat, and crushed some of the cells. I'm looking at getting a new manifold and cat at some point. Some reports have shown that without a cat you loose performance. |
| MINI2 Sponsor Join Date: Mar 2006 Local Time: 10:36 PM
Offline | A cat must form a restriction to flow ,by virtue of it having a cross sectional area and being in the pipe!! probably a low restriction 1-2 psi drop but a restriction - they will also absorb some heat ,cooling very slightly the pipe/air temps after the cat . This will release 2 or 3 bhp if removed -PROVIDED that the cat shape and size canister remains-sustituting a straight pipe in place will alter the airflow/pulses in the whole system and hence could actually lose a couple of bhp , The cat does however break up sound waves and cars are very loud with out the cat. Any rich running cars or overfuelling or slow starting that allows fuel down the manifold and into the cat will ruin the cat quick smart , this could lead to a MOT fail and manifolds/cats are not cheap. The "green" issue is not that clear ,as usual , it is overlooked that the cats themselves contain undesireable metals ![]() A bit like the leaded/ unleaded fuel thing where for years we were told the lead is killing our kids- then we stop using leaded -and presto ......its now thought it was lead in paint that was the problem and it uses more oil to produce unleaded against leaded ![]() |
| | #8 (permalink) |
Offline | "Mine runs better with the cat in." This is very likely ,the cat has to be substituted with an expansion chamber of similar dimensions. The position of the cat is important also ,they should be a multiple of the distance of the primary pipe length or the same as preferably , this is far more critical in a 4-2-1 manifold than the 4-1 . But even the 4-1 is likely to lose power with a straight replacement pipe . The 4-1 manifolds have longer primary pipes and the cat should be as far back as those ,but the position of the cat sensor wires is fixed which limits this and the the cat cannot go too far back as it has to get up to temp quickly to operate correctly Even with compromises aftermarket manifolds are still better than stock |
| | #10 (permalink) |
Offline | the gain is very little 1-2bhp , but it allows the cat to be replaced easily and refitted easily ,prolonging the cat life ---the noise however increased !!! How is the torque on your car post manifold? |
| | #11 (permalink) |
| MINI2 Regular | the torque is much improved , the noise is not extreme untill you get high up the rev range. What is the typical bhp increase you have seen with your manifold as i have not had it dyno'ed yet. Also if i decide to fit the cat & it fails how much is a replacement cat from yourself. |
| de cat pipe. | westycoopers | Engine & Drivetrain Tuning | 7 | Apr 10th, 2008 02:42 PM |
| SOLD : GTT Manifold & Race Cat / Janspeed De-Cat Pipe | TallAndy | For Sale | 6 | Nov 17th, 2006 11:13 AM |
| Cat Replacement Pipe | Silver Bullet | Engine & Drivetrain Tuning | 3 | May 2nd, 2004 12:05 PM |
| Magnaflow with a de-cat pipe | Dark Mini | Engine & Drivetrain Tuning | 4 | Sep 25th, 2003 08:00 AM |
| Cat Bypass Pipe | mainlinemenace | Engine & Drivetrain Tuning | 3 | Oct 8th, 2002 10:19 AM |
