| Tags: asc |
| MINI2 Regular | asc light Could anyone out there shed some light as to why my ASC light comes on when i drive that the car hard I.E it tends to light up at 6500 RPM in 3rd Approx 110mph. This keeps the traction control off until i stop the car & switch off the ignition, this then resets the traction control & works fine until next time . |
| MINI2 Regular | i have the jcw (approx 11%) + the GTT +3% lightened crank pulley. this should mean around the equalivent of a 15% supercharge pulley on a stock MCS. Lots of cars run that , Do they normaly have this issue? How does a excessive boost pressure cause the ACS light to come on ! by the way i know there's a high boost as the small snoot boot keeps blowing off, I'm going to order some 5 ply ones fron GTT in the morning. P.S thanks for a quick responce. |
| | #7 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 09:10 PM
Offline | lots of cars have the problem. its a feature But I cant answer if its the records boost pressure for the engines calculated torque figures that actually cause the traction control to shutdown.When you give Roland a call mention it and see if he says the same ![]() |
| | #9 (permalink) |
| Track Addict Join Date: Mar 2003 Location: Sydney Local Time: 08:10 AM
Offline | Hi, Go to a garage that has a code reader and get the fault codes downloaded. That is the only way to know for sure. It could be overboost, it could be a faulty sensor, it could be a lot of things. The only way to know for sure is to look at the fault codes Cheers Robbo Mods: GO MADDIE and SPARKY! |
| asc + emissions light | PR04SAT | Engine & Drivetrain Tuning | 12 | Feb 17th, 2008 06:36 PM |
| Undocumented warning light... ASC+T?? | batou | Faults & Fixes | 20 | Jan 9th, 2008 04:19 PM |
| asc warning light coming on | george p | Engine & Drivetrain Tuning | 21 | Jan 4th, 2007 09:37 AM |
| Faulty ASC Light | claudeG | Faults & Fixes | 2 | Oct 23rd, 2006 02:50 PM |
| ASC+T Warning Light | Gemini4321 | Faults & Fixes | 13 | Feb 9th, 2006 04:33 AM |
