| Tags: engine, mods |
| MINI2 Regular | Mods To Protect Your Modded Engine.... what mods should there and what should you do to keep your modded engine safe/reliable?:- a regular oilservice/belt change at appropriate intervals tensioner limit stop - lohen, gtt, etc gtt tensioner pulley setting a safe rev limit? <7250?? ?decent radiator ?go aftermarket?-notice minimaniuk are advertising one ?aftermarket header tank,silicone hosing ?a more robust oil pump? is there an aftermarket kit out there? uprated injectors anyone agree/disagree/have further suggestions? i'm a mini newbie so go easy on me! i've seen some heated threads on here! lets say we're talking about your average modded cooper with a 15% sc pulley, a 2% crank pulley, an uprated intercooler, a cylinder head and a remap. (which is what i have except the crank pulley) sy dr. blaze bbr 250 |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 10:51 AM
Online | Good thread topic SY , everyones always talking peak power , but never preventative maintenance. This is an area we put great emphasis on with all our conversions. All the things you list are worthy of discussion in this thread. ![]() |
| Track Addict Join Date: Mar 2003 Location: Sydney Local Time: 07:51 PM
Offline | Hi, I have a few suggestions to add to your list. These are all mods that add to longevity rather than performance.
Cheers Robbo Mods: GO MADDIE and SPARKY! |
| | #11 (permalink) |
| MINI2 Regular | re: have a look, they're basically cheaper to buy and import directly yourself - don't fotget vat, savings ranging from £50-£100 depending on who you buy from. - while the pound remains weak... REMOTE OIL COOLER - MiniMania.com oil cooler - MiniMania.com OIL COOLER KIT - MINI COOPER S 2002 - 2006 - MiniMania.com Madness MINI Cooper S Engine Oil Cooler - MINI Cooper S engine Oil Cooler dr. blaze bbr 250 |
| | #12 (permalink) |
| MINI2 Regular | think how far you plan to go with tuning,what you intend to use the car for,then decide what is needed.i really dont tink you need oil coolers unless you plan on tracking lots. you can over cool oil btw Last edited by sillycar gt4cs : May 5th, 2008 at 02:54 PM. |
| | #13 (permalink) |
![]() MINI2 Master Join Date: Aug 2006 Location: Camberley, Surrey Local Time: 10:51 AM
Offline | One other key thing to consider especially with a heavily modded car Bring it up to proper operating temp (water and more importantly OIL) before giving it the beans Fuel grade and AFR are also key for longevity of the motor. In Italy |
| | #15 (permalink) |
| MINI2 Regular Join Date: Sep 2007 Local Time: 10:51 AM
Offline | Hmmm, as I don't intend to take my rpms any higher, is an oil cooler required, also, have ordeextra gauges, oil pressure, oil temp. Have Sat Nav though, so no visible indicator for water temp. Should I get a water temp gauge too? Sooo much to do!!!! |
| | #16 (permalink) |
| The Power Cube | Oil Cooling Note the OEM blue cooler. ![]() Is it required? ![]() This also looks useful... The Pressure and Temp gauge locators look useful. ![]() Too many mods to list, PM me if the cat needs killing... Last edited by MINIAC : May 5th, 2008 at 06:07 PM. Reason: Attach images |
| | #18 (permalink) |
Offline | Hi, I absolutely agree. You need an oil temp gauge before you can decide if you need an oil cooler. If you are hitting oil temps greater than 125-130C then you need a cooler. Realistically this will only be an issue for people who are tracking the car. There is an enormous difference between "spirited road driving" and racing / tracking the car. Cheers Robbo Mods: GO MADDIE and SPARKY! |
| | #19 (permalink) |
| MINI2 Regular Join Date: Oct 2007 Local Time: 11:51 AM
Offline | I think a good idea is to get oil temp and oil pressure gauges, so that you can monitor the way you're lubricating your engine. This is very important. Also, AFR and EGT gauges can help monitor if you're in risk of melting something because you're too lean. After this, I'd say an oil cooler only if you see you need it, and changing belt and plugs often as already mentioned. |
| | #20 (permalink) |
| MINI2 Senior Join Date: Jul 2007 Location: 7600rpm Local Time: 10:51 AM
Offline | Normal road driving won't need an oil cooler, but I remember one day I was running late to meet up with a few friends to go Karting and I had to hammer it to get there on time and my oil temp was not far off 160C ( between *30 and *40 all the way there ) |
| advise on first engine mods! | JMCS08 | Engine & Drivetrain Tuning | 14 | Feb 25th, 2008 05:49 PM |
| advice on next engine mods | plush-automotive | Engine & Drivetrain Tuning | 4 | Apr 29th, 2007 02:41 PM |
| Few engine bay mods | Richard22b | Engine & Drivetrain Tuning | 13 | Apr 17th, 2006 12:57 PM |
| If you have aftermarket engine mods ... | MINIAC | Southern California Region | 3 | Mar 14th, 2006 09:30 AM |
| If you have aftermarket engine mods ... | MINIAC | Northern California Region | 2 | Mar 14th, 2006 09:22 AM |
