Wipac
Old May 17th, 2008, 12:47 PM   #1
philly c
philly c's Avatar
Local Time: 09:05 PM
Big Bad Boy Brakes Vs Discs&pads
Hey all
Its been along time but i have a prob youe u all I up rated my pads and as i thought would happen, the discs have worped to the point of serious shakking and feed back through the steering wheel. I am wanting to up grade the discs to tarrox drilled and grooved. However i have a number of considerations....
R56 CALIPERS AND BRAKES???
bIG BRAKE SET UP BUT UNDER £1000
OR PADS AND DISCS??
Has anyone any thoughts on this one i was thinking that unless a spend a small fortune i am not really going to get the best out of a cheeper big brake set up and so i thought discs and pads.
I know brake fade will be much better with a disc and pad set up including a better 5.1 brake fluid but i know stopping power will ot be as hot as some set ups. But do the cheeper set ups such as AP really offer performace or is it just the ilimination of brake fade??
Any thought wopuld be great
cheers
Phil
V6 PHL
Old May 17th, 2008, 01:55 PM   #2 (permalink)
MINIMANIAUK
MINI2 Sponsor
Discs can warp ,especially if worn thinner ,if the brakes are not released after a big stop due uneven heat dissipation.
Brakes are all about heat and the ability to disperse heat - larger discs help ,drilled discs do very little ,groved discs help keep pads clean and stop glazing.
larger calipers provide more clamping force as they have greater piston area or more pistons
any brake is only as good as the tyres and the abs system.
A big brake system will stop the car in exactly the same distance as stock -the abs and tyres are the limiting factor -they will however use less pedal pressure and be able to repeatedly stop the car without heat problems and outlast the stock brakes in life.
best value/quality is wilwood IMHO for bigger brakes and they also fit under stock size wheels.
simply replacing pads and discs will help in some respects but will never match a big brake kit for fade resistance and durability -if you want that save up!
Old May 17th, 2008, 05:37 PM   #3 (permalink)
philly c
philly c's Avatar
looks like a saving sessiopn might be in order i do find that the yoko rubber help stopping as it is alot softer compound than most.
I am going to use willwood brakes and willwood peddle box on my z car as i know they have been prooven over and over by z cars but i good to hear positive things about the willwood set up for the bmw mini too
V6 PHL
Old May 17th, 2008, 11:33 PM   #4 (permalink)
dazo
dazo's Avatar
Online
Roland...you said piston area is greater? i thought this was a bad thing
Old May 19th, 2008, 07:20 PM   #5 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Cool Brakes
Quote: Originally Posted by MINIMANIAUK (original)
...able to repeatedly stop the car without heat problems and outlast the stock brakes in life...
...simply replacing pads and discs will help in some respects but will never match a big brake kit for fade resistance and durability -if you want that save up!
Sums it up really.
Cheers,
K.
Which Discs & Pads? WHITEY_ Wheels, Tyres & Brakes 1 Apr 7th, 2008 10:17 PM
Got the discs & pads, but what calipers? BrandX Wheels, Tyres & Brakes 11 Mar 12th, 2008 04:46 PM
Brake discs & pads icclebug Wheels, Tyres & Brakes 13 Jun 19th, 2007 08:38 PM
Brake Discs & Pads STOYS General Discussion 1 Aug 4th, 2004 03:08 PM
Uprated Discs & Pads jon.od Engine & Drivetrain Tuning 6 May 8th, 2003 06:23 AM
